Are cheaper tires robbing your frame's ride quality?
Quoted: 55 Post(s)
Liked 57 Times
After a lengthy rebuilding, polishing, and respoking of a particularly nice Rigida 700 wheelset from the early 80's, I've decided to keep them on the bike with such a nice finish and buttery smooth Suzue hubs. Since they're unhooked rims, I went the safe route of mounting wire beaded Paselas (28's), from a fear of tires blowing or rolling off an almost 40 year old bike, landing this almost 60 year old into an ER. The ride is "okay", but I suspect the best of this 531 frame would come out on more supple tires. I've thought of Compass-Rene Herse and others, but they all seem to be of the folding variety. I'm assuming, correct me please, that the wire bead on the Paselas might hold a tighter circle and be less inclined to blow or roll off. I'm only running them at 80 psi rear and 70 front anyways.
Can anyone suggest a wire beaded version of something better than the old Paselas in a 28-32 max width? Or have you just mounted folding beads on unhooked rims with no issues? It does seem like a waste to run these beer tires on champagne frames, or maybe it just doesn't matter.
Thanks in advance!
Thanks in advance!
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
I'm not sure about all that as I've never run hookless rims, so I'm here to learn a bit myself. I will say I would imagine some tubeless ready folding tires could work out. The sets I have were/are exceedingly tight to seat and stay that way. Unless you're pulling them on and off frequently and they stretch. And, I suppose it would be contingent on the rim since actual rim diameter fit can vary a tad
Anyway, I do recall in threads past mention of this very issue and, IIRC, wire beads are suggested. Grain of salt....
Cyclist
I'll let those more knowledgeable answer your second question, but as for your first I can say they absolutely are!! My Surly Cross Check on Compass tires rides much better than the 531, Prestige, etc frames I've ridden with Paselas.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
I've always liked Continentals for good value and ride in a wired bead. They will never equal the quality of great tires on hooked rims but they are still fun. All bikes are fun.
Likes For clubman:
Quoted: 767 Post(s)
Liked 1,898 Times
Wire bead is the safest bet on hookless rims, and as far as I know the Pasela is about as good as you'll find. At its price point it is a good tire. If you want to run higher end tires with folding beads and more supple casings, ditch the hookless rims.
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
...my experience, and it includes many years off riding, rebuilding wheels with newer rims, and experimenting with various tyre brands on my own bicycles, which are many, leads to this advice: if you are interested in ride quality, toss those period correct hookless rims and rework your wheels using at least a Sun or better quality rim.
One of the reasons the olde guys here are so enamored of glue on tyres and rims is because of their inherent lightness. Another is the higher pressures you can run with tubular tyres, because they won't blow off the rim. You couldn't approach that with clincher tyres at 60-70 psi and alloy rims in the early days of hookless rims. You can get a lot closer nowadays. So you kind of need to choose which is more important to you. the top quality tyres today are all designed with hook bead rims in mind.
Quoted: 1163 Post(s)
Liked 442 Times
What is the casing thread count...
...on the wire bead Pasela’s? Just curious.
In an ideal world I would 2nd what others have said about re-lacing the wheels with modern rims (that still have the look you are after).
But to improve the ride of the 700c Rigida/Pasela combo you could experiment with latex inner tubes & also using thinner (tubeless type) rim tape. The tubeless rim tape will permit a bit more interior volume and the latex tubes can be very palpable with high thread count clinchers. With your wire bead tires it is possible that the casings are just too dead to let the latex tube increase road feel or cornering precision. I would do the front wheel with this treatment then road test it to see if you can feel a difference.
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 387 Post(s)
Liked 692 Times
Just curious, which pasela's have you tried? In my experience, the paselas with the ProTite protection layer tend to have a slightly stiffer feel than the regular non-PT (red label) paselas. Also, what pressure are you running on those 28s?
I've had the 27 x 1-1/4 non-PT wire-beaded paselas on a couple bikes and they ride reasonably well.
Likes For panzerwagon:
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 698 Times
And I thought I was styling on my paselas after upgrading from decades of Kendas. Oh well.
Likes For sd5782:
Quoted: 4560 Post(s)
Liked 2,802 Times
Continental Ultra Sport II are available in wire and folding bead versions and both are very snug fits -- you'll want a bead jack to mount them.
Pretty good ride for inexpensive tires too, much better than other low priced tires I've tried such as the Vittoria Zaffiro. The Conti Ultra Sport is durable, reasonably puncture resistant considering it has no special puncture shield, and retains reasonably low rolling resistance at lower than maximum pressure. And there are a few choices in sidewall stripe colors.
Continental hasn't offer much specific info about the newer Ultra Sport 3 but it appears to be the same tire with a slightly different tread pattern.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Pretty good ride for inexpensive tires too, much better than other low priced tires I've tried such as the Vittoria Zaffiro. The Conti Ultra Sport is durable, reasonably puncture resistant considering it has no special puncture shield, and retains reasonably low rolling resistance at lower than maximum pressure. And there are a few choices in sidewall stripe colors..
