Freehub body, cassette biting on freehub body??
Bikes: Fuji roubaix 1.1
Quoted: 20 Post(s)
I have a set boyd altamonts and they have an aluminum freehub body
i want to replace it with a steel one or titanium if the price is reasonable
but i dont know which free hub body would it i have a ten speed bike?
Do you guys know which freehub i would need??
Boyd Cycling owner
Quoted: 10 Post(s)
The freehub body is unique to our hub. We do have a Ti freehub body coming out in a couple weeks for our new Eternity hubs, but the one you have is aluminum. The notches are not necessarily a bad thing.
I wrote a blog about this and you can check it out here. Notches in a Shimano/Sram freehub body
Middle-Aged Member
Bikes: Bianchi Infinito CV 2014, TREK HIFI 2011, Argon18 E-116 2013
Quoted: 24 Post(s)
Quoted: 20 Post(s)
I wish boyd would make the titanium version for the altamonts will it be compatible with the altamonts??
Boyd Cycling owner
Quoted: 10 Post(s)
The Titanium freehub body will only be available on the new Eternity hub. That will be a hub option for any of our wheels, but will be a $350 upgrade. We are in production on them right now, and set to release very soon.
Quoted: 6556 Post(s)
Liked 58 Times
You can extend the useful life of the Al freehub body by occasionally filing down any ridges that are raised up by the cassette gouging into it. This assures that you won't have future trouble removing the cassette. The trick is to not wait too long the first time. Problem is that after a while there won't be enough spline left to keep the cogs from rotating. That will take a while though, but still just be careful to only take off the tops of the gouges. Also I wouldn't want to advise you to do anything that would void the warranty on your hubs/wheels.
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
I've had a lot of aluminum free hubs with gouges. Some bad enough that it took a little bit of effort to get the cassette off.
I've never had a freehub get to the point the cogs wouldn't stay in place, even on a tandem where you're putting twice the torque to the hub.
At most, it's a slight annoyance. If anyone ever got an aluminum freehub to the point of failure, I'm pretty sure they got a lot of use out of it first.
So just keep using the aluminum body, and if ever does fail, replace it.
You could get lost and die.
You could hit a tree and die.
Señor Blues
Liked 58 Times
Yes really. That freehub has many thousands of miles left on it. File the raised lumps down to the level of the tops of the splines. It will be fine. But it is mainly not such a big deal because you can just get a new one to replace it if and when that is necessary...which is not for a long time from now.
Señor Blues
Liked 58 Times
I do it all the time. Not on my own wheels but on ones I am fixing for friends and the occasional wheel customer. You just have to wiggle it off little by little. Sometimes in a really bad case you have to file the freehub in front of each cog. And once I had to put ice on the aluminum to shrink it relative to the steel cogs. If you don't wait so long to do it, it isn't such a problem. But if you file the splines flat again, you can ride that freehub for a long, long time. Remove it every few months and file it flat so the cassette doesn't get stuck again. I don't have the problem anymore personally because I use SRAM Red cassettes which don't damage aluminum freehubs.
Señor Blues
Look at the photo again. It's not a matter of filing down a few bumps. There are more gouges on the other side of the freehub body and just as deep as those you see. Those gouges are ready to accept the cogs of the cassette and get everything stuck all over again. I've not been foolish enough to just throw the cassette on there without some kind of shims or protectors. That would be insanity.
Yep, it can be a BIG deal..
Quoted: 86 Post(s)
the trouble with distorted and notched freehub splines is that the notches are not square, they ramp up and the torque created by riding tightens the cassette onto the freehub body. it can be very difficult to get off. the displaced freehub body material can make it even more difficult that one would think. there are probably 60 to 80 notches on a notched freehub.
the hard part is that there is precious little to hold on to while one tries to dislodge the cassette, that doesn't also turn with the cassette. seeing as how the cassette must be turned slightly counter-clockwise to dislodge it, and the freehub is designed to freely turn counter-clockwise too.
the problem and it's solution are similar to the one presented by a freewheel threaded on to a hub, sans rim, and that needs to be removed. ...nothing to hold on to. ... and elusive.
sometimes, two chainwhips (or one by simply shifting on to the small cog and immobilizing the crank) can help if the cassette has a separate small cog. by attaching one to the smallest cog and one to one of the middle cogs, and turning them in opposite directions, with some effort, it's possible to dislodge the multi-cog carrier counter-clockwise.
Bikes: S-Works Roubaix SL2^H4, Secteur Sport, TriCross, Kaffenback, Lurcher 29er
I've used these for years to minimize the gouging and avoid needing to replace freehub bodies.
10 Speed Clip Kit - Small Parts - Parts
Thread Killer
Quoted: 3143 Post(s)
Liked 1,707 Times
I agree it can be a PITA, making a routine, quick service a time-consuming job.
American Classic's solution is brilliant: steel face inserts. It allows them to keep the weight savings of aluminum, but with the durability and usability of the steel, while avoding the considerable expense of titanium.
Liked 58 Times
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
AC makes (made?) Steel shims that could be used on other hubs (i think).
If I had Shimano type hubs I might try making shims out of shim stock and sliding them in the gap when installing the cassette. Glad I use Campy, so this is not an issue .
Thread Killer
Liked 1,707 Times
Thanks to 11spd cross-compatibility, using a Campagnolo freehub and gear cluster to replace, or instead of, Shimano units is a totally legit way to solve the problem. Campy 11spd gears work perfectly under Shimano 11spd derailleurs, as do Shimano 11spd cassettes work great under Shimano derailleurs.
Thread Killer
Liked 1,707 Times
Señor Blues
the trouble with a distorted and notched freehub splines is that the notches are not square, they ramp up and the torque created by riding tightens the cassette onto the freehub body. it can be very difficult to get off. the displaced freehub body material can make it even more difficult that one would think.
the hard part is that there is precious little to hold on to, that doesn't also turn with the cassette, while one tries to dislodge the cassette. seeing as how the cassette must be turned slightly counter-clockwise to dislodge it, and the freehub is designed to freely turn counter-clockwise too.
sometimes, two chainwhips can be a help if the cassette has a separate small cog. by attaching one on the smallest cog and one on one of the middle cogs, and turning them in opposite directions should, with some effort allow one to dislodge the multi-cog carrier counter-clockwise.
Super Moderator
Liked 927 Times
The AC shims are what svtmike posted a link to in post #16 above.
Middle-Aged Member
Quoted: 24 Post(s)
I had to use a whip on each of the 4 middle cogs of my ultegra cassette to get it out of the aluminium it had bedded in so deep.
