A bit unorthodox choice of carbo source for long runs?
#51
Quoted: 2333 Post(s)
Liked 2,097 Times
Try to figure out your sweat loss on normal rides. The weather is cool on PBP, I would be surprised if hourly sweat losses are more than 8-12 oz on average. For me, the daytime averages are a little more and the night losses are a little lower. Estimating sweat loss gets complicated on long training rides because I tend to end them in a glycogen depleted state and each gram of glycogen has 3-4 grams of water with it. For instance, I went on a hard and hilly 3 hour ride in 35-45F temps the other day. I lost 1% of weight. I had consumed about 16 oz of water to thirst (maybe 2/3 of the bottle). Afterwards, I drank a glass of water and had lunch. All better. YMMV.
#52
Quoted: 3460 Post(s)
Liked 1,466 Times
I had a problem that involved a lot of swelling, when I got back into USA, I was at my Doctor's office within 24 hours and their lab tests showed that I had some weird things going on, very high blood pressure, etc.
#53
Liked 2,097 Times
Also, be careful of using ibuprofen during endurance events. I saw my MD a day after a hilly, hot 300km and the blood work was legendary in his office, make sure you tell the Doc and explain what such an event entails.
https://pubmed.ncbi.nlm.nih.gov/28679502/
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC3366912/
https://ultrarunning.com/features/we...100-mile-race/
What we can say about weight is that maintaining a stable weight during exercise will mean that one is likely to be over-hydrated.
Weight gain. The runner should be advised to reduce fluid and salt intake until urinating, particularly if there are signs of swelling (rings are tight, runner feels puffy).
#54
Bikes: 2004 Trek 520, resto-modded 1987 Cannondale SR400, rando-modded 1976 AD Vent Noir; 2019 Wabi Classic; 1989? Burley Duet
Quoted: 213 Post(s)
Liked 93 Times
Well yeah, upon reflection I injured my ankle during PBP and was prescribed prednisone afterwards. So that probably explains it...
If you had noticeable swelling, you have or had a medical issue. If you did not have noticeable swelling, the scale read wrong. If you have a re-occurrence, you should have a doctor decide what lab tests should be run and those test samples should be collected quickly before you get back to normal. And a blood pressure check for sure.
#55
Liked 2,097 Times
#57
False. False. False.
I used 70-80% fat in 2015 and I was standing on the bridge into Brest in 22 hours.
You are getting very good tips from many randonneurs.
It is impossible to fuel a Grand Randonnee with food, you must burn a lot of fat. 2.5 times your basal metabolic rate is the limit to how much food you can absorb a day. So, burning fat a lot of fat is essential.
https://www.science.org/doi/10.1126/sciadv.aaw0341
I tried to run low on carbs earlier this year, and it always ended in a bonk in 3-4 hours for me. The usual routine was: I ate a big carb-reach breakfast (700-900kcal total), then rode 3 hours using sweet isotonic only (700ml with 35g of carbs in it) as my only source of carbs - that's how far I can go before I start to feel like bonk is closing on me. I still could toughen up and run for may be an hour more, top - but with more and more fatigue and more and more frustration and suffering. Usually I don't strain myself like that, and just start eating some sweets (jellybeans, bananas, carbo-bars etc) at the end of the 2nd hour of riding. But even that doesn't mean I won't get bonk later anyway.
And I don't even ride at some exhausting tempo, my heartrate is at 125-130 on average, and speed is about 25-27kph (not that high for a roadbike on pavement). I could probably try to achieve even lower heart-rates, but then my speed will be laughable and I definitely won't be able to achieve my goal (27-30kph on a long rides).
#58
Randomhead
Liked 3,698 Times
I have gotten swollen ankles after grand randonnees. Not PBP, thankfully, I would be afraid to fly home.
#59
Liked 2,097 Times
Then I don't know what I do wrong.. Because on my 200km rides before, I had to eat A LOT of carbs, otherwise I got bonked regularly. As someone suggested before, I actually tried to count the carbs I consumed, and number for my last ride (200km with 2000m of total elevation, on a cold rainy day, with about 9 hours spent in saddle ) are as such: 3700kcal and 670g of carbs. Despite that I tried to eat some sweet things regularly, I still felt like I'm about to bonk 3 times, and had to use an emergency gel to prevent it. My avg heartrate was at 130 may be, and maximum was at 160 (hit it only once on a particularly steep climb, I tried to not go above 140 in general).
As a point of reference, if this helps...I dunno, on my last 200K, my average HR was 112 and the highest I hit that day was 120 (it was unseasonably warm, I was not fit. Normally, my average is 100-105 bpm). I can hit 183 on a treadmill and my highest self inflicted HR on a bike recently is 172 bpm but could probably do 175 if I had do. My threshold HR is around 150-153. Sorry if this is too detailed. My resting HR is 60, so I have a range of 112 beats on my heart (172-60). If I average 112 beats on a ride, this is 46% of my range (112-60 divided by 112). Another to look at it is percentage of threshold HR or about 58%. At these levels, type 1 slow fibers can meet demand using almost all fat (when trained). You are probably closer to 70-75% and this level of effort takes a lot of glycogen and so yes, it is easy to bonk. I would slow down a little for now. In any case, GL.
#60
At the same time, I check the other guys who ride the same routes with me - most of them are seasoned randonneurs, and ALL of them have either the same heartrate as me, or even higher. And ride faster, some of them MUCH faster than me..
