Why no idler wheels on tandems?
Quoted: 680 Post(s)
Liked 949 Times
with long wheel recumbents and long chains why not use this method instead of having to retake the bottom bracket? it would be far easier to deal with and easier to fix or take off a chain.
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
Other than old or really cheap frames, tandems tend not to have them for the same reason fixed gear bikes don’t. The lower chain portion can end up in tension, which tends to be hard on the idlers. Most also want the chain length to be fixed, IE no rear derailer type idlers. Without the fixed length chain the sync between captain and stoker floats a bit and the top can lose tension.
Finally, a half decently made eccentric is more secure and less easily damaged than an idler.
Don’t get me started on plastic tubes being used as chain guides.
Likes For jccaclimber:
Quoted: 2495 Post(s)
Liked 738 Times
The main issue is that there needs to be a way to fine tune the tension in the system to allow for 'chain stretch. The previous answer is correct in so far as the need to have tension on the return run of chain, but an idler could allow for that.The horrible tension adjusters fitted on department store TSO's are, in fact, idlers in a sliding carrier. The *usually) extremely small diameter of the pulley wheel, and the overall lack of refinement of such designs makes it easy to overlook that this is actually an idler system at work.
Quoted: 127 Post(s)
Liked 133 Times
It isn’t just that it needs some tension to not derail. It’s also that the captain backpedaling makes the lower chain portion a high tension segment rather than just a slack tension segment.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
IMO an absolutely tight chain between captain and stoker is a must. Each rider needs to be able to feel the pedaling of the other rider. I think that conventional timing chains have too much slack. When we changed from a chain to a tight Gates belt, it made a big improvement to our pleasure-in-togetherness we get on the tandem. An idler pulley would make it much worse.
Results matter
Results matter
Bikeable
Quoted: 173 Post(s)
Liked 104 Times
I was a bicycle store owner for over 12 years and used to sell tandems, some of the less expensive ones had idler wheels (Crestline tandems come to mind), The truth is one thing is for sure: Idler wheels are really, really really noisy. Trust me, I you want a half way decent tandem, you don't want one with idler wheels)
Likes For headwind15:
Bikes: 1984 homemade 531SL road bike; 1988 Ritchey TimberComp; 1997 Nashbar tandem; 1998 Kona Explosif; Specialized Epic, Scott CR1 Pro; Salsa Beargrease; Curtlo custom Tandem, Curtlo custom S3 steel gravel bike.
Quoted: 67 Post(s)
Liked 49 Times
Interesting observation about the timing chain being a way for the captain and stoker to communicate. We have a timing chain (as most do) and have no problem at all telling what the other is doing. Maybe that comes from riding the tandem together for many years. And if I don't get the message through the cranks there are other less subtle ways to communicate!
Bikes: Cannondale '92 T600 '95 H600 '01 RT1000
Quoted: 92 Post(s)
Liked 109 Times
The one time I remember having to explicitly yell something was riding up a steep hill in the South Dakota Badlands with my son. I was trying to drop into the granny gear but he wasn't catching my backing off just a little and I couldn't shift!
Our S&S-coupled custom steel framed tandem has an idler wheel. It is necessary to permit removal of timing chain during disassembly for each trip's transport in two pieces in our truck.
After fighting to spin off tensioned chain for a while on our new build, we ground and welded a mount and added the sprung idler.
