7 speed freewheels are not all the same?
![WTF](images/smilies/wtf.gif)
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/df168d60_b328_4d9f_83bd_6af472b78cb8_4b18c9ea89889cc3b55bfbf0047a41230fb04d85.jpeg)
Ruler touching where frame contacts
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/62f7005e_c948_47d0_ad71_a7535eb9743e_73d7c24cdc76ccb8e83c7c0c2965181d0d0899f5.jpeg)
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/1c4be58a_bbd9_4571_b20c_816c227bfa77_d397a0733d1a971ea7d8f1aab9aeed92ee65e212.jpeg)
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Liked 329 Times
Why did you need a replacement freewheel? The Suntour freewheels were (and still are) the best ever produced. Your Winner isn't a bad unit at all, and almost certainly higher quality than the new replacement. The teeth of the Suntour look good.
As for a solution to your problem, the only thing you can do would be to add a spacer under your lock nut. This is going to shift your rim over a bit, so you'll have to dish your wheel to center.
working on my sandal tan
Liked 2,579 Times
Cantilever believer
It does look like the outboard lockring & body on the DNP does stick out farther than the flush end on the Winner, even if the cog spacing is 5 mm on both. The DNP might also protrude more on the inboard side of the freewheel, placing the mechanism farther out on the hub.
I haven't yet run into this problem myself, but I could see it occurring. I've run into a different problem where I swapped a 7 speed threaded freewheel wheel for a 7 speed freehub wheel and the old Suntour derailleur wouldn't throw far enough inward to engage the innermost (largest) cog even with the L screw all the way out.
The DNP freewheel is specifically known to be wider than other 7 speed freewheels. Just go with the tried and true Sunrace 7 sp freewheel.