#61
Liked 2,097 Times
That's correct, usually my heartrate averages somewhere between 125 and 135 on rides over 100kms. At brevets I try to keep it at about 125-130 on plains, and below 140 on uphills, if possible. Thought sometimes I can just get carried away on a long downhill with a tailwind, and get over 140 beats while speeding down the road
I can't even imagine how to reach such heartrates, tbh. I tried, honestly tried riding very slow - still barely could reduce it to 125 beats on average, on 100+kms rides. First problem is uphills - it's often hard to keep it even under 140 when climbing; occasionally there is steep hill I can only climb on the lowest gear and with my heartrate at 150-160.. And I'm climbing so slow at these moments it's painful on itself Like, 10kph or something. Then, as fatigue grows, it becomes hard to stick to low heartrate even on plains, you just don't pay attention to your headunit for may be 10 mins, and then boom - you are already at 140, though you didn't even feel like it. If I'll be running it at 110 beats, I'm afraid my average speed will drop below the threshold needed to get to finish in time.
At the same time, I check the other guys who ride the same routes with me - most of them are seasoned randonneurs, and ALL of them heart either the same heartrate as me, or even bigger. And ride faster, some of them MUCH faster than me..
If you are happy with your riding, why make a change. Keep at it. It is very hard to give useful advice. To be honest your objective of 125-130 beats per minute sounds high but you could be very young. Getting the sleep you desire is also very difficult.
I normally get 240-250 watts at 120 beats when fit. It only took me about 150 watts average to do PBP in like 54 hours total. At 200 watts average, most average sized riders would be finishing in 43-44 hours. This is why it seems to me that 125-130 average HR is too high in addition to your running out of gas. The best way to go fast is not to stop at all, just to get your card stamped.
Randonneuring is not about power as much as it is about energy efficiency, balancing output and intake with consideration to rest. Hard efforts should be very rare on a brevet. Managing the gut is also critical. You have to figure it out, sort thru some of the ideas and try them out.
#62
#63
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
#64
Liked 2,097 Times
Not a typo. Proper training for endurance will increase the amount of blood in each beat. You want to become like a diesel motor instead of a high revving 4 banger. The most straight forward person to look up is Alan Couzens. He has an old blog and is very active on Twitter. He is an exercise physiologist and coach who mostly works with Ironmen who frankly have similar training objectives. Getting the sleep you require and finishing in 90 hours is possible but very few can do it. Everything has to be perfect.
#65
Liked 2,097 Times
I think the best recent research on this topic was conducted by the US Army recently because they were killing recruits with excessive fluid intake, obviously they meant well. I am sorry I no longer have the very long study report link. Ultra running also had some good studies. Leadville 100 comes to mind. It is a complicated thing. Fluids. And we are all different. I need almost no fluids on my recumbent but quite a bit more on my upright.
#66
If it's not a typo and 220W is zone 2 for you, your FTP should be at around 400W.. That's professional athlete threshold, so I hardly can compare myself to you, we are in different worlds.. Mine is 250W, and I'm losing hope of reaching even 300W already..
#67
Quoted: 213 Post(s)
Liked 93 Times
Can I ask, how much are you riding just generally?
#68
Liked 2,568 Times
if you do not have health issues, improper fluid and/or mineral intake can be the cause of peripheral swelling.
I've been worried that I might have to give up SPD pedals for longer rides, since taking my shoes off every stop eats time. This gives me something to experiment with.
#69
Liked 2,097 Times
I am trying to help you understand what you are doing wrong and what you can do to reach your challenging goal of sleeping 8 hours each night on PBP. When I did PBP in 54 hours and all my qualifying brevets in under 60% of the time, my FTP was 271 watts and I weighted 86-88 kg doing my SR. So, my functional threshold power is not much different than yours. What is very, very, very different are our lactate curves and the training that got me there.
You need to spend less time doing intensity work using glycolytic type 2 fibers and more steady work building your aerobic engine. Do some reading or get a coach. Here are a few links to get you in the right direction. GL.
https://simplifaster.com/articles/ho...le-is-vo2-max/
https://www.howardluksmd.com/zone-2-...r-less-injury/
#70
Liked 2,097 Times
This is still blowing my mind a little... I'd noticed for years that my feet don't get hot spots nearly as soon in cooler weather. So I'd always attributed my foot-swelling to heat in the summer, and thought the swelling meant I wasn't drinking enough water!
This is a bit over the top but I weigh myself before and after every ride of significance. I have gotten my hydration a little wrong recently by not drinking enough. I am mostly riding my upright bike and I sweat a lot more on that bike or probably more like the larger frontal area means more evaporation losses. In any case, too much or too little is a problem. (some need sodium and some don't......I do not know why). I also noticed that when I get fitter and thinner, I might need very little water in moderate temps (60-70F) but then at higher temps (90+), I sweat like a pig compared to when less fit. This is kind of why I keep an eye on my pre ride and post ride weight.
Likes For GhostRider62:
#71
Randomhead
Liked 3,698 Times
My feet swell right at 95 miles, no matter what. This is not really accompanied by visible swelling in my legs. The bike community as a whole thinks that you need form-fitting shoes, but I think that's overblown. Although I guess after 95 miles my shoes fit better. I go one (european) size bigger.
Likes For unterhausen:
