Vintage Huret Downtube Shifters Upgrade
Hi
I want to build a gravel bike out of my (beautiful) 70s steel Motobecane. It has downtube shifters installed with a huret clamp and I want to upgrade to Shimano shifters. I prefer to have a kind of cable holders attached to the frame, but the huret clamp is not like that. So I wonder if you have any suggestions for attaching a kind of cable shifter without doing heavy work such as welding. Or should I just use the huret clamp and just find suitable cable holders with that?
Thank you.
Thank you.
Sr Member on Sr bikes
I bought and tried one of these for my old steel 70s Motobecane. It had the same exact shifter setup that you describe. It works just fine but I didn’t like how far off the dow tube the shifters and cables were.
https://www.brandscycle.com/product/...RoCidoQAvD_BwESo I ended up going with one of these...
https://www.ebay.com/itm/154274201759
(I did NOT pay $75 for mine. I think it was less than $10 brand new.)
And if they’re index shifters you’ll need these
https://thebikeshopstore.com/categor...xoCAtcQAvD_BwE
Dan
I guess clamp-on downtube shifters adapter PTP that Dan mentioned above, combined with some kind of cable holders would work. Though i'd prefer a simpler setting if you know any.
Quoted: 5888 Post(s)
Liked 3,471 Times
This is not hard. You could go with shimano bar end shifters or STIs. In either case, you simply need a downtube cable clamp.
This one is $10:
https://www.amazon.com/Origin8-Alloy...40510981&psc=1
This one is $10:
Likes For bikemig:
Sorry. I guess I misunderstood your OP. Sounded to me like you want to maintain downtube shifters but just Shimano indexed.
Dan
Dan
