Stiffness Does Not Matter
#126
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
No, it just means the energy is absorbed over a smaller distance, but it’s the same amount of energy. The stiffness affects the degree of deflection, but not the force input to cause that deflection.
#127
Quoted: 338 Post(s)
Liked 408 Times
Hypothetically, you could measure power at the pedals and power at the rear wheel.
If the same power meters, cranks, rear wheel c,hain and derailleur are used, and the same BB is used, the difference should be the same if the bikes are equally efficient regardless of stiffness.
The only confounding factor which would have to be controlled would be the BB shell tolerances and alignment.
#128
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
It's the same amount of energy being exerted on it, but I don't think that means the same amount of energy is stored. If I exert 5w with my foot against a brick wall, the brick wall doesn't deflect at all. By your logic, that means the 5w is being stored in an infinitely small amount of space.on the wall. What I think is actually happening is the 5w is being dissipated into reshaping my foot.
Isn't resistance by definition the opposition of the flow of energy? If the stiffer bike is more resistant, then it is actually less energy that is being transferred to it.
Likes For livedarklions:
#129
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
And even in your brick wall example, the force is reshaping your foot. It’s not magically pushing 90° down the wall. On a magical infinitely stiff bike, the lateral force is mashing rider A’s foot in the shoe, not pulling the chain.
And with that I’m done on the topic.
#130
Quoted: 3952 Post(s)
Liked 7,297 Times
1. The displacement of a spring is proportional to the force applied to the spring. The potential energy stored in the spring scales with the square of the displacement, and therefore the square of the force. A soft spring will therefore store more potential energy than a stiff spring when an equal force is applied.
2. All real springs are damped, so some energy is lost when a spring is compressed and then allowed to relax. Given two springs, one stiff and one soft, with equal losses, the soft spring will lose more energy than the stiff spring when subject to the same forces.
#131
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
The amount of energy a spring absorbs and stores is a function of the force applied to it over the distance that it compresses. That is also the amount of energy that the spring releases.
So the more flexible frame does absorb more energy when it bends, but it also releases that same amount of energy when it straightens out again.
The underlying debate about whether stiffness effects efficiency has to do with whether the released energy of the spring (the bike frame) is
a) significant enough to worry about
and
b) going into driving the bike forwards or being used up in some other (less useful) way.
EDIT: the post above mine (Tomato Coupe) details this very well. Also, the part about real springs having some damping is true and worth noting, though I think in the case of a steel spring (steel bike frame) this is probably negligible for the current discussion.
Likes For Kapusta:
#132
Liked 7,297 Times
Likes For tomato coupe:
#133
Liked 7,297 Times
* Sorry, no offense intended.
#134
Habitual User
Quoted: 4946 Post(s)
Liked 8,086 Times
#135
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 565 Times
Likes For Clyde1820:
#136
Quoted: 20810 Post(s)
Liked 9,456 Times
#137
Take rider A on bikes X and Y. Rider A always has an identical pedaling style, and puts 5w laterally into the BB. Bike X deflects 4mm at the BB under rider A's 5w lateral. Bike Y is stiffer and deflects 2mm at the BB under rider A's 5w lateral. Bike Y deflects less, but still absorbs 5w laterally.
#138
Quoted: 1944 Post(s)
Liked 2,164 Times
#139
Habitual User
Liked 8,086 Times
#140
Advanced Slacker
Liked 2,537 Times
The implication being that when a frame flexes such that a rider's full energy is split between forward motion and downward flex, that upon un-flexing the frame returns that energy directly into forward motion. I suspect a spring could achieve this, aside from heat loss, as it's force is in-line with both compression and return. But a frame's flex would have to be spot-on equivalent and in-line, and occur at a time when the rider could actually use it, for the return, in order to recover that energy in the form of the forward motion that was previously lost. Wouldn't it?
As far as the timing, that would be part of the question I pose at the end of my post (the part that you did not quote).
#141
Liked 7,297 Times
#142
Quoted: 12 Post(s)
Well, since the entire lightweight bicycle doesn't weigh very much then why not suspend the rider on the frame instead of suspending the rider and frame on the wheels ? In the first case the entire bicycle would be un-sprung weight while in the second case only the wheels and suspension would be un-sprung weight. But again the bicycle doesn't weigh very much against the total weight of bicycle and rider.
The problems would seem to be that a seat suspension would hinder pedaling while sitting in the seat. But then if there were only a handlebar suspension that would tend to pitch the rider's weight forward. If there were both a seat suspension and a handlebar suspension the rider would move more vertically. Of course there is a Specialized 20mm handlebar springing and dampening.
Now one bicycle developer has a seat compliance system that moves the seat mostly front and rear and not as much up and down. I suppose that the development has our attention. Well, it's the Cannondale Kingpin system that should be considered. They call it a suspension while I call it a seat-compliance-system. But another system is the Trek rear IsoSpeed. Then the Trek front IsoSpeed is a front-to-rear movement of the handlebars !
My solution is a stiff frame with a deflecting fork and deflecting seat post. Of course my sport is not long-range rides but short downhill courses like a paved sports-car track but relative to the 40 MPH speed of the bicycle.
Or maybe we should test the Cannondale Kingpin rear system with the Specialized Future Shock front system ?
Now we all know that a wheel suspension at the rear of a bicycle does reduce pedaling effectiveness.
#143
Quoted: 7652 Post(s)
Liked 3,473 Times
Seems simple enough to me .... the motion of the crank translates the motion of the foot into motion of the chain and ultimately, the rear wheel, which propels the bike forward. Anything in the system which transfers energy anywhere not alo0ng the perfect (circular) path of the crank, wastes propulsive energy.
Think about a bike with really loose bottom bracket bearings, or cranks which weren't tight to the spindle---no one would be trying to convince anyone else that those things in some way returned energy to the bike because "ya know, conservation of energy." If the whole frame flexes at the bottom bracket, same effect---some of the potential propulsive energy goes in different directions. When the frames snaps back (or is pushed back by the other crank) it is still lateral, not longitudinal motion, and this does Not help propel the bike.
it's going Sideways, people. Unless you want your bike to go sideways , any sideways motion is wasted, since "wasted" in this case means "not propelling the bike forward."
The only way the bike could be acting as a spring and propelling itself forward with energy from deflection would be if the bottom bracket twisted longitudinally under load---but that would imply a fixed or high-friction crank bearing.
Think about it .... if your wheel shakes from side to side really badly, are you going to claim that its okay, because the energy lost will be returned and help propel the bike forward.?
For maximum efficiency, everything has to stay in the plane in which it is meant to operate. Every angular flax is a waste of energy. Y'all are engineers with degrees and all that ....
Ask the race-car engineer: Is frame flax a good thing? Does it make the car go faster? No ... eventually it breaks drivetrains because all those drivetrain parts are designed to work in very specific relative orientations. The forces involved with automobile engines are so large that transmissions will explode, gears will strip, cranks will snap .... the forces involved with cycling are so puny that realy almost nothing happens ... which I think was the OP's point, he just said it badly.
Likes For phughes:
#146
Tragically Ignorant
Liked 9,098 Times
#147
Liked 2,164 Times
Likes For 70sSanO:
#148
Tragically Ignorant
Liked 9,098 Times
I'm so confused by this issue and all the conflicting opinions on it (which generally all have to be better informed than mine) that I've decided that the best approach is to ask the bikes. They're not talking.
#149
Liked 9,456 Times
#150
Tragically Ignorant
Liked 9,098 Times
I'm hearing them, it's just not talking.
And I can't for the life of me understand why anyone would pay money for those buzzy hubs. Talk about things I wish I couldn't hear!
