What is this?
Bikes: '92 MX Leader, 84 Colnago Mexico, 85 Recherche, 86 Panasonic ATB Pro, 88 Roberts, 80 moser... ect
Quoted: 68 Post(s)
Liked 134 Times
What is this?
I'm not concerned value wise, just curious what this is. Looks like a bottle cage but smaller...
Quoted: 68 Post(s)
Liked 134 Times
Just asking a simple question. Are you a Mod in training? Seemed pointless for me to start a thread in C&V about a cage. If you could direct me to the 'what is it forum' it would help.
Quoted: 68 Post(s)
Liked 134 Times
Another pic with a standard size cage for reference.
Quoted: 3811 Post(s)
Liked 3,339 Times
uncleivan -
IIRC REG (Rampinelli) offered a junior size water bottle and cage
spent a few moments just now to see if could locate an image of one, but without success
perhaps another reader may recall this product, there were likely other brands as well
for what size tube are the mounting clamps intended?
REG did have one small bottle found an image of but it is flask shaped, evidently intended to be carried in a musette or jersey pocket
capacity is given as fifteen ml, which sounds very small indeed, suspect this figure must be an error
perhaps someone intended to write fifteen dl
have you considered the possibility that the holder may be for a battery which is part of a lighting system?
from the 1920's through the 1940's there were combination bicycle lighting systems which employed both a dynamo and a battery
in these designs the battery typically mounted to the frame in some form of bracket/holder
uncleivan -
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
What’s stamped into the upper ring?
Looks pretty robust to me, maybe a mount for a tool kit container? Or a gas bottle for camp stove?
Quoted: 68 Post(s)
Liked 134 Times
It is made by Coloral. I picked up a couple bikes yesterday along with a box of parts. Neat stuff. I'll share more in the C&V forum.
Likes For EddyR:
Liked 3,339 Times
advert of 1950 -
advert of 1950 -
Likes For juvela:
Quoted: 790 Post(s)
Liked 1,767 Times
These are older vintage bottle cages made for 40' 50's alloy or glass tapped bottle cages which are about 5mm smaller than modern standard. Also as noted above Cooral and sever other makers made there own specific bottles and cages the uniform bottle cage size we think of did not come into the main stream until the late 80's.
Quoted: 18376 Post(s)
Liked 4,511 Times
So, does it fit the ubiquitous disposable water bottles which don't fit well in standard cages?
Quoted: 790 Post(s)
Liked 1,767 Times
Good question that could add to value considering the slight spring and solid build of the cage and slight flex in modern disposable water drink bottles I would ques yes. Also would a large size 24 oz beer bottle fit?
Liked 3,339 Times
one infrequently encountered COLORAL product is their bag support -
Quoted: 68 Post(s)
Liked 134 Times
It might fit something the size of a can of Red bull. Its not any bigger than that.
More than likely, mid 50's, as that fits with most of the other parts.
I didn't know they made a bag support. There were two Karrimor 'uplift' bag supports in the box. Haven't seen one in years.
Thank you Juvela for your time.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
Super small junior cage....Maybe one of theses will wet junior's whistle.
Pick your poison
Best, Ben
Pick your poison
Best, Ben
Voltaire
Voltaire
Edumacator
Quoted: 2439 Post(s)
Liked 3,128 Times
Metal bottle?
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,925 Times
Didnt this used to the “ What is this and how much is worth” thread?
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
