Clearcoat over new decals? Or new decals over clear coat?
FOOD FIGHT !!
Location: (Faber College) Over? Did you say over? Nothing is over until we decide it is! Was it over when the Germans bombed Pearl Harbor?...Hell no!
I'm stripping, and repainting an old Schwinn cruiser. After all the painting is done, should I spray the clearcoat over the new decals? Or apply the decals after the clear coat?
Thanks!
Thanks!
If you are going to ride and use the bike alot I think the clearcoat should go on after you apply the decals. No expert, just the way I would do it.
mouthbreather
Bikes: all of them
if ya want it to look cool, decal under clear coat. if your going for an accurate restoration, decal on top of clear coat
Quoted: 2026 Post(s)
Liked 1,096 Times
One thing to test if you clear coat over the decals; be sure the clear coat won't damage them. Some decals can be softened and disolved by the solvent in the clear coat.
It really depends on the decals. I clear coated over some nice thin Italian water slide decals with great results, but some of the "decals" being sold are vinyl reproductions. They can be slightly thicker and since they're vinyl, might not allow the clearcoat to bond to themselves. I'd put those types on after the CC. Use the Search feature and you will find plenty of info on this. Check out Dr. Deltrons posts too.
FOOD FIGHT !!
I suppose if you are going for a really accurate restoration, you don't use a clear coat at all, just paint.
Professional Decal Maker
Bikes: Giant MTB, Fuji beach bike
Clear coat away.
Vinyl, water transfers and most other decals can be clear coated with out any problems. It is all in the technique. PM me for details. JR.
Bikes: 1979 motobecane fixed, 2002 GT LTS-3 street stomper
Exactly. I've got some water transfer replacement Schwinn decals. I just wondered if the clearcoat was sprayed over them, it would cause them to bubble up or something? As for accuracy, it's about a 25 year old cruiser that has faided paint, and some rust. It's going to be for my daughter who just started high school, not going to a museum or anything, just want it to look clean.
I learned this trick from an old sign painter: leave the water transfer ON the card, do not cut out the edges yet (if you even need to as some are precut)
now LIGHTLY, and I mean LIGHTLY spray a super mist coat of POLYURETHANE clearcoat (spraycan clearcoats NOT recommended) on the surface of the decal on the card, let dry for a half hour, now another super light coat, and let dry again for another 30 minutes, repeat about four times.
now cut out the decal and stick it in the glass of water and apply to the surface
and let dry for at least 24 hours,..when you paint over that decal, it already has a protective clearcoat on it!
slick trick especially if you get some super old NOS decals that are cellulose based (those melt INSTANTLY if you apply a wet coat over them)
