Is My Chain The Right Length?
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
Just finished upgrading my Dahon Hemingway from factory 9-speed to 11-speed..
Components, all brand new:
- L-twoo A9 shifter and rear derailleur (factory 9-speed group was L-twoo A7, rebranded as Dahon; was absolutely reliable and worked great, so decided to use the same off of Aliexpress)
- Sunrace 11-speed cassette, 11-40t
- KMC chain, 11-speed
- Wolf Tooth narrow wide chainring , 130mm BCD, 52t (knew I shouldn't skimp on these )
- CDHpower crank arms, 165mm arm length (Chinese, but definitely not cheap at $75 off of Amazon.sa Prime, delivered to door)
Here's where the chain ended up:
Is it too long or just right?
Quoted: 4208 Post(s)
Liked 3,875 Times
"just right" is a determination made after the system is used. Have you used it yet in real life?
Generally there's a range of a few links between too short and too long. Where within this range your bike's best set up is found by trying. I usually err on the long side as one can more easily shorten a chain than lengthen it.
The photo shows a chain that is not too short or long but that's all I can say from long distance. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Look at the Park Tools website for how to size a chain (Big/Big plus 1 or 2 links depending on how you are counting)
Likes For Kapusta:
Quoted: 506 Post(s)
Liked 639 Times
Likes For KerryIrons:
Quoted: 966 Post(s)
Liked 1,629 Times
So far looks good, your right in the sweet spot. Some times finding the right chain length can be tedious. Especially when resurrecting and old bike with Parts Bin components. Just beware of the short or too long chain. It can really wreak a nice bike.
Likes For Camilo:
Quoted: 792 Post(s)
Liked 1,494 Times
Andrew R Stewart I haven't actually taken the bike out of the street yet, but I can report that after I've made the proper H/L adjustments (really only the H side needed to be curbed in; the L side was already spot on out of the box... Or plastic Aliexpress bag ) I could run up and down all the gears with no problems.
With that being said, L-twoo say that this derailleur can take up to 42t, but I had to screw the B screw all the way in just to keep the upper jockey wheel comfortably clear of the big cog.
Also, gears 4 and 5 are particularly noisy, which I find odd given that the chain is straightest in these two gears!
Advanced Slacker
Liked 2,537 Times
However, in my experience, it is better to minimize the excess chain bouncing around when going over bumps. Less likely to hit the chain-stay, and less likely to drop a chain. I might make less difference for your bike (can't tell what it is, but it looks like a commuter or touring bike?) but it makes a difference on MTBs, especially if the RD is not a clutch type.
If this is a 1X setup with plenty of excess wrap capacity, then maybe I would not go as short as big/big plus one (perhaps I'd go one link longer). But unless there is something in the setup instructions for that RD that says otherwise, I'd shorten it.
That's my $0.02.
Likes For Kapusta:
Advanced Slacker
Liked 2,537 Times
This is another reason to consider shortening the chain. As you pull the cage down, the jockey wheel moves away from the cog.
Quoted: 3513 Post(s)
Liked 2,926 Times
I'd say this is pretty bad advice--if not dangerous. Out on the road is the last place you want to test out your repairs--including whether or not your chain is the correct length. This is what bike stands are for--to determine if there will be a problem before you take the bike out on the road in "real life."
Advanced Slacker
Liked 2,537 Times
Liked 2,926 Times
Advanced Slacker
Liked 2,537 Times
Seemed pretty clear to me.
And FWIW, the OP is clearly within this range.
Likes For Kapusta:
Likes For easyupbug:
Liked 2,926 Times
Liked 2,926 Times
Quoted: 1109 Post(s)
Liked 1,200 Times
Yes, it looks like your RD has a lot of excess chain wrap capacity for your setup, so there will be a wide range of chain length that will work. And yes, you could go longer and it will still work.
That's my $0.02.
That's my $0.02.
It is a 1X as in the OP: "Wolf Tooth narrow wide chainring , 130mm BCD, 52t "
Advanced Slacker
Liked 2,537 Times
It's not my my bike. But I still don't understand what you see in the pictures that would lead you to think that the chain is too long. When it's on the big sprocket, it looks to me like the derailleur wouldn't like a chain that is shorter, there isn't much curve as the chain wraps through the pulleys. Is that what you're looking at thinking that it could be shorter and not over-tax the RD cage?
As far as WHY i would consider shortening it… I gave reasons in two different posts.
Likes For Kapusta:
Liked 3,875 Times
Of course all the possible work that can be done without test ride feed back should be done before that test ride (unless the ticket or mechanic's judgement calls for a pre assessment/servicing test ride). To claim I said otherwise is not right. To suggest that a mechanic's after service ride is not the right way to confirm actual performance is missing a vital point. That the work is only valid when the repair stand and real life rides agree. Would you expect your customer/friend to be the gunnie pig after your work? To not consider a test, and the feedback loop it offers for further tweaking, is poor procedure in any field is just lacking credence. There are a number of differences with in stand functions and in the field ones (brake squeals come to mind fast). The after service test gives the mechanic the real life feedback they need to more fully understand that bike's issues and abilities to be "tuned" better. Some call this learning and striving for best performance.
I could go on about the lacking of "turn screws by the numbers" manor of instructions and the lack of basic understandings of method and procedures but these are for another thread. Andy
AndrewRStewart
AndrewRStewart
Liked 2,926 Times
I can only envision someone getting on their bike after "adjusting" their chain length, heading for a hill, launching into low gear and lurching forward as their derailleur explodes because the chain was too short. As for chain length, I still believe "just right" is a determination to be made before the system is used. Had it been me, I would have left your statement for the end of your post.
But again, I apologize, and thanks for your clarification.
Liked 3,875 Times
I apologize if I misinterpreted what you wrote, or what you intended. But leading off with the statement "'just right' is a determination made after the system is used. Have you used it yet in real life?," implies that this is the initial test that will determine proper chain length.
AndrewRStewart
AndrewRStewart
