Steel
#76
Old Worn Treads
I Googled it. Amazing tool that Google.
"By the time the modern "safety" bicycle was developed in the late 1800s most frames were made with steel tubing instead of wood or cast iron. While the steel bicycles were quite strong they were also very heavy. It was not uncommon for a bicycle of that era to weigh in at over 80 pounds."
So seems steel was the material in late 1800's.By 1900, Karl Siemens in Germany replaced Bessemer steel with a better method. You still started with a big batch of melted blast furnace steel (“pig iron”), but instead of cold air you slowly added wrought iron (which has a lot of oxygen in it) or rust (iron oxide) until you had the right amount of oxygen in the steel. Then you added limestone as before.
Hope that helps.
Cheap steel leads to hundreds of new inventions
An open-hearth process allowed for making "cheap steel" and was invented in 1900 and was easier to control and could make even bigger batches of steel. The price of steel kept on going down, while the quality got better and better. People started to make all kinds of things out of steel including bicycles.Hope that helps.
But that's not my question, I would like to know what kind of steel tubing, or piping, was used back in the 1880's to early 1900's in the construction of bike frames? I can only assume from your answer that you don't know just as I don't know, fine, I can live with that.
Does anyone else know?
#77
Stuck in Toeclips
It's all down to construction. I really do think 1" steel with short chain stays was the pinnacle of the grand compromise, at least for metal bikes. (And yes. You need at *least* four).
#78
I have been on my Gunnar 8 years and it is a wonderful riding bike.
Likes For wvridgerider:
#79
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 405 Times
I gifted my steel rigid mountain bike ('95 Marin Muirwoods) to my son thinking my modern aluminum bikes were all I needed.
Didn't take long before I missed the ride of steel. Picked up a steel framed SS and its been my go to.....
Likes For Speedway2:
#80
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
Hope that helps.
Likes For rekmeyata:
#81
Quoted: 1857 Post(s)
Liked 664 Times
Agree that a well engineered steel bike is smoother, the steel itself makes a difference also. Butting, grade of steel, design, all makes a difference. That being said, a neighbor is selling his 2002 LeMond Alpe d'Huez. The frame is 853 steel with a carbon fork. Too small for me, but I took it for a short spin anyway. Yes, it sure is smooooooooth!! My old mtn.bike is steel, but chromoly and rides nothing even close to the neighbor's LeMond. Good steel is for sure real!
Glad you like steel! So do I!
#82
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Not sure that Vitus was the first. Reynolds 531 also came out in the 1930s, and Columbus claims to have made seamless, cold-drawn tubing even earlier:
#83
Liked 253 Times
#84
Jazz Aficionado
I’ve been riding a Waterford RS33, True Temper S3, Carbon front fork, Campy Record 10sp, Ritchey for the past fifteen years. Bought it when I was fifty four. Custom fitted and built by Vecchios in Boulder. I still get a really nice smile on my face, like I did yesterday morning riding it. Could have bought Carbon, but the Waterford build is so smooth, comfortable and it handles like a dream.
Likes For Climb14er:
#85
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 212 Post(s)
Liked 356 Times
People out and about seem to appreciate my Gunnar Roadie. I know I do.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Likes For Shadco:
#86
Bikes: 2014 Fuji Cross 2.0 LE, 1993 Santana Vision, 1993 Specialized Allez Pro, 1993 Trek 930, 1985 Panasonic DX3000
Quoted: 49 Post(s)
Liked 75 Times
I have always found Steel to be a better riding bike than aluminum in road bikes. My first "Real" bicycle, was a 1988 Peugeot Versailles with Light action Shimano components. Not top end by any means but a comfortable bike. In 1991 I moved up to a Trek 1400 which was aluminum. Nice bike and very light, but super stiff. After I recovered from being rear ended on the Trek, I picked up a Specialized Allez from 1993. That thing was so smooth. I also had a 1993 Trek 930 with True Temper OX that was smoother than the 1400. Several years back I got a 2014 Fuji Cross gravel bike. Aluminum frame, but running 32's on the tires. Someone commented on aluminum frames with large tires would be similar as steel from on 25's, and I do agree with this. The Fuji rides very nice, but if I were to run 25's, or 23's I'm sure that would change the game.
#87
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
What about a carbon fork which comes on most newer aluminum bikes, does that have a big impact on the ride? I have a few steel bikes, a few chromoly bikes and 2 aluminum road bikes with carbon forks. I find my 2013 Cannondale CAAD 8 to be a pretty smooth ride but my Peugeot with 453 Reynolds steel is also super smooth. I have a gas pipe steel bike which is not smooth and very heavy.
I've never ridden a carbon bike so can't speak to it.
Likes For gthomson:
#88
Quoted: 8280 Post(s)
Liked 9,041 Times
I have a Kestrel fork on my steel Gunnar. It rides smoother than the cf fork on my Seven.
