Looking for a Road/Gravel ebike with/without Throttle
Old 05-23-21, 06:26 PM
sanditude
Hi All!
Please could someone recommend a good eBike each with 'and' without Throttle for UK? I am not looking for a full-blown eMTB, just a Road/Gravel bike that can climb some minimal hill terrain.
Budget can be upto circa GBP 1500 for a decent-built bike.
Also hope its Motor capacity shouldn't exceed 250W to make it road legal as a Pedelec in UK? or has the 2016 rules changed since..
Thanks in advance,
Sandy.
sanditude is offline
Old 05-23-21, 09:50 PM
2old
Quoted: 533 Post(s)
Liked 311 Times in 227 Posts
Also consider pedelec.uk.co. Almost all of the majors have a PAS-only gravel bike, but very few (maybe none) have throttles.
2old is offline
Old 05-24-21, 08:59 AM
Chuckles1
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 124 Post(s)
Liked 89 Times in 61 Posts
Throttle can help you maneuver at low speeds when turning around in road, or starting out at an intersection, situations where pedal assist could thrust you ahead and make you lose control for a second.
Chuckles1 is offline
Old 06-02-21, 03:19 PM
Calsun
Quoted: 15 Post(s)
Liked 5 Times in 4 Posts
The heavier the bike the heavier the bike rack is going to be to support the weight. Also there are a few bike racks with ramps (Thule, Yakima, 1up) and this makes it a lot easier to get a heavy bike up on the rack. 1up provides the longest ramp which is part of the reason I bought one of their two-bike racks.
A lot more rack options with a e-bike that weighs less than 45 lbs which you will see when you check the specs for the racks.
Calsun is offline
