Looking for hanger for my Suntour VG-T LUXE Rear Derailluer
Bikes: Miyata six-ten, Miyata Grand Touring, Univega Sport Tour, Univega Gran Turismo, 80's Trek MTB, 2008 Dahon Mariner
Quoted: 85 Post(s)
Liked 83 Times
Hello all,
I found three of these in local bike coop and no hangers to be found in the parts. If anyone has the hangers, hex nut and ideally, the shims, would be so happy to buy a couple to make these baby's work for the rebuilds of a five and six speed Centurion and Raleigh. I would be willing to trade one of the mechs (they are dirty but they are straight with pulleys in excellent condition) in trade for a hanger bolt and shims. If someone has hex bolt alone, PLEASE connect as I have several people already who have the hangers.
Thanks in advance. I am cross posting C&V general forums. If this offends anyone, let me know and I will have moderator remove post.
Cheers!
Nubra
This is the hanger I am looking for! Need the shims too
Cheers!
Nubra
Give thanks, for unknown blessings are already on their way.
~Native American Prayer
Quoted: 85 Post(s)
Liked 83 Times
YES indeed, I need the hexbolts as well. I wish I could figure out how to edit my post. Will try to contact moderator to see if they will do for me.
Car free since 2018
Bikes: Mostly japanese ones
Quoted: 259 Post(s)
Liked 269 Times
Reminds me of that short period of time that every time I found a Suntour derailleur in the coop's bin it was *always* missing the bolt. Why would they do that? Are they even interchangable? Drove me nuts.
Quoted: 85 Post(s)
Liked 83 Times
Making me nuts too. These are excellent mechs, in great condition. What a bummer!
Quoted: 1106 Post(s)
Liked 1,328 Times
If you are lucky enough to find the bolts but not any shims you may have a work-around - if there are sufficient threads of the bolt protruding you can use a 10x1 rear axle locknut on the inner side of the dropout/claw and set your clearance with it.
Quoted: 472 Post(s)
Liked 1,028 Times
Same problem with the shim washers. Fell off, swept up, tossed anywhere handy, and everywhere. "Where to we put these things?" "I donno, just toss it in that bin over there."
Nothing's changed. It still goes on today.
Car free since 2018
Quoted: 259 Post(s)
Liked 269 Times
For a time, RDs did not have anything to retain the pivot bolts, unlike later units that had snap rings or slotted nuts. So when an RD was dismounted the pivot bolt could and did fall out (like the Campy NR caliper cable adjuster bolts did). Unfortunately, I have found, there was no standard diameter nor length. So finding a replacement involved long searches through obscure parts bins and much luck. BTDT. And do not assume bike shops/co-ops binned things together. Those old pivot bolts are could be anywhere.
Quoted: 85 Post(s)
Liked 83 Times
Hey One Click, That is a handy work around. Thanks so much, I am using it for the one complete derailleur (missing the shim) that I have and it works beautifully!
Quoted: 85 Post(s)
Liked 83 Times
YEP, plenty of hangers (including multiple offers from members on this forum). No hex bolts. A little further down, member has described machining a bole and using sleeve. Don't know that I'll be able to do that, but will hold on to the in completes for a while.
Quoted: 1872 Post(s)
Liked 692 Times
I have two of everything you need, the problem is that I'd then be in the same boat you are in with two RDs that need the same stuff
2019 Salsa Warbird
2019 Salsa Warbird
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Likes For clubman:
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
There came a point in time when I no longer bought a frame without an integrated derailleur hanger. I have an Altoids box full of hangers. I'll paw through it. Maybe get lucky. I do have a VGT Luxe on one bike, so there is a possibility.
smelling the roses
Liked 901 Times
If you give me specifics, I'll continue the search. There are likely other bits around, less organized than this was. Let me know if it's of any use to you.
Edit: I see. It's not exactly the same. But the numbers match
Quoted: 85 Post(s)
Liked 83 Times
The hex bolts are perfect and I can certainly get another hanger. I will PM you . THANKS!
Liked 1,328 Times
The next stage is measuring the parts. If you - OR ANYONE ELSE READING THIS - have a set of calipers can you measure those bolts? The critical numbers are head dia, shaft dia, shaft length, and threaded section length; and it would help of course to have the mech model number from which it came.
If there are any shims then ID, OD, and thickness, and where in the sequence they are positioned. Suntour seems to have used the term "bush" for all such parts, and they didn't always have one on each side of the mech knuckle. A complete sequence I have termed Bolt - <shim> - Knuckle - <bush> - Hanger - <nut>
Likes For seedsbelize:
