Chain adjustment
Quoted: 92 Post(s)
Liked 20 Times
Chain adjustment
I see two adjustment screws on my 1975 Motobecane derailler.
It looks like the one on the end is the only one of the three I should adjust to tighten the chain. I assume clockwise tightens it which I was trying to do to take the slack out.
Quoted: 3464 Post(s)
Liked 2,829 Times
Tighten the chain...
the B screw, closest to the axle will impart some "tightening" of the chain.
the majority of the chain tension will be in the jockey cage spring- those can wear out and essentially are a cause for derailleur replacement, springs possible to exchange, doubtful to find.
Likes For repechage:
Quoted: 3511 Post(s)
Liked 2,926 Times
The B screw (the one farthest to the left in your photo) is not used to adjust chain tension. It’s to adjust the distance between the jockey wheel and the cogs. If your derailleur isn’t tensioning the chain properly, it’s probably time for a new one (unless you can get a spring and feel comfortable replacing it).
Quoted: 92 Post(s)
Liked 20 Times
It seems ok now. No performance issues except that the chain goes off gear too easily when shifting to least tension.
Also I have been using chainsaw oil for lubrication, which is a big improvement over the WD40 which is more or less a solvent.
