Correct chain length not possible?
Quoted: 21 Post(s)
Liked 9 Times
Hello there, hopefully someone can help me out. I recently converted my hardtail MTB into a singlespeed. I'm using a 42T chainring with a 14T rear sprocket. The frame has vertical dropouts so I am using a Surly Singleator chain tensioner to tension my chain, all though it's not really working.
Basically, if I am to take a link out of my chain right now, it's too short and won't reconnect so that's not an option.
I also can't tension the chain by pushing the tensioner upwards anymore as it's hitting the frame, meaning the chain is on and does work but it's incredibly loose and keeps falling off the rear sprocket after a while. (the cable ties are there because the Singleator is actually not so good of a product and kept losing tension after I would bunny hop).
Lastly, pulling the chain down instead of pushing it up results in an undesirbale chain skip if I crank the pedals too hard, so I'd definitely prefer to push up.
So I am a bit stuck now, does anyone have any suggestions? I'm even considering just buying a horizontal dropout hardtail frame but am struggling to find any that are cheap.
I have a DMR tensioner on the way which doesn't utilise a spring so hopefully the results may be a little bit better.
https://www.sheldonbrown.com/singlespeed.html
https://www.sheldonbrown.com/no-derailers.html
You might also want to use an enclosed cam skewer if you're running single speed with vertical dropouts. They clamp much more firmly when properly installed than the open cam style.
Likes For Hondo6:
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
Are the chain and the (rear) sprocket new?
Where does the skipping occur when you pedal hard - at the rear, or at the front?
Basically, my line of thought is to make sure the sprocket and the chain are new (not worn) and try then with that chain tensioner that pushes the chain downwards.
If that fails, try with a Shimano Alfine chain tensioner (Amazon affiliate link).
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Zip ties tell me something is wrong with your installation.
https://surlybikes.com/uploads/downl...structions.pdf
Likes For dedhed:
OP: looks like you installed your current chain tensioner in "push up" mode. You might want to try the "push down" mode instead. That may allow it to work properly with your configuration. The link dedhed posted tells you how to change the tensioner from one mode to the other.
Likes For andrewclaus:
Quoted: 21 Post(s)
Liked 9 Times
Quoted: 21 Post(s)
Liked 9 Times
I ask because the manufacturer (Surly) specifically notes in their installation instructions that some specific user configurations may require either the "push up" or "push down" configuration to work properly. (Their instructions also say that you have to reverse the spring in order to use the "push up" configuration, because the product is shipped in the "push down" configuration. I'm going to assume you did that.)
If you haven't tried the product in both configurations, you don't really have a good reason to call the product "garbage". And so far, you haven't stated whether or not you've tried both.
Quoted: 332 Post(s)
Liked 742 Times
You haven't explicitly stated whether or not you've tried the "push down" configuration. Have you?
Quoted: 21 Post(s)
Liked 9 Times
"I also can't tension the chain by pushing the tensioner upwards anymore as it's hitting the frame, meaning the chain is on and does work but it's incredibly loose and keeps falling off the rear sprocket after a while."
"Lastly, pulling the chain down instead of pushing it up results in an undesirbale chain skip if I crank the pedals too hard, so I'd definitely prefer to push up."
Quoted: 21 Post(s)
Liked 9 Times
Im curious about this too, though it does seem like the OP states they tried this and it caused chain skip. I imagine it would work better with a cog with more teeth, but then the chainring would need to be swapped to retain the current gearing (which to me seems too high anyway, especially if the bike is being used for trail riding).
Quoted: 1944 Post(s)
Liked 2,164 Times
A tensioner should function like a rear derailleur cage, but obviously without chain wrap.
I’m guessing a more traditional position is to push down the chain.
John
Edit added. Technically you could slap on your old rear derailleur and lock it in the proper alignment using the high limit screw. If the limit screw won’t move it enough, use a few inches of shifter or road brake cable going through the RD barrel adjuster.
John
Not to be condescending but reread the original post please if you're going to attempt to answer. I've already stated that both configurations don't work.
The last sentence of your original post indicates you have tried some form of chain tensioner that works in a push-down fashion and found the results unacceptable. However, you did not explicitly state whether or not that was done using your existing Surly Singleator. For all we know, that could have been a different chain tensioner you tried previously that worked only in a push-down mode. That's why I asked the question.
Does your original post imply you tried it with the Surly product? Perhaps. But until you tell us you did, we don't know; we're assuming.
Assume: ass-u-me. It's generally if not always best to ask the questions necessary to confirm assumptions.
Finding out precisely what has and has not been tried previously is pretty much step 1 in troubleshooting any problem. That's all I was attempting to do above.
Hopefully someone can help you figure out how to fix your problem.
Quoted: 21 Post(s)
Liked 9 Times
Not to be condescending, but perhaps you should re-read my last comment above. And no, your original post did not explicitly state that you've tried your existing Surly Singleator in push-down mode.
Oh, I know - we're supposed to magically know that's what happened without being told. Or, in other words: we're supposed to assume that's the case.
The concept of "verifying an assumption to make sure you are correct" shouldn't be that hard to grasp.
Done on this thread. Good luck.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Sounds like the product is garbage if it only works when it's zip-tied all the way against the frame. I would try the half link suggestion mentioned above, and if that doesn't work find a better tensioner. There are other ones out there.
It's like riding a bicycle
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
I'm probably being a big dummy but, the Surly Singleator needs the proper spring for the mode it is in.
Push up spring for pushing up.
Pull down spring for pulling down.
The wrong spring will cause it to work terrible.
Lastly, are you using the 18mm cone wrench to load the spring?
Your problem seems unusual. Even so, a half-link has been recommended & would do a world of good.
Also, a 48, 16 would also be identical in every way except chain length to your 42,14. So, there is that.
Quoted: 431 Post(s)
Liked 460 Times
Use a 16t or larger cog. Use a cog without shift ramps. User the tensioner in push down mode.
Quoted: 21 Post(s)
Liked 9 Times
Fortunately, the Singleator also ships with a seperate push up spring. So I dissasembled my Singleator and armed it with the push up spring, tensioned it with the 18mm wrench to which it appeared to tension fine but after riding the bike for less than an hour, the Singleator would drop the tension, meaning that I would have to then re tension the thing; obviously undesirable and had nearly led me to fall off the bike twice!
THIS IS THE REASON THE CABLES TIES ARE THERE. By cable tying it the Singleator does not lose the tension, but of course it looks, and is, terrible.
UPDATE:
The entire problem is fixed by using a DMR STS tensioner. One WITHOUT a spring. See image below.
I'm lead to believe that the Singleators spring loaded tensioning approach is the reason behind the product performing horrendously for me. Who knows though, I'm just one guy so maybe I got a defective one? For £60 however I was expecting much better. The DMR tensioner cost me £17.99 and after a 3 hour ride today, it appears to be a much more reliable bit of kit.
Likes For bikethis:
