For Sale 1983 Colnago Super Fork 55cm to 57cm
verktyg
Quoted: 1038 Post(s)
Liked 1,240 Times
SOLD 1983 Colnago Super Fork 55cm to 57cm
For sale - 1983-1986 Colnago Super Fork 55cm to 57cm: $50.00 plus < $15.00-$20.00 shipping - US only, PayPal Friends & Family or local pickup.
This fork came out of my 56cm 1983 Colnago Super that I sold to a friend a few months back. I'm selling the fork for him. Not perfect but very usable and reasonably priced for a REAL Colnago fork. It's being replaced with a NOS Colnago factory made fork that I had sitting around for about 10 years.
Colnago used this style aero fork crown from 1983 until at least 1986. It will also work on an older Colnago frame too. The steerer fits a 55cm to 57cm frame, maybe even 58cm. It's made of Columbus SL and is properly aligned, the crown was refaced and the threads are good.
When I got the frame in 2006 there was some surface rust in the chrome on the crown plus the drive side lower fork blade from cable wraps used to mount a speedometer. I cleaned it up and rode it that way for 15 years - it passes the 10 foot test and could be easily replated.
700c x 28mm tires clear nicely, 700c x 32mm may even fit???
Pro quality headsets have a 38mm to 42mm stack height. The current headset is 42mm high with several 1mm spacers at the top.
Easy way to measure the steerer and head tube to determine stack height.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Maybe I missed it, but what is the steerer tube and thread length? I have a Colnago frame that is languishing without a fork. It’s a 57 so this should work, but I’d like to check your measurements against what I need. And BTW, I’ve used your stack height photo to measure HS needs for other frames. Thanks
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1113 Post(s)
Liked 1,927 Times
sigh. its a year newer than my frame, but I'll take it. See you in SF in a couple of days.
Robert
Robert
Edumacator
Quoted: 2492 Post(s)
Liked 3,231 Times
But it's a Colnago and cheap!!! It will look great with it!
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
That's a great deal. Too bad you don't have a Ciocc fork for a 58cm frame!
Phyllo-buster
Quoted: 2299 Post(s)
Liked 2,059 Times
Quoted: 2588 Post(s)
Liked 4,827 Times
This will get you where you want to be for now. Just keep an active watch for the correct one (which should be fully-chromed, too). Over time, one will pop up - they always do. Then you can either pass this one to someone like you looking for just the right fork, or keep it as a spare.
Finally, the geometry will not be any different, so the ride - the most important thing - will not suffer. That's the best news of all.
DD
DD
Likes For Drillium Dude:
verktyg
Liked 1,240 Times
SOLD
Thanks for looking
Thanks for looking
Chas. ;-)
Chas. ;-)
