Going back to 23/25 from 28/30...?
#101
Quoted: 7653 Post(s)
Liked 3,485 Times
Anyway ... Unless @LarrySellerz shows up, I think this thread is finished .....
#102
Quoted: 1248 Post(s)
Liked 1,323 Times
Even if he could make two frames a day (which is less time than it takes to prepare and cook your thanksgiving turkey) from start to finish, including mitering, fork bending, fork assembly and welding, main triangle welding, rear triangle welding, welding of various braze-ons, frame assembly welding and finishing he has at least one quarter of a years production just hanging around the shop. Not including frames out for chrome, paint and shipping prep. No business could sustain itself that way. It’s all marketing BS. Probably safer to take this debate back to C&V and it’s acolytes.
That said, your Cinelli which you have posted many times is a very aesthetically beautiful bicycle.
#103
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,384 Times
Perhaps that is why I am such a cynic regarding these old lugged bicycles and the bizarre romanticism attached to them. I spent decades as a toolmaker and precision metal worker. The skill required to build a lugged bicycle is very basic and easily within the capabilities of a 6th month apprentice. That is why a vast majority of frame builders are self taught or have taken a basic frame building course lasting a few weeks. Someone with a strong mechanical aptitude can learn how to build a frame in a month or so which would be indistinguishable from these so called storied frame builders. Of all the steel frame building techniques lugged steel is by far the easiest to learn and the most forgiving. It also lends itself to batch production, main frame, rear triangle, forks then final,assembly. Nothing special about that at all.
I don't honestly get the comparison. Maybe you can enlighten me further on how your experiences as a precision metal worker translate to this other area of making stuff from steel. My limited experience with that stuff tells me that maybe you're not the best person to debunk Richard Sachs. But it's not something I've ever done, either tool and die machining, or bicycle frame manufacturing.
Friendship is Magic
Bikes: old ones
Liked 10,384 Times
Two quotes from the article:
"At Bicycle Quarterly, we’ve been researching tire performance for the last eight years, and the most revolutionary finding is this: Tire pressure has almost no effect on a tire’s speed."
Followed by: "On smooth surfaces like the one used in the tests shown above, moderately high tire pressure – say 100-110 psi for a 25 mm tire – actually rolls slower than either a lower pressure (80 psi) or a higher pressure (130 psi). On rough surfaces, higher pressures roll significantly slower."
If the supposed experts cannot help but contradict themselves in subsequent paragraphs, I would not trust any of the conclusions in the article. That is not science, that is journalism approaching fiction... which is great, but not informative.
Liked 1,323 Times
...so let me see if I understand ? You were a tool and die guy ? Or was it some other "precision metal working ? I need to know this to ask my next question, which will be how that possibly qualifies as a platform from which to judge something like frame building ? I mean, I've been a blacksmith and farrier doing production forge work for a while, back when I was floating around in various occupations. I can braze and I can weld. I have even done both using a forge (coal, not gas), instead of a torch. I even did a semester in college learning foundry casting, using sand molds.
Richard Sachs made very attractive frames to a discerning clientele which were beautifully finished but performed identically to others. As a frame builder gets more proficient he gets faster while retaining the same quality but the actual performance is identical. I find it bizarre on how gullible so many people are regarding frame builders, the input materials are identical as well as the assembly methods so the only differentiation is branding, finish and details which play no role in performance or reliability. Just look at these forums which has a frame building sub forum with over 50,000 posts, not a very rarefied group if you ask me.
Likes For Atlas Shrugged:
#106
Tire choice is based on where you live. If you live in a place with butter smooth roads (China, Singapore, Middle East, etc), you can close your eyes and there will be no discernable difference in road feel between 21s and 32s. At that point you simply choose the lightest tire, which will be the thinner one. If you live in upstate NY, you need 35s
Likes For Yan:
#107
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 570 Post(s)
Liked 773 Times
Wow - all over a few mm’s and PSI.
Lookie heere:
The performance, speed, ride qualities… between a Huffy and a high end bike are fairly significant.
the difference between stock heavy alloy wheels and a light set of CF deeper section wheels, fairly significant.
Gator skins and Gp5000’’s - little less significant, but makes a difference.
Most of the other things people argue about - not real significant.
