Max tire width on Alex DC19 (16mm internal width) rim
Quoted: 101 Post(s)
Liked 41 Times
Just looking for some experience with wider tires on a 16mm rim (specifically, Alex rims DC19).
I've looked at this chart from Sheldon, but even he says it is conservative. However, even when I look at the more generous chart here from Schwalbe's site (ETRTO 2007) my rim size seems to fall between two sizes listed (15 & 17), where oddly enough a very large difference occurs in the maximum tire size. 32mm is max for a 15mm rim, whereas 50mm is listed as max for the 17mm rim.
Anyway, anyone have any real world experience with large tires and a 16mm internal width rim they could share? Currently I'm running the 700x30mm tires that came with the bike, but I'd like to go to 40 or 42 in the front and the same or a little less in the back (depending on clearance).
Thanks,
Thanks,
Quoted: 101 Post(s)
Liked 41 Times
Never got any replies, but I thought I'd post an update for posterity.
I went ahead and put on a 40mm tire in the front and 35 in the back (that was about the limit to clear the chainstays). I've done about 80 miles of gravel riding with no tires rolling off the rim, just one pinch flat in the back that I blame on the terrain.
Quoted: 1944 Post(s)
Liked 2,164 Times
Didn't see this earlier. As you found out, you are not having any problems.
I've posted before elsewhere that I have mounted WTB 2.1 (52mm) on 14mm internal width rims with no issues.
John
John
Quoted: 4806 Post(s)
Liked 3,928 Times
Ben
was as wondering if you had any bad experiences with wider tires on the 14 mm rim? I have a similar rim and am thinking about putting some wtb 40’s + 47 on the back on those rims.
Thanks,
brandon
Liked 2,164 Times
I've had no issues at all, but in the dirt there is a little give on the surface so the rollover may not be as severe as hard cornering on pavement. But I'm also running 50mm+ on 14mm which is probably pushing the envelope as much as "im"practical.
Mavic 217's are closer to your width (16mm-17mm) and they have had a great reputation for running wider tires. I've used them for a while as well.
John
John
Bikes: Vilano Urbana, DownTube FS9, Montaque paratrooper, Nano mini-velo, Motobecane CX, Raleigh 20, MIFA folder, ROG Pony, Iverson Grand Touring folder, Exclusiv German folder
Quoted: 168 Post(s)
Liked 191 Times
Old thread, but the exact issue I'm facing. Love BikeForums.
Gonna take my 8 year old old Bikesdirect Motobecane Fantom Cross for a tour of the GAP. It has DC19 wheels and I had put 26mm Conti's on it when new. Now researching fat tires for road/ass comfort.
I find this https://www.treefortbikes.com/Qualit...t-On-Alex-DC19
"The 700c Alex DC19 rim is compatible with 700c and 29" tires. Recommended tire sizes are 700x30-47mm or 29" tires up to 2.1" wide and should work with most hybrid and fitness bikes. This version of the Alex DC19 rim features a machined sidewall for improved braking performance."
With that input and wheelsmcgee's I am comfortably contemplating 35 to 47mm.
wheelsmcgee, thank you
Likes For mirfi:
Quoted: 507 Post(s)
Liked 237 Times
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
I have run tires the size you were looking at on narrower rims. My only caution would it be to keep the pressures low with the larger size tires. I have cracked a couple of rims and I attribute it to too much pressure and fat tires. I believe Sheldon speaks of this somewhere on his site.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
