Squeak where spokes cross?
Quoted: 455 Post(s)
Liked 112 Times
Have an issue of squeak/creak where spokes cross. These are black spokes.
Àny thoughts?
Àny thoughts?
Quoted: 4205 Post(s)
Liked 3,864 Times
Just how did you determine that the spoke crosses were the source? And the sound described as a squeak is not the typical spoke crossing noise. Spoke color doesn't affect the notching that is the common cause of spoke cross noise , a click/tick with a resonance that the wheel's size amplifies. Please explain your assessment in greater detail. Additionally can you measure the spoke tensions? Andy.
If in fact that is the source,
Wrap the cross with thin copper wire and solder it .. it won't do that any more..
Liked 3,864 Times
Or to test, place a piece of business card stock (or better yet a credit card stock) in between the touching spokes, all of them. Then ride the bike. Andy.
I once had a pair of factory built Ambrosio wheels with black spokes. Where the spokes crossed they weren't laced under/over. There was a space between the spokes. I originally thought they made a error when lacing them, so I contacted Ambrosio. They told me that the wheels were built that way on purpose to keep the black spokes from squeaking.
Quoted: 455 Post(s)
Liked 112 Times
OK, here is the whole story. I work PT in a LBS and a women bought a Scott Contessa. She is someone we know as she had a Felt road bike but crashed it a few weeks ago. She brought the bike in yesterday saying it was making a noise. So I checked the cable tension on the RD and also checked and adjusted the FD. She road it and came back today saying it was still making "the noise". So I took off the spoke protector thinking maybe that was it and when I was checking the spoke tension I squeezed a few pair of spokes and she said'That's the noise!". So I went outside and jogged alongside of her while she rode. I hate jogging! And it did make a bit of noise. Not the noise of a newly built wheel where the nipples are seating themselves. So I had heard about using a drop of lube on each touching spoke,I know this is a short term fix. But I will see her on a ride Tuesday.
So that's the situation. I am open to advice.
Quoted: 1324 Post(s)
Liked 927 Times
Cheers
Liked 3,864 Times
This thread is a great one to ask if noise is always wrong, a situation requiring a fix. I have my opinions but would be interested to hear other's thoughts. Andy
Here is the link to website on bike noise:
Bicycle Bike Noises, Clicks, Ticks, Creaks, Clunks, Knocks Repair by Jim Langley
Andy,
Not sure if wrong, or requiring a fix, but I personally dont care for any noises.
Andy,
Quoted: 455 Post(s)
Liked 112 Times
Will try the business card technique next. Thanks!
Quoted: 4560 Post(s)
Liked 2,802 Times
Stainless steel has a reputation for galling, something that worried early owners of stainless steel firearms decades ago. But I'm not sure it's worth fretting over for bicycle spokes.
Quoted: 837 Post(s)
Liked 1,061 Times
I've had some limited luck with using waxed dental floss by just flossing the spoke contact spots. Sometimes it cures the problem permanently sometimes not. As mentioned make sure your spokes are tensioned properly. A string coated with grease is another option used to floss the spokes with. Lots of ways to skin this cat.
Quoted: 455 Post(s)
Liked 112 Times
I had the opportunity to ride with the lady last night and heard first hand the "noise". It sounded like a spoke noise so she graciously dropped the bike off at the shop this AM. Did 2 things first I re-lube the hubs bearings and adjusted the cones then de-tensioned the wheel and then re-tensioned and trued it up. Took it out for a test ride and no more noise!
Thanks for your replies!
3-in-1 on wheel nipples
I found this 10 year old thread really helpful. I did the card thing -- even oiled all the spoke crossings. No luck, though it did help me identify the one offending spoke that made so much creaking noise. Turns out it was the wheel nipple. A put on a few drops of 3-in-1 on and it was solved. My only concern is if 3-in-1 is corrosive to tubes. A dab of grease might be better. I might also try tightening the spoke later, but didn't want to go down the truing rabbit hole at the time.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
I trimmed the threads and told the person to learn how to sing show tunes…loudly!
Stuart Black
Stuart Black
Quoted: 506 Post(s)
Liked 638 Times
Bikes: 1988 Bottecchia Professional (for Eroica), 2011 Ridley Noah ISP (retired), 2020 Soma Fog Cutter (daily commuter), 2021 Ridley Kanzo Adventure (gravel), 2022 Tideace Aero (main road bike).
Quoted: 77 Post(s)
Liked 76 Times
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
Then there's the stethoscope with open tube end.
Indeed, the OP mentioned they re-tensioned the wheel, which is likely what actually solved it.
I seem to remember reading that some Pro-Lite wheels come with little plastic thingies (for want of a better word) at the point where the spokes cross over. I wonder if there's a source for those?
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
Yup. This problem developed on my rear hub drive ebike last summer. Not a squeak, thought at first it was bad crank bearing, but took me a while to solve it. Went over rear spokes with wrench and snugged those that were loose. Voila, problem solved (until next time).
WhatsYoCadence
Track Cycling: Velodrome Racing and Training Area
10
12-19-17 11:42 PM