23,28, 32mm - yer talking minute differences in speed, and minimal comfort. Much of it is personal preference. Even steel vs aluminum vs CF, good versions of each - minimal differences.
105 to dura ace, aside from your wallet, for the average rifer - minimal differences.
yet people will argue to the bitter end about these minimal preferential differences.
Lookie heere:
Likes For Jughed:
#108
Quoted: 6974 Post(s)
Liked 10,975 Times
True, and enough reason to enjoy it. No need to make up a fictional backstory or pretend that it's something that it's not - such as lightweight in any meaningful sense.
Likes For Koyote:
#109
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
SILCA BLOG PART 4B
#110
Quoted: 505 Post(s)
Liked 639 Times
I will run my cheapo 25s at 90+ PSIG on good roads until the day I die, and will defend anyone's right to ride whatever they want at whatever pressure they want for whatever reason they want.
#111
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
#112
Quoted: 3515 Post(s)
Liked 2,929 Times
#113
Friendship is Magic
Bikes: old ones
Liked 10,384 Times
This is bordering on idiocy. I spent 4 years as an apprentice toolmaker followed up with 15 years as a lead hand in a custom fabrication shop,which specialized in precision metal products. Medical instruments, aerospace, military and astronomy equipment as well as molds and dies. Often our products required welding as part of manufacturing and assembly which I was involved in. You have absolutely no clue if you think that brazing some lugged tubes together in a jig is challenging at all.
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,924 Times
The 25s I run on 8 out of 9 bikes are a whole lot comfier at 90/95 F/R than the 23s I ran at 140 psi BITD, but the 28s on the Canyon are comfier and faster EVERY TIME. Given the state of some of the pavement I ride, I'm thinking of running 30s or 32s. I wanted to swap the 28s onto the Litespeed, to make it slightly comfier, but when they built that frame in 1995, they didn't leave room for anything larger than 25s. 28s rub the underside of the brakes.
#115
Friendship is Magic
Bikes: old ones
Liked 10,384 Times
I've had a few exchanges with Jan over the years, asking him about his test protocols and methods. Jan has interesting ideas but doesn't do good experiments or analysis. Nonetheless, sometimes his ideas turn out to be correct. I (occasionally) read Jan's stuff to get ideas but it's often necessary to replicate his experiments.
Friendship is Magic
Bikes: old ones
Liked 10,384 Times
Originally Posted by G. Marx
I refuse to join any club that would have me as a member.
Quoted: 446 Post(s)
Liked 1,045 Times
I prefer 25c on my road bikes paired with 21mm internal rim wheels. My GP5k tires inflate closer to 27-28c with a slightly wider footprint, but without the added weight or sluggishness of actual 28c tires. I also prefer clinchers with lightweight TPU tubes, because they tend to be cheaper and easy to patch up. I've seen one too many road tubeless mishaps which required a car pick-up. For gravel I completely prefer wide tires and tubeless.
#118
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
...I think the only reason I went to that source was because, for a long time, way back when, it was Mr Heine at BQ who was the most published voice on wider/ lower pressures/ faster (in the popular cycling literature of the time). It's kind of wild for me referencing that here, and seeing it shot down as "non-science" in the same thread that has strong opinions about how that's the correct approach.
Likes For RChung:
#120
Liked 2,929 Times
But you would discount it out of hand either way.
#121
Quoted: 3241 Post(s)
Liked 2,512 Times
Annnddddd there's a thread recently started about the ride of carbon wheels. Let's see where that thread goes in relation to this one.
Likes For seypat:
#122
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2590 Post(s)
Liked 5,657 Times
”I’d rather fight than switch.”
”From my cold dead hands”
”Fugetaboutit”
”Fugetaboutit”
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
#123
Liked 2,929 Times
Just got back from a ride. Deflated my tires to the minimum: 100 psi, down almost 1/3 from my usual pressure.
A noticeably “less crisp” ride. No thanks. Back to 140.
#124
Friendship is Magic
Bikes: old ones
Liked 10,384 Times
...I thought about starting a thread about inflating my tires using helium. But every time I tried to type the OP, I started laughing hysterically at the sound of my squeaky voice.
Likes For 3alarmer:
#125
Quoted: 570 Post(s)
Liked 773 Times
my carbon wheels vs the stock crap that came with the bike - night and day different. The bike is a completely different machine.
