Bike stands - one to avoid, one I like.
Bikes: Giant Cypress DX
Quoted: 246 Post(s)
If you don't already have a bike maintenance stand and were thinking about getting one *don't* be tempted by one of these. Goes by different names depending where you find it but by any name it's junk. I thought it might be a clever alternative design - nope. The picture of it is sheer false advertising. Maybe it'll work with other bikes but my Giant Cypress DX won't sit on the stand as the picture shows - i.e. with the crank housing neatly in the mounting area - which is 4 raised plastic tabs protruding out of a plastic base - the balance is all wrong for it to do that. It tips forward at about a 45 deg angle and sits with a part of the frame forward of the crank housing resting on the mounting area and the only way it'll sit on the stand at all is with the front tire resting on the support leg. The image of it sitting parallel to the ground the way the "ghosted" image shows is pure fantasy. Never going to happen, at least not with my bike.
Amazon.com: Gudcraft Bike Stand Bicycle Stand Repair Stand Rack with Tray: Home Improvement
The J-hook stabilizer is attached to the stand with a very light gauge spring and on mine the nut to tighten the J-hook down doesn't even fit the threads on the J-hook - it just slides through with minimal pressure. Even if it held the frame tightly enough to keep the bike from sliding I wouldn't trust it. And it's far more awkward to put the bike on this than with the clamp-on style of stands. Further the bolts holding the blue plastic mount in place interfere with the front gears on the crankset. It's a dumb, kludgy design.
Got one on Ebay, they gave me my money back and didn't require me to send it back. I've now got a modern art sculpture, useless as a bike stand.
Then I got one of these. Excellent design, works great.
Amazon.com : BIKEHAND Cycle Pro Mechanic Bicycle Repair Stand rack Bike : Bike Workstands : Sports & Outdoors
Quoted: 2026 Post(s)
Liked 1,096 Times
My first repair stand was a Minoura similar in concept to the first picture you posted. It also supported the bike by the bottom bracket and a J-hook over the downtube. It was dreadfully unsteady and a pain to work with. I then bought a Feedback Sports Ultimate stand and have never regretted it.
Custom User Title
Bikes: Fuji Roubaix Pro & Quintana Roo Kilo
Quoted: 2863 Post(s)
Liked 31 Times
Maybe the ghosted image is showing how it will quickly slip out of position and unto the floor?
Quoted: 246 Post(s)
The clamp style is the way to go.
Liked 1,096 Times
I always put a dot of bright nail polish on my seatpost just at the top edge of the seattube or collar. It's a depth gauge that always lets me reinstall the saddle at the correct height.
Quoted: 246 Post(s)
The concern I'd have with clamping the seat post is because of the balance on the bike is it seems it would put a lot of stress on the seat post.
Bikes: Schwinn Continental, Schwinn Paramount, Schwinn High Plains, Schwinn World Sport, Trek 420, Trek 930,Trek 660, Novara X-R, Giant Iguana. Fuji Sagres mixte.
Quoted: 35 Post(s)
Liked 22 Times
Why do you say don't clamp the top tube? Even the pics on virtually every bike stand show that as one of the ways to hold the bike.
I wouldn't worry about clamping the top tube unless you have a carbon fiber bike. You can do some googling and find plenty of people that have cracked their top tube buy clamping it with too much pressure.
+1 on the Feedback Sports Ultimate stand, Had a lesser Feedback 1st, then traded up to the Ultimate. I like it more every time I use it.
Bikes: 2012 Trek DS 8.5 all weather hybrid, 2008 LeMond Poprad cyclocross, 1992 Cannondale R500 roadbike
Quoted: 5888 Post(s)
Liked 3,472 Times
Yep but if you're careful, clamping a bike on the top or seat tube with a steel bike is no big deal. Seatpost is better for that reason alone but I've clamped my steel bikes literally hundreds of times on the seat or top tube with no problem. Decals can be a problem though.
Clamps on stands are like quick release levers -- small movement, incredible pressure.
In the shop, the only time I've ever clamped a seattube is when the seatpost is stuck; I have never, ever clamped a top tube, nor will I.
You do what you want; take the advice of a well-meaning mechanic or not.
I picked up a floor model of the Feedback Sports Pro Elite stand, it came with a tote bag that's still in the plastic wrap because the stand is always up. Easier to do routine maintenance when the stand is always available.
The only thing that could possibly be better would be a shop stand permanently mounted to the floor of the garage, and then that wouldn't exactly be portable...
mconlonx, any reason to use the seat mast adapters for carbon seatmasts/seatposts or should I just watch the amount of clamp pressure?
Quoted: 1529 Post(s)
Liked 718 Times
The order is seatpost, seat tube, then top tube if neither of those are possible.
Not unless the bike's a complete tank, and anyway, 99% of the time I point the bike down so the head tube is a tad past vertical and the bars don't flop around. This puts a lot more of the bike's weight below the clamp, also making for more stability.
Not many reasons to have the bike horizontal in the stand.
Which is why, when clamping anything halfway vulnerable, it's best to have the cam closed when it's loose and use the thread to tighten the clamp.
No biggie if you're clamping the seat tube where the seatpost is inside it, IMO.
Also, a soft rag (nothing synthetic) is useful to prevent marring decals.
Bikes: Airnimal Chameleon; Ellis Briggs; Moulton TSR27 Moulton Esprit
Quoted: 3291 Post(s)
Liked 827 Times
You could damage the paint. You could damage the decals. You could dent the frame. And in the case of a carbon bike, you could crack the frame. Easily. It's bad practice. Your concerns about clamping the seatpost are unfounded; my concerns about clamping elsewhere are backed up by training and experience.
It's bad practice as has been said and if you are in the business of repairing customers' bikes it could prove a very costly business.
Every reason in the world to use seat post adapters. If you're careful, you might get away without using them; in the shop we have them and use them. If I had a carbon bike with a seatmast, I would get the seat post adapters. Cheap insurance.
