Shimano M525 Rear Hub Set-Up
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1301 Post(s)
Liked 942 Times
I just re-packed it, and it's binding tight when I tighten the locknut (I'm working from the drive-side. I think I have part #10 in this exploded diagram, Right Hand Seal Ring in the wrong position. One problem is that the diagram shows this part facing outward, and I am almost certain that it faced inward (with the seal toward the hub), when I took it out. Another thing is that the diagram does not show the two rings that go inside this seal, one metal ring with a rubber ring within. The rubber ring is different on both sides, and therefore, can be installed two different ways.
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
Quoted: 5847 Post(s)
Liked 2,680 Times
Generally seals of this type are installed lip side out so any outside pressure would tend to tighten the seal.
On that hub, they should be mirrored with the lips both facing away from the freehub body.
BTW, don't forget to apply a grease film to the back one to avoid dry friction.
Likes For FBinNY:
Bike Sorceress
Bikes: Yes
Quoted: 62 Post(s)
Liked 116 Times
Some pictures of what you actually have would help. The diagram certainly has it right on what it is supposed to look like, including the orientation of the seal.
When you tighten the locknut, are you using one wrench on the locknut and another wrench on the cone at the same time? If not, only tightening the locknut will cause the whole hub to tighten up, and this is true for any cup and cone hub. Best practice with a freehub is to lock the driveside cone and locknut against each other, then do all of the adjustment on the non-driveside, as some freehub bodies will obscure the driveside wrench flats for the cone when properly adjusted.
Freehub seals can be difficult to get into proper position without mangling them. If you have ruined yours, the easiest fix would be to get a new freehub body that already has the seal installed, and to leave the seal in place when overhauling the hub in the future.
Likes For Arrowana:
The version # should be printed on the hub shell in the center of the barrel under the Shimano print.
With the M525-A, the part #10 should have the inner lip facing outwards. The cone/seal unit should interface with it in that position.
Likes For KCT1986:
Standard Member
Liked 942 Times
That did it, all right..! Thank you very much. I had thought that by adjusting the cone properly on the drive-side and setting it, I'd be all right. Non-drive side from now on! I'm not too familiar with working on cassette hubs.
Standard Member
Liked 942 Times
You mention M525 but have the link to the M525-A, the 2 versions have different cone/cone seal setups.
Standard Member
Liked 942 Times
Liked 2,680 Times
You're expecting too much. They're not intended to totally prevent water entry. Just to improve resistance to dirt and water spray.
FB
Chain-L site
FB
Chain-L site
