lock-wire safety bolts for disc brake mounting
I'm building up a frame which has disc brake mounts. I see that Shimano sells, for its flat-mount disc brakes, mounting bolts that have been drilled through the head so they can be secured with lock-wire to prevent loosening from vibration. Is there something about flat-mount specifically that causes the mounting bolts to loosen or is this an issue generally with disc brakes regardless of the mounting type?
novis rebus studentem
Quoted: 714 Post(s)
Liked 800 Times
I've never used any of Shimano's brake mounting bolt security devices and I also have never had a brake mounting bolt come loose. I don't see anything about flat mount in particular that would make it more prone to loosening from vibration. I don't really like them, because its a pain to blindly reach under the chainstay to adjust the brake caliper, but its where the industry has gone and we have to live with it.
Quoted: 427 Post(s)
Liked 339 Times
Never used or even seen them used. I have seen caliper bolts that were loose, but I suspect they were just never tightened properly in the first place. Thread lock is a great answer and miost mount bolts have thread lock alreaduy applied to the threads.
Likes For timo888:
