Bearing Size
Bearing Size
The bottom bracket bearings on my 3 year old grandaughter's kiddie bike have disintegrated. Can anyone tell me what size the replacements would be. Or tell me how to measure them. There is nothing left of the original bearings to actually measure though.
I have a thread on here of when I had to sort out her rusted chain. And here are some pics:
Quoted: 332 Post(s)
Liked 740 Times
Without seeing it in person I’d guess this is the “juvenile” size 1 piece bottom bracket:
https://www.modernbike.com/sunlite-m...racket-cup-set
Likes For bboy314:
Quoted: 837 Post(s)
Liked 1,061 Times
Not sure if this is relevant for your granddaughters bike but check this article. One-piece ("Ashtabula") Cranks (sheldonbrown.com) If you have any bike shops nearby they could probably tell you and bearing balls are cheap, even at bike shop retail prices. Just bring in the crank and races.
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
99% chance they are 1/4" balls
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
^This^
Thanks, Crankycrank. I saw that Sheldon Brown article.
Mudpie - there were balls remaining. The cages were destroyed but there were 14 balls. Which seems an odd number. So there may be some missing. The balls were 8mm which seems to cnvert to 5/16".
I have ordered a couple of 5/16" bearings with an outer cage diameter of 38mm. The diameter would seem to fit the shell. So I will see how I get on with that.
Likes For bboy314:
Quoted: 3511 Post(s)
Liked 2,926 Times
Isn't that bike getting pretty small for her at this point?
Errrm, not sure what you mean? But no. It was her sister's and was in one hell of a mess when it had been left in the rain. I worked on it last year to make it ready for the wee one when she was big enough. So she started to use it not that long ago. She is coming up for 3.
Quoted: 114 Post(s)
Liked 119 Times
I assume you could install the bearings without cages, too. Cages make it easier, but the grease will retain the balls during assembly and installation.
Likes For MudPie:
It would be really tricky, I think, Mudpie because of the one piece crank. But I didn't think of trying that.
Quoted: 4205 Post(s)
Liked 3,864 Times
It's been my experience that fully loose balls in an "Ashtabula" type BB don't hold their place WRT the other balls and the ball tracks on the cone and cup. I suspect it has to do with the bearing load/contact angle, the size of the balls for the above and the amount the cup and cone "cradle" the loose balls. 1 piece BB's have fairly shallow cups and cones that are often conical and not 3D curved. Still trying fully loose balls will be a good exercise in learning and working with stuff. If it works with the parts you have that's great. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
SE Wis
Liked 3,395 Times
Likes For dedhed:
Liked 3,864 Times
The pressed in cup (the silver thing in the BB shell that also is securing the white chain case inner piece) is as proper as it needs to be. What can be confusing is that the relative parts are in an different order when compared to a threaded shell running a loose ball BB. Andy
AndrewRStewart
AndrewRStewart