Otto
Quoted: 583 Post(s)
Liked 698 Times
As an aside, on my limited perspective of weinmann rims on the old Schwinn, I NEVER had problems with the non beaded rims with Schwinn approved cheapies and Kendas. In my youth I even put 85 lbs in them like the sidewall said so that I could feel fast. I never had trouble. I was about 170lbs then just like now. I even loaded the old Super Sport down for a circle Ohio ride in 1980 with 25-30 lbs of gear on the back on a plescher rack with no problems. Perhaps those old Weinmanns were a good match.
I blame this thread for the Rene Herse Bon Jon Pass tires being sold out when I finally got around to buying them this morning XP
Current project: 1976 Motobecane Grand Record restomod
Quoted: 170 Post(s)
Liked 264 Times
Supple tires on modern rims would transform your ride experience. If you can fit 32s, go right to the king of tarmac (and light gravel, in my experience): Conti gp5000s: more durable casings (3/330), less $$ and rolling resistance than RH offerings: https://www.bicyclerollingresistance...000-comparison
Quoted: 387 Post(s)
Liked 692 Times
It’s amusing to imagine a horde of C&V’ers descending upon their website, triggered by the slightest whiff of discontent on the forums with alternatives. Yet another reason why we need a volatility index for C&V parts.
Quoted: 930 Post(s)
Liked 1,292 Times
+1
Quoted: 170 Post(s)
Liked 264 Times
I shared the link merely to point to the rolling resistance data for GP5000s. My comparative opinion vs RH tires is based on personal experience over many miles. I was initially skeptical of BRR's lab methodology, but have found their drum and durability results map over well to real life.
Likes For ctak:
Bikes: 1981 Bianchi Specialissim, 1976 Colnago Super. 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1
Quoted: 276 Post(s)
Liked 952 Times
Thanks in advance!
Thanks in advance!
Mike
Quoted: 1639 Post(s)
Liked 829 Times
Most of the time, ride quality of the tires is proportional to the price you paid for them.
I did not really feel this that much till I experienced the difference between the Vittoria Rally and Vittoria Graphene G tubs I bought in the last few years. The Rallies made my bikes feel kinda numb and dead (still better than most clinchers I had ridden, but not that great), compared to their Graphene G version which made my bike feel much faster and livelier on the road.
I have not ridden clinchers for a while, but IIRC, the difference between tires of different prices wasn't as easy to feel with most clinchers.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,700 Times
There's that- and then going from Paselas to Compass/ReneHerse.
Commence to jigglin’ huh?!?!
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
Even in the Pasela line, I can feel the difference between the standard model and the one with the ProTite casing. I have two pairs of these, both in 700x38, and can feel the difference even when ridden on the same frame.
I certainly think more expensive (supple) tires would ride even nicer.
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
I've been kinda tempted to try wired Zaffiros, sine I found 32s for $17 at Cambria.
Better tires are well worth it!
Then I got my Miyata 710 (700c)...
When I bought it, it had a 22mm wire bead Zaffiro on the front, and something - I can't remember what - that was flat on the rear. I wanted a new 28mm for the rear, and all the LBS had was a Vittoria Randonneur II in that size. The ride was sluggish - I thought Miyatas were better bikes... hmmm...
Fast-forward a year, and I'm heading back out to AZ to ride the Miyata, and I was bringing along some 'upgrade' parts to fit my personal preferences (SunTour friction barcons, new cables, bar tape, dual pivot brakes...) as well as a matched set (actually TWO sets) of Vittoria kevlar-bead Rubino Pro Tech III. One set in 28, and another in 25. I opted for the 28s for a softer ride. Lucky thing I didn't try to go larger because a 28mm fit the rear just fine, but the front left only 1mm clearance between the tire crown and fork bridge! Oh, and I probably cut a pound and a half off the rotating weight. The former front Zaffiro had a thick 'thorn-proof' tube in it that was also filled with Slime. The Zaffiro and tube combo weighed MORE than BOTH sets of 'standard' tubes and the supple 150tpi Rubino Pro Tech III that include the puncture-resistant layer for the AZ thorns and also the steel-belted-wire from people that run the tires down to the cords in rainless AZ... The difference in ride feel was dramatic! Much more responsive and smooth-rolling than the stiff sidewalls of the Zaffiro/heavy tube or the heavy Randonneur tire.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Off the bike, they feel pretty similar to a Pasela -- a bit thick (though less so on the sides), not terribly supple, but softer material than many other cheap tires.
I've read that wire beads themselves can contribute to a tire have a poor ride feel. That's tough to say because there just really aren't many (if any) high thread count tires with wire beads. Generally the tires with wire beads are pretty stiff to begin with. I guess maybe someone could compare folding bead Paselas to the wire bead version. Like everything with the feel of a bike, it's a huge pile of marginal gains. Good fit, good geometry, good build, good frame material, good rims, good tires, good tubes...they all make the ride better. Any one of them has to be pretty bad to make the ride bad.
My Bikes
My Bikes
Quoted: 2338 Post(s)
Liked 2,822 Times
I did not really feel this that much till I experienced the difference between the Vittoria Rally and Vittoria Graphite G tubs I bought in the last few years. The Rallies made my bikes feel kinda numb and dead (still better than most clinchers I had ridden, but not that great), compared to their Graphene G version which made my bike feel much faster and livelier on the road.
