Wheel building book.
I’m looking for recommendations for a good book on wheel building and maintenance. I don’t care if it covers all maintenance as long it has a comprehensive section on wheels. Many thanks
Quoted: 2026 Post(s)
Liked 1,096 Times
The classic in the field is Jobst Brandt's "The Bicycle Wheel", first published in 1981. I believe it it out of print but easily available through used book sellers and Amazon.
This is a highly detailed and theoretical treatment of bicycle wheel design and function. Some of his claims are a bit controversial but still very thought provoking. There is a lot of practical, hands-on info also.
The book is obviously dated and, of course, says nothing about carbon rims and other material and design changes since it was written. Still, well worth the time.
Likes For HillRider:
Really Old Senior Member
I started here-
https://www.sheldonbrown.com/wheelbuild.html
I bought Brandt's book, but had trouble wrapping my brain around some parts.
OTH, I have mild Asperger's, but I thought that would help wrap my....
How do you define "maintenance"?
If you are talking hubs/bearings, just Google "bicycle hub maintenance".
It's not the same as "wheel building".
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times
Plus one on Brandt's book. Also, Sheldon Browne has an excellent how-to at his site. I just rebuilt my rear wheel after 30-plus years. Couldn't find my copy of the book but the on-line info from Browne got me through it with flying colors!
Jon
Jon
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times
This is the book I learned (and am still learning) from - Most excellent, for a $12 download :
https://www.wheelpro.co.uk/wheelbuilding/book.php
Musson's book covers everything, in an easily understood fashion - I actually printed it out, and keep it in a ring binder on my workbench
Likes For mixteup:
On my bookshelf is "building bicycle wheels" by Robert Wright, copyright 1977, cost: $ 1.95 BITD..
Half way there
Quoted: 986 Post(s)
Liked 880 Times
+1 on Musson’s book. I have both it and Jobst Brandt’s, and I found Musson’s more useful as a stepwise set of instructions for how to build a set of wheels. They’re both good books and complement each other, but if I had to pick only one to learn how to build wheels, it would be the Musson’s book.
Likes For ted_major:
I went one step further and got an instructional DVD that takes you step by step through the entire process of building a 3 cross rear wheel for a road bike from scratch. It also has information for variations like building for disc brakes or 2x spoke patterns, how to measure for ordering spokes, what tools you need and how to use them etc. The cost was small considering the skills you can learn from a Master Wheel Builder. I have since built several wheels very successfully and have greatly improved my truing skills along the way. Google 'billmouldwheels', if you cant find where to order the DVD, just email him. He has always been happy to answer any questions.
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 227 Times
it's called life, can't recommend it highly enough
I've read three books about wheel building, begin with robert wright's as an easy intro, then read jobst brandts' for some theory and musson's for detailed and well explained instructions.
The best advice you will find however is in these forums' brains
Clark W. Griswold
Quoted: 4356 Post(s)
Liked 3,994 Times
this book was strongly recommended to me: ART OF WHEELBUILDING: A BENCH REFERENCE FOR NEOPHYTES, PROS & WHEELAHOLICS, By Gerd Schraner.
the high price of the book has kept me from owning a physical copy. however, if you use your google-fu, you can find a downloadable pdf of it.
Brandt's book is pretty excellent. For individual topics, I really like some of the blog posts on https://www.wheelfanatyk.com/blog/ .
Quoted: 4806 Post(s)
Liked 3,929 Times
"Building Bicycle Wheels" is an excellent book for one's first wheel. Robert Wright uses plain English, simple terms and does a good job of demystifying wheelbuilding. He is as straightforward in real life. Also an excellent wheelbuilder. (I say this in present tense. I knew him 40 years ago. He doesn't blow his own horn. I knew from others he built good wheels. Had no idea he'd published a book two years before.)
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
Mussons to learn what to do and how, Brandt's book to learn/understand why it's done that way.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Another vote for Musson's book, "Professional Guide to Wheelbuilding". I laid out the dough to buy a legit version of this. More modern than Jobst. Explains some things Jobst doesn't.
Jobst's book is also excellent. I had a hard copy and I think I lent it to my stepfather and he passed away so I can't find my copy.
Schraner's book "The Art of Wheelbuilding" is also very good. A bit idiosyncratic and counter to some modern wheelbuilding thought, though. Still (in 1999) he recommended tying and soldering on some wheels. Even for track bikes I think that this is now a discredited practice.
I do expect that the Secret Guild of Exalted Spoke Solderers to rise up en masse and will converge on my house with torches made from extra-long seat posts to visit their wrath upon me and my heathen untied spokes. Sigh.
Any of these books will teach you a lot. I'd start with Musson. A second (or alternate first) choice would be Jobst. Schraner's book is useful once you have the first two books under your belt. My 2 cents.
Liked 1,096 Times
J have both the Brandt and Schraener books. I like the spoking method in Gerd's book. For hub maintenance you can use Park's site or the manufacturers.
