Replace 1995? Giant Sedona ATX
Replace 1995? Giant Sedona ATX, Hybrid or Mtn?
Looking to replace my 1995? Giant Sedona ATX. I currently use it like a hybrid. Over the years I have made it more upright riding with a riser stem so I am not so uncomfortable leaning over. At home mostly around the neighborhood with the family. We have been going to Sunriver once a year and I use it on all the paths and also like to do easy single tracks/trails around the area. (no significant uphill/downhill, some tree roots and lava rocks). I would also like to try out the easy Mt Bachelor Mtn Bike Park, which I have been told is very tame.I am not really finding a suitable replacement. I don’t think I really need suspension, but I would like larger tires (40c min, preferably 2.1-2.2). I don’t know much about bike geometries but think I would like it to be fairly upright riding given my current bike. Budget is up to $1500 and I would like it mid spec’d (Deore/equiv +). 1x drivetrain is a requirement.
Hybrids tend to have narrow tires and forks. If they don’t, they have cheap suspension forks. I am big (6’6”/250). I don’t want the suspension to be squishy and inconsistent. My son has a front shock on his precaliber 24” and it is not good.
Mtn Bikes (hard tail), can be had with better front suspension (air instead of coil), but I am afraid they aren’t going to be comfortable enough of a riding position.
The closest thing I have found is probably the Trek Dual Sport. The DS4 is no longer made and the current DS3 has a cheaper shock.
Looking for options and/or recommendations. I would prefer to stay with the larger bike brands, Trek, Specialized, Giant, Marin if possible.
Some Options:
Some Options:
- Mid level rigid mtn bike (ex: Trek Marlin 8) and change stem and handle bar to make it more upright
- Mid level hybrid like a Trek FX 3 Disk or Dual Sport 3 and replace tires and front fork if needed (either rigid or suspension that would allow larger tire/or a better front shock)
- Marin DSX 2 gets pretty close, but it seems like more of a gravel bike and not sure how comfortable it will be
How about another Sedona. I love my 2018. It's 3 x 7 speed transmission gives me a gear for every scenario I encounter. I like their Cypres too. The base model has no front suspension, which I like. Both have wide tires for a smooth ride and the ability to ride on wet grass or gravel.
I am most accurately looking for a rigid hybrid that would accept larger tires.
Giant makes a nice hybrid/adventure bike that might work for you. Their ToughRoad should be good for heavy riders with its composite fork, 50mm tires, and a 2 x 10 speed gearset, not the 1x you want. Going 1x is goinng to seriously limit you choices. Their Escape is a popular choice for a more tradional hybrid with 38mm tires.
If you take advantage of the benefits of a 2x or 3x chainring, like dropping 2 or 3 cogs with a single step, You might find them quite useful. I have. I've put 5,000 km on the triple and it still works flawlessly. In fact I have more trouble at the cassette then the chainring.
Cleaning can be a pain though, and I do like the uncluttered look of a single chainring. But as far as reliability goes, it's a non issue, At least for the kind of riding these bikes are likely to be used for.
I am pretty set on a 1x. I leave it on my current middle front cog almost all the time and only take for the few lowest gears. I am thinking a 1x10 should meet my needs fine. I appreciate your thoughts though.
Likes For dnadrifter:
I am starting to lean toward a Trek DS 3 and immediately upgrade the shock to a Rockshox Paragon Gold RL. This would put the bike at about $1300.
I thought about buying the DS3 and getting a carbon rigid fork (and its still an option) but they are spendy too....at least the ones I found. Its hard to buy a carbon fork for $300-500 when I could buy a reasonable suspension fork.
Quoted: 137 Post(s)
Liked 51 Times
I make my own 1 x by removing which front ring I don't want, using shims on the ring bolts to make up for the thickness difference, remove front derailleur and shifter and you are finished. 20 to 30 min. Tops
But I guess then you would be missing out on the expanded casette of one designed for a 1x drivetrain? Making your own just saves weight then vs just not using the other front chain ring?
