Looking for a Waterproof bike cover that still lets me lock my bike
So, during the pandemic, I’m locked down at a place that doesn’t have a garage or much space to hold my new bike and will need to secure it outside. But I’m worried about what the weather might do to it. Is there a cover people could recommend that does the job but still allows me to lock it up against a bike rack?
I have the Electra cover below. You can place locks of your choice on the bike, put the cover on and then a lock through the 'lock holes' and rack. I bought mine from REI but I'd presume that it's available from many other sources.
Good luck.
https://www.rei.com/product/136954/e...-bicycle-cover
Good luck.
Quoted: 722 Post(s)
Liked 353 Times
thanks
Quoted: 608 Post(s)
Liked 352 Times
I guess you can't comprehend the 10th to the 15th word in their sentence, all in the name of what I suppose you think is funny.
MAK posted a decent looking bike cover that looks quite promising. I do use bike covers but I purchased mine in Japan, so not easily gotten in America. They work well enough but the Electra one looks better. Good luck with finding something that fits your needs. Keep safe.
Likes For blakcloud:
Quoted: 2604 Post(s)
Liked 1,933 Times
Locking the bike isn't hard. You'll need something solid to lock it to, and if you're going to leave it outside for long periods of time, get a 6-8' logging chain with a darn good lock.
You can cut holes in something like https://www.universalcycles.com/shop...ls.php?id=7963 for the chain to thread through. With luck you won't have high winds to rip the cover off. I don't see why you need car and bike rack to use https://www.bikeman.com/AR8809.html; lock the bike up, put the cover over the top, and snug down the straps.
Quoted: 2485 Post(s)
Liked 2,956 Times
Waterproof covers have the disadvantage of trapping moisture, which can sometimes cause more damage that would occur with an uncovered bike. Whatever you do, consider spraying all the vulnerable surfaces (seatpost/frame interface, stem/frame interface, etc., but not brakes and rims, of course) with WD-40.
Quoted: 5224 Post(s)
Liked 3,585 Times
getting some use out of my rain cover. it has a cpl large grommets at the bottom for a bike lock
Puroma Bike Cover Outdoor Waterproof Bicycle Covers Rain Sun UV Dust Wind Proof with Lock Hole for Mountain Road Electric Bike
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Depending on your locale, UV light may cause just as much damage as water or humidity. Can you put up a small plastic shed into which your bike can fit and be locked?
Likes For Phil_gretz:
Clark W. Griswold
Quoted: 4358 Post(s)
Liked 3,996 Times
Humidity can really cause some damage to a bike so try and keep it indoors whenever possible. If really desperate try the shed idea and use some way of removing moisture and still lock it in the shed.
Quoted: 18424 Post(s)
Liked 15,573 Times
Likes For indyfabz:
Liked 3,585 Times
thanks mine is only outside for a cpl days. but I was also thinking about bugs & amphibians. I'll probably wind up w/ spider webs & little frogs in there somewhere
