Early 1990’s Schwinn High Plains Tire Size
Quoted: 41 Post(s)
Liked 26 Times
THREAD UPDATED: 1990’s Schwinn High Plains Tire Choice
I’ve found I’m enjoying riding trails and gravel on this bike and I’m purchasing a separate bike for pavement so I’m going in a totally different direction than I had originally thought.
The rear rack and fishing rod holders are no longer and the fenders idea has been abandoned.
What are some good gravel/ trail tires for the money that are supple and have decent rolling resistance?
Im considering the Panaracer Gravelking SK but am open to suggestions.
Secondly, based on a few of the comments here I’m thinking I can go as wide as 2.1” without issue.
I appreciate any thoughts and tips from anyone here who is familiar with this bike and it’s specs.
Thanks so much.
Thanks so much.
Quoted: 112 Post(s)
Liked 213 Times
IIRC, my High Plains utility ride had 2 inch knobbies on it when I got it off of CL. It has narrower Schwalbe Marathons right now. I've been considering adding 2 inch RibMo's, might need to take off the fenders I added. See the 26 inch tire thread for lots more ideas.
The Schwalbes have great, zero flats in over ten years of use on various bikes on lousy roads.
Quoted: 41 Post(s)
Liked 26 Times
Excellent
Quoted: 112 Post(s)
Liked 213 Times
Planet Bike aluminum fenders. Wheelset is not original; these are off a Gary Fisher that got flipped.
Gee, I better put the frame pump back on before the next ride.
Good luck!
Quoted: 41 Post(s)
Liked 26 Times
Wow
Thank you for sharing as it gives me a good idea of what my bike will look like with fenders.
Quoted: 86 Post(s)
Liked 78 Times
What year is yours?
My son has a '90 or '91 High Plains that still has a level top tube. We fit 2.25" WTB knobbies on it, but the clearance was so close he wore some paint off the chains stays after hitting curbs and some big bumps. The hard hits apparently dislodged the tire enough to make it wobble - the rim was still true. I don't remember what the situation was at the other choke points.
As far as tire width, I have 2.1" Maxxis on my Stumpjumper. They handle anything, but I think I'll replace them with something narrower when it's time. The 2.1" seem to offer too much cushion. I know I could, & do, air them up more, but seems like I don't need that wide which would probably reduce some weight too. We'll see when it comes time, I do like the look.
Quoted: 41 Post(s)
Liked 26 Times
Many Thanks
What year is yours?
I’ve decided to go with some 26x1.95 Kenda K838 City Slick tires.
My thinking is they will be a good all around all purpose option.
Likes For Basstar:
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
For what it's worth, my 1988 Schwinn Project KOM-10 ideally takes 26 x 1.95, although I have gone as high as 2.1. Particularly with the larger tires, I need to deflate the front tire to clear the brake pads, particularly for reinstallation. (Ubrake in back, SunTour Rollercam in front, although most of the other KOM-10s I have seen have conventional cantilevers in front.)
Likes For John E:
Quoted: 41 Post(s)
Liked 26 Times
My Bike’s Purpose Has Changed
I’m posting this here simply to bring the post back to the forefront as I’m changing directions with this bike.
Your insight and knowledge are truly appreciated.
Thanks so much.
Thanks so much.
Quoted: 86 Post(s)
Liked 78 Times
I'd go with Maxxis DTH unless you plan to be riding in mud. I've done a bunch of single track & had no problem, but I'm not an agressive rider either.
They've been great pavement/gravel/trail tires. They offer good suspension & have never let me down off-riad. There's a subtle hum on pavement, but nothing distracting.
Likes For thorstein:
