Cyclocross Fork Brake Boss Repair
I have a steel cyclocross fork from a diamant. The brake boss is bent and the stud is loose.
Everyone has a “guy” but I don’t have welder.
Anyone have someone that can do these brazes?
Thanks
Bob
Thanks
Bob
Quoted: 964 Post(s)
Liked 1,451 Times
Wouldn't cost much to mail the fork to @gugie , forum member who does this sorta thing all the time!
I'd normally say I'd do it, but currently I'm swamped with other duties!
Likes For scarlson:
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
A photo would really help determine how to fix it. I'm a hobby builder as well and could possibly fix it.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
The left boss as you look at it is bent. The stud wiggles.
It is Reynolds 531 according to Eddy Martens of Martenelly, the maker of the frame.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,801 Times
If the post isn't bent, just brazing it back would do the trick, as long as the posts were jigged in place.
If not, removing and replacing the bosses would be advised.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
^Completely agree with the statement above. If they need to be replaced it would be easier to replace both and move them to modern spacing (80mm) to open up your brake choices. Also, you do understand that the paint will need to be removed.
I am good with just brazing it. But I think the left one may be bent. Also good with removing it and installing a new one. I don’ think the fork is bent but if so now is a good time to straighten it. It will have Mafacs put back on it.
Understand the paint. I did the paint myself with a rattlecan. I can repaint the fork.
Do you guys know of anyone that could do the repair.
a possibly helpful suggestion: find out if there is an established Maker-Space nearby; there's likely to be someone with a frame jig or some knowledge of how to braze properly.
Quoted: 2363 Post(s)
Liked 1,749 Times
Randomhead
Liked 3,699 Times
You can still get Mafac bosses
Anyone know someone that brazes?
Quoted: 634 Post(s)
Liked 444 Times
Any frame builder can take care of this. Google is your friend here. I googled and found two in Georgia. There are probably more.
https://zukascycles.com/About.html
Deep South Bicycle Company
A fork is pretty easy to ship so you could send it to most any frame builder to have it fixed. Here's a list (probably not comprehensive) of framebuilders in the US:
https://theframebuilders.com/list/
Likes For tricky:
Quoted: 28 Post(s)
Liked 60 Times
If the boss is not terribly bent and can be re-used, you can likely find a local (non-framebuilder) welder do the fix. Get a small piece of flat bar steel and drill 2 holes at the same spacing of the 2 boss centers so that you can use the stud bolts to make a simple jig to connect both studs together. The alignment of the loose stud will then be set by the unbroken boss (unless the stud is really bent out too far). With the bosses jigged together for alignment, most any semi-competent welder will be capable of brazing the stud back onto the boss. You might be able to find a local automotive machine shop with welding capability to take it on, all of about a 5 minute job. Once the stud is re-brazed, it alignment/bend is still out then you can likely use a crescent wrench of the stud to tweak it back if needed.
Rest of the vintage CX build looks great!
Likes For GrayJay:
Thanks for all the advice. Gugie is going to take care of me.
This forum is awesome.
Likes For con50582:
Quoted: 964 Post(s)
Liked 1,451 Times
Totally new fork? Or did he just fill up those voids under the edges of the crown? Either way, looks like great work and a quick turnaround time!!
Likes For Jimbo1983:
Liked 5,801 Times
gugie got this thing right. A true craftsman and I highly recommend his help if you need a torch with the artist/mechanical knowledge to get you right. Cant thank him enough.
Looks like you did a great job matching the paint, would love to know details. Did you go the color-match at an automotive paint place route? Rattle can yourself? Looks like you found the correct decals as well, did you clearcoat?
Cantilever posts are pretty easy to braze on once you get the correct miter and use a jig. I've got a fancy Anvil model, but you can get good results with a DIY scrap metal method as well.
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,478 Times
Brent
Likes For obrentharris:
Thanks for the kind words!
Easiest vintage install of cantis ever after your adjustment to boss placement and for the first time the whole pad touches. Should have done this years ago.
Likes For con50582:
