When to buy new tires?
I just recently pulled a rock from my tire, and it looks like it almost hit the tube, but it didn't.
It made a very tiny hole.
Is it time for a new tire or would you keep riding until a flat?
Fat Guy Rolling
Bikes: Bacchetta Agio, 80s Raleigh Record single-speed, Surly Big Dummy
Keep riding them until flats become much more common (tire gets thin). I pulled a piece of wire out of one of my tires yesterday. It did puncture the tube, so I replaced that. The tire is fine, the hole is tiny.
Quoted: 2639 Post(s)
Liked 1,987 Times
I've worn the last two tires until the tread separated (ride of shame: not fun). But if you don't get tires from a bad batch, you can ride them until they're worn out. I define worn out as:
You can see the threads through the rubber.
The rubber in the middle of the tire changes color.
The rubber in the middle of the tire feels softer than on the edges. Normally coincides with multiple, frequent flats. More than one flat every couple of weeks, unless you find a big honking piece of glass or metal, means it's time for a new tire.
Bikes: Workcycles FR8, 2016 Jamis Coda Comp, 2008 Surly Long Haul Trucker
Liked 6 Times
You can replace them when they are worn through. Or you can replace them when you have the money for more flat resistant tires.
Papaya King
Bikes: 2009 Felt X City D, 1985 (?) Trek 400, 1995 (?) Specialized Rockhopper, 1995 Trek 850
If you're concerned about punctures, but your tires don't seem to be worn out, you could always add some tire liners.
Bikes: Bianchi Via Nirone 7, Jamis Sputnik
Bikes: noyb
As above. I recently changed a tire out right before it got to this stage - very square, different color, several large holes that were rocks/glass. After blowing out a tire one time due to thinning I decided to replace them when my 'gut' was telling me to.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1253 Post(s)
Liked 338 Times
I mostly get 35s - 38s. Probably 80 % have had sidewall age failure or tread edge corner cracking.
About 10% tread thinning and the rest are flat damaged.
Conti-s seem to be the crack prone ones. My first Schwalbe MP has been flawless so far, 1700 miles.
Acts 2:38
Bikes: '10 Marin Lucas Valley, '13 Scott Speedster 20
Waiting to see how far my Conti-Contacts will take me. 2,700 miles and counting with only two flats.
Liked 1,987 Times
I gave up on a Contact after 4700 miles (rear, including a lot of commuting). That thing was a beast to get on and off, and when I tore up my second tube trying to fix a rare flat, I'd had enough.
