Dealing with bridges and RR tracks
I've long been bent-curious and recently taken the plunge into riding some of these bikes. One thing that I knew about, but didn't know just what a nuisance it would be is not being able to hop or lift the wheels over road obstacles. I can avoid potholes (usually) but on the roads and trails I ride, there are several bridges and RR tracks to cross. The bridges on the bike path seem the worst with some of the crossings having a 1" or 1.5" step up onto the bridge. On an upright bike, these are no issue to take at speed (in some cases 20+mph) and scarcely a hindrance, only missing a pedal stroke or two. On the 'bent, they give me pause. So far I have just kept my tire pressure on the high side, favored the largest tires I can run and slowed down for these obstacles. I have tried leaning my shoulders against the backrest to lift my butt out of the seat, but that doesn't seem to do that much. Is there a better way to deal with these road hazards? Slowing down especially is fairly anathema but I don't have a better solution yet. Any suggestions?
Quoted: 3352 Post(s)
Liked 1,056 Times
Quoted: 523 Post(s)
Liked 229 Times
The worst RR crossing I ever encountered was at the edge of the Michigan State campus where the tracks were angled at about 45 degrees. I hadn't been used to riding a narrow tire bike or even finding a crossing that wasn't at right angles to the road. Of course when I entered the crossing the bike went sideways and I went down in a heap. A two wheeled recumbent is no different when it comes to crossing them - slow down and move into the road so that you are crossing the tracks straight on. We have a few of them in the Las Vegas valley and so far I never went down on one of them riding a recumbent.
Quoted: 896 Post(s)
Liked 2,064 Times
RR tracks I cross as close to 90 degrees as possible on any kind of bike.
For uneven pavement, on my DF I don't bunny hop I just raise off the seat. On the 'bent I do the same.
I've hovered around 200 lbs for a long time, have ridden a 'bent tens of thousands of miles on 1 1/4" tires at 90psi, and have not had an issue with pinch flats. I'd say don't overthink it and just ride.
Simply pay attention to where you are riding. And-------------------I agree about the mis match of road or trails on to a bridge. Some how road builders cant seem to make an approach that is smooth last. Apparently they dont pay enough attention to compacting the dirt and underlayment right where you go onto the bridge proper.
I guess the front of the bike is lightly loaded so the 28mm tire I can cram up there may be enough? I can get a 40mm in the rear where the weight is (LWB model).
Quoted: 966 Post(s)
Liked 1,629 Times
One area that both bicyclists and motorcycle riders will agree... Don't mess around crossing rail road tracks!
Ride more, eat less
Quoted: 715 Post(s)
Liked 736 Times
Besides crossing the railroads at perpendicular angle, there is a technique to "unweight" the front wheel by accelerating quickly from near stop, low speed and using the forward momentum to get the front wheel over first.
This takes good amount of practice and likely to damage the front wheel when it hits the mark.
Practice on the grass try to get front wheel over something soft like a plastic soda bottle for a few times first before attempting actual railroad or rounded curbs.
Ride more, eat less
Quoted: 715 Post(s)
Liked 736 Times
That's probably the general limitation for LWB recumbents, but you don't have to lift the front end completely off the ground to allow front wheel to "unweight" and roll over minor obstacles.
As mentioned before, it takes practice, lots of it for some.
Quoted: 22 Post(s)
Liked 17 Times
Arcata Bottoms, northern CA
Cheers, MAC
Quoted: 2333 Post(s)
Liked 2,097 Times
The wheelbase on my bent almost exactly measures the rail gage distance between the tracks and when they are wet, I walk. I don't need more damaged kit and bloody body parts. On wet metal bridge surfaces, I might also walk or at the very least, I unclip and sit up. On uprights I would accelate and jump tracks and never once went down on tracks on an upright. If the tracks are at an angle, I stop and walk 100% of the time. At night on unfamiliar roads, I stop and walk tracks. Once bitten, twice shy
Likes For GhostRider62:
