pedalpower quad tandem rental ?
tandem cyclist
Hi does anyone know if pedalpower rent a quad tandem bike ? They do make them and triplets but not sure about renting them out. https://pedalpower.de/tandems-triple.../classicsteel/
Quoted: 2504 Post(s)
Liked 745 Times
This is an almost insultingly low effort original post. Pedalpower appear to be based in Germany. Are you? If not, the answer is no. If yes, then, maybe. But probably not at their headquarters, but at select dealerships in the region. But, whether or not you are in Germany, the link provides ample means of contacting pedalpower.de so you can get the 411 first hand.
tandem cyclist
i dont deal with people over the phone because i have anxiety with doing it that way. no offense but your not much help i can see they have a phone number myself.
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
Also, while I don’t expect you to list any personal disabilities/limitations up front, if you are unable to use a common contact method and have already exhausted the others, that’s important to mention in a first post. At a minimum, don’t get insulted when people suggest the seemingly obvious things you didn’t mention.
Given that the supplier doesn’t seem interested I think your best bet is seeing if any of their dealers do rentals, unlikely as that may be.
Likes For jccaclimber:
tandem cyclist
ah it appears i messed up i used the wrong email address i emailed them if i get no reply i will have someone call them.
