Quickest floor pump?
Quoted: 206 Post(s)
Liked 38 Times
I have a Bontrager Turbocharger HP pump - it works okay, I've always felt it requires a lot of strokes to get the job done.
Is there something that's famous for being the quickest floor pump?
Thanks!
-Edit- ideally something that's in current production that can be bought new.
Thanks!
Quoted: 4208 Post(s)
Liked 3,874 Times
Out of production- Zefal Double Shot, the blue one. Pumps on both the up and down strokes. Andy
AndrewRStewart
AndrewRStewart
Half way there
Quoted: 986 Post(s)
Liked 880 Times
From the Trek site:
The diameter and stroke distance of the pump define its performance; everything is a tradeoff. Pumps that have an easier stroke require more of them, while pumps that push a lot of air each stoke require more effort per stroke. Pumps that support high pressures (e.g. your pump and most road bike specific pumps) tend to be in the former group because once you get above 80-90 psi, the force per stroke becomes considerable.
If you want to inflate faster, look for a pump designed for mountain bikes, but keep in mind that pressures over 80 psi will be a workout.
Turbo Charger HP gets you on the bike with the right pressure faster with a piston bore customized for easier high-pressure inflation
Likes For Moe Zhoost:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
You gotta have a serious lack of free time if you're looking for a fast pump.
Likes For cxwrench:
Palmer
Quoted: 1669 Post(s)
Liked 1,825 Times
I'm always shocked at how much quicker my Zefal Alaskan dual-stage pump gets a tire to pressure vs. the single-stage floor pump I have - like >25% of the strokes. The catch is you have to work the pump handle both down and up. The Alaskan has been discontinued.
The Topeak Twin Turbo is another dual-stage pump.
Note 1: Topeak offers other floor pumps they advertise as dual-stage, but they are really two-mode pumps.
Note 2: If I'm at home, my air compressor inflates much faster than the Alaskan.
Likes For tcs:
Quoted: 1438 Post(s)
Liked 1,092 Times
The tradeoff for hand pumps is pressure vs volume; a high-volume pump may not be able to achieve sufficient pressure.
Likes For dsbrantjr:
Quoted: 540 Post(s)
Liked 416 Times
If this is something you only plan to use only at home, you may want to think about a shop compressor with a Park Tool INF-2, believe me nothing will be faster.
On roadtrips, I'm happy with whatever I packed last minute and threw it in the van.
Likes For soyabean:
Quoted: 206 Post(s)
Liked 38 Times
From the Trek site:
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Yep, probably. You'd likely spend more time searching for a marginally faster pump than you're spending using your current pump.
Palmer
Liked 1,825 Times
This is different from the dual stage pumps I mentioned in post 5, where the large diameter cylinder supercharges the small diameter cylinder which in turn pumps into the tire.
Quoted: 540 Post(s)
Liked 416 Times
The OP may not realize atmospheric physics is in play, and no magic manual pump will create free energy.
Human power watts going in makes air pressure and cfm volume coming out. There's little to cheat around that.
When it comes to a dedicated air compressor for just bikes, any tiny oiless one will do, like the pancake ones for nail guns. Your local Harbor Freight store can have them on sale below $50, watch those flyers. Or buy used.
You don't need something fancy as the INF-2, it's more of a showoff piece to impress walk-in customers. The simple tire chuck included with the compressor is fine and is how folks have been doing it for the past 100 years.
Don't confuse air compressors, which store readily air in a tank, vs air inflators, which create tiny pulses of air on the fly and are god awfully slower than a manual pump.
Once you get your first air compressor, you realize all the other neat things you can do with it, like blowing water away off cassettes and chain for quick dry.
Palmer
Liked 1,825 Times
"Is there something that's famous for being the quickest floor pump?"
A true multi-stage pump is demonstrably faster.
Back, oh, a hundred years ago or so, if your Model T had a flat, you patched it much the way we patch tubed bike tires today. Then you pumped the tire back up to pressure. Model T tires don't have the volume of modern car tires, but they have significantly more volume than bike tires. Pumping them up by hand (on the road, in the 1920s) took a while, so pumps were introduced to speed the process. Here's a Victor 'Half-a-Minute' triple-stage pump of that era:
Likes For tcs:
Palmer
Liked 1,825 Times
In the old days, we'd put a few drops of Neatsfoot Oil down the barrel to keep the leather gasket soft, pliable and efficiently sealing on the downstroke. If the leather gasket dried out, the pump would become quite a bit less efficient due to 'blow by'. Dunno about Bontrager or synthetic seals.
Quoted: 540 Post(s)
Liked 416 Times
My answer gives more options for the DIY that wants the absolute fastest and easiest that is also realistically possible for all wallets.
Nothing beats a shop compressor, the INF-2 is proof.
Quoted: 206 Post(s)
Liked 38 Times
Topeak has a double-barrel pump. You use both barrels to quickly pump to relatively low pressures with low effort, then lock out the small diameter barrel to pump to moderate pressures, and finally open the small diameter barrel and lock out the large diameter barrel to pump to track pressures.
Palmer
Liked 1,825 Times
Quoted: 206 Post(s)
Liked 38 Times
I have a small like 2 1/2 gal or so Harbor Freight compressor I use to inflate car tires but you have to fire it up, wait for it to pressurize to bike tire pressure - an overall slower process. Plus the neighbors aren't going to be happy if I fire it up for a wee hours ride
Quoted: 540 Post(s)
Liked 416 Times
I have a small like 2 1/2 gal or so Harbor Freight compressor I used to inflate car tires but you have to fire it up, wait for it to pressurize to bike tire pressure - an overall slower process. Plus the neighbors aren't going to be happy if I fire it up for a wee hours ride
senior member
senior member
Was having to strain to get to 100psi with my floor pump - just got the Park INF-2 and a Craftsman 1 1/2 gallon compressor and now achieve that pressure in seconds - couldn't be happier - fortunately I had an 8mm hex to open the presta side on the Park inflator to take the valve - I'll use CO2 on the road but that only gets me to about 80psi and will have to top up when I get home .
Likes For blinky:
Quoted: 540 Post(s)
Liked 416 Times
I am happy that you are happier
Despite how happier you are, there are just some folks that are just never happy and complain.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
I have a Bostitch 6 gallon pancake compressor at home, but using it would entail unwinding and winding a hose, so a floor pump is still faster (for bikes).
Maybe this will change when I install a hose reel.