Likes For big john:
#89
Quoted: 49 Post(s)
Liked 75 Times
That's a great question. My Fuji has a carbon fork, My Specialized has an aluminum fork, and my other 2 steel frames have steel forks. Of all of them, I like the feel of the carbon fork the best. It's just personal perception, but it does feel smooth, and not harsh in my riding.
#90
Liked 253 Times
I personally, don't trust my arse to be on a CF bike, with CF wheels, I've known people who's CF stuff broke just riding, even my mechanic at my local bike shop won't buy CF. However, on my Lynskey I have a CF fork, which I had the original one replaced back when I bought it for a Enve 2.0 because at the time that fork was rated to carry the most weight at 350 pounds intended to be used on tandem bikes (if I remember correctly the weight limit), I wanted a fork that was going to be FAR over rated for my weight at 175 pounds, the stock fork and the Enve 1.0 was rated for 224 pounds. I'm hoping that fork will last a lifetime, so far so good, and that's my lifetime, not the forks!
#91
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,833 Times
I remember a former BF'er who would love this thread. Didn’t post much in 50+, tho qualified.
I think he made a few t-shirts.
Likes For Wildwood:
#92
Thanks for all the reply's, I've got it now read every post and this is what I learned.
Yes I did buy a touring "comfort" bike so it should be no surprise that it is very comfortable.
But the real take away is I just need another bike or two. Gonna have to work on that.
And I guess the best bike is the one that inspires me (you) to get out and ride.
Likes For Ttom:
#93
IMO/E, tire size, inflation & suppleness (quality) can have far more to do with how 'harsh' a bike feels than frame material. My old Cannondale felt awful with the (cheap) 28c tires that were on it when I got it. Shoe-horning some Rene Herse Barlow Pass tires (38c, 45psi....$$$) on it was transformational in terms of ride & comfort.
#94
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2581 Post(s)
Liked 5,639 Times
I have one CF, one aluminum, one titanium, and 5 steel framed bikes. They are all comfortable, with the CF Orbea Avant being the "harshest" ride. I think the most comfortable is my steel Soma Smoothie, much of that being the geometry and fit. The biggest differences between each bike are the components and the weight.
I also have a steel bike, an aluminum and another carbon. The steel bike is so smooth, the aluminum is stiff but it’s a full suspension MTB, and the other carbon is an endurance frame with more relaxed geometry which really absorbs rough pavement but is still responsive.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
#95
Quoted: 2482 Post(s)
Liked 2,955 Times
Other things equal, I've found that the way a given bike rides correlates not with the frame material but instead with its wheelbase. Long-wheelbase bikes ride smoothly, if a bit stolidly, regardless of frame material. Short-wheelbase bikes give a harder but, for want of a better term, racier ride, regardless of frame material.
For an example, my mid-'80s Columbus steel Bianchi Specialissima, with its short-wheelbase criterium geometry, was no more or less comfortable to ride than a same-era Cannondale Crit series bike (aluminum, obviously) with equivalent geometry. Since then, I've come to prefer the more or less standard road geometry that most companies offer these days, so all my road bikes (steel, carbon, and aluminum) share that geometry.
[Edit: actually, come to think of it, my one carbon road bike has a slightly longer wheelbase, which is probably why I've been riding the aluminum road bike almost exclusively for the last 10 years.]
#96
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1252 Post(s)
Liked 1,284 Times
That being said, I don't buy into this notion that frame materials have specific different riding characteristics that are A) discernable to the rider, and B) independent of design, and fit, and component selection, and probably a handful of other variables.
I currently own two steel bikes, one carbon bike, and one aluminum bike...and have owned at least a half dozen other steel bikes and one other aluminum bike over the years. Plus rented/borrowed a number of bikes made from carbon and aluminum. And there is/was absolutely nothing consistent about the frame material correlating to the subjective experience of riding those bikes.
#97
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
I have had steel forks that I think ruined the ride for me. I had purchased a Colnago Master that was my dream bike, a replacement for my Tommasini that I loved the ride of, but not the look. However, while I still think the Colnago was better looking, the ride to me was terrible and really harsh. Just plain unpleasant, especially through the handlebars. Never thought about it that much, but often wonder it it was all down to the fork - straight steel on the Colnago and curved on the Tommasini.
#98
Grupetto Bob
Liked 5,639 Times
Again with forks, regardless of material, it comes down to geometry (just like frames). My old Bianchi’s fork has a minor swoop/ curve down by the wheel, which absorbs bumps with aplomb while my steel Fondriest has a straight carbon fork does not.
Similarly my carbon “endurance” frame with a relaxed geometry absorbs a fair amount of chip seal vibration while my racing frame carbon lets me feel every pebble - bless its sprightly heart.
Likes For rsbob:
#99
Nothing wrong with steel. I have carbon road bikes, an AL MTB, a TI gravel bike, but my dream bike is steel touring rig. Reason: My carbon race bike is awasome for what it is, but I personaly like riding a slightly heaver bike with more relaxed goemetry and a mellow, stable feel. One look at me and it's easy to see I don't prioritze lightweight.
Likes For IronM:
