View Poll Results: Do you tire sweep?
Never heard of it.
15
26.32%
Do it all the time.
33
57.89%
Way too dangerous for me.
10
17.54%
Does it require a duct pan too?
2
3.51%
Multiple Choice Poll. Voters: 57. You may not vote on this poll
Does anyone still ‘sweep’ a tire?
Quoted: 2488 Post(s)
Liked 2,957 Times
A wise bike shop customer once remarked to me, "It's not the ones that you see that get you." He was right. In all my decades of riding, I can remember only one time when I flatted from glass that I saw coming.
Beat me to it! My Super Six has much less clearance than the Merckx as I found out😳my thumb got squished when it got grabbed. Lesson learned.
Likes For waters60:
Yes. Old habit from ridng tubies in the 70's.
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,872 Times
Used to do it, but modern tires and tight rear triangles.
Quoted: 6196 Post(s)
Liked 4,811 Times
Your answers almost had me not answering your poll. However I thought about it and yes, if I run over broken glass or anything that might have stuck in my tire reach down and scrub it off while riding. But that doesn't happen very often so through out a season of riding I can probably count those times on one hand.
I tend to do the front tire first, but thinking about it the rear tire has more weight on it. So maybe I should do the rear tire first.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Not anymore. It didn't seem to help (would regularly get flats shortly after riding through stuff that I swept). Someone once wondered aloud if doing so could even push the item further in the rubber than way rather than letting it just fall off.
It's like riding a bicycle
Likes For urbanknight:
I have never heard of that. I figured making a cringy face and pedaling softly was enough to prevent a puncture when I come across some roadside debris. It’s worked so far!
I am not the most careful person out there. I can hurt myself lubing my chain. So no, I won’t be reaching down and sweeping my tires while in motion. And unclipping and using a foot? I imagine that would end badly as well. But bravo to all of you who can do it without hurting yourselves and make it look easy!
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2586 Post(s)
Liked 5,648 Times
Sorry, no occasional sweeps allowed. It’s similar to being kinda pregnant. Either you are or aren’t. No wishy washy sweepers in this pole. Sounds very Jerry Seinfeld when I think about it.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 4806 Post(s)
Liked 3,932 Times
The place to put the rear is the chainstay bridge. Aimed down. Bike says clean. And yes, most framebuilders do not provide a hole on the bridge for that bolt. That takes what,+ 5 minutes to drill while you have it in hand to miter for fit? My TiCycles have that bolt hole. I doubt Dave Levy was thinking glass catchers and I haven't done it yet but they are there.
Liked 2,979 Times
Likes For Troul:
I think they’re still available from Rene Herse.
EDIT: yep
https://www.renehersecycles.com/shop...s/tire-wipers/
EDIT: yep
Liked 3,932 Times
(From the Renee Herse website https://www.renehersecycles.com/shop...s/tire-wipers/
The before and after shots. Don't let anyone fool you. They aren't pretty very long.
Likes For 79pmooney:
Quoted: 768 Post(s)
Liked 1,747 Times
Not while rolling unless I could hear it, typically I would do it before and after a ride. I use a old piece of hosiery that my wife was getting rid of. I cut some of it up, and put it in my seat bag. I might not catch everything with my hand, but that material will grab onto the tiniest sharp object. Have not had a need for it in a while since moving to tubeless personally, but I did use it not too long ago when helping a lady on a MUP that had puncture 2 tubes and I found a small wire that cause the issue on the inside sidewall of her front tire. Been using this method for about 15 years now after I nicked my fingers on a piece of glass after I got a flat.
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Quoted: 4236 Post(s)
Liked 2,949 Times
EDIT: yep
EDIT: yep
Thread Killer
Quoted: 3148 Post(s)
Liked 1,714 Times
Interesting you should ask, because while I don’t think I know anything about that specifically, I do have a vague recollection of learning about them in the context of boutique, special production, but I was thinking it was to do with Bob White or maybe some Japanese retro-touring group.
So short answer: I dunno! 😉
Liked 2,949 Times
I know I bought some from someone here on BF and I thought that, at least at one time, they had also been supplying them to Rene Herse. Maybe that changed if they couldn't keep up with demand, or maybe they still are, or maybe I'm just misremembering the whole thing. Will have to see if I still have the envelop at home (I think I bought a spare pair or two in addition to the pairs I mounted). I do remember taking one of the bikes with them on it to the shop and the mechanic asked if they were just there as noisemakers or what.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Yes, it was rootboy. As all models are out of stock at RH, I don't believe anyone else has stepped up to make them.
Absolutely. I've seen objects stuck in the tread of the tire, that had not yet caused a puncture. Removing it avoided the flat. I like to keep my tread free from dirt/sand/debris so can find myself doing this often. Light pressure from fingertips is usually sufficient.
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
had those on my Zeus
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
pan y agua
Liked 728 Times
I learned that lesson the hard way. Skidded to a stop but stayed upright
pan y agua
Liked 728 Times
Used to, sporadically, over the decades. Stopped when I read the late Jobst Brandt's dismissal of the practice as being nonsensical. Rate of flats unaffected either way.
Since I switched to riding 28-mm tires, flats have occurred far, far less frequently. Once a year, maybe.
