6 speed to 7 speed
Count Orlok Member
6 speed to 7 speed
I have an early '80s Raleigh Wyoming. I converted to 700c and cold set the frame for 130mm. I tried a 7 speed freewheel, but there's not quite enough clearance for it. I'm using the 6 speed version now, but I gather that I could try a 1mm spacer on the axle and it may give just enough room to get it to work. I thought I'd give it a try, but I asked a couple of bikes shops if they had spacers but they said no, and the only ones I can find on-line come in a bag of 20. Anyone have a source for one? Will I need to redish?
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Likes For ehcoplex:
Quoted: 86 Post(s)
Liked 78 Times
I'd give Express Bike Shop a try. Just off Lexington on Selby. By far my favorite shop in the Cities.
They had spacers when I went in there this spring.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Now that your frame is already 130mm, you might as well upgrade a little further into 8+ speed cassette hubs.
Likes For ThermionicScott:
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
This is going to sound like retro-grouch resistance at first, but what is your goal in switching from 6-speed to 7-speed? New freewheels tend to come in 14-28 or 14-34 either way, so there isn't much of a gain in my book. The extra cog is added where it is least needed in the progression.
You are right about the benefit of an 8-speed cassette. My mountain bike started 3x6, was evidently upgraded to 3x7 by the first owner, and I have since upgraded to a 3x8 cassette, which gives me a delightful set of gears spanning almost a 4:1 range (26 to 100 gear-inches), with 6-7 percent progression most of the way up.
Count Orlok Member
The two I tried said they didn't have any. Didn't have, or didn't want to sell them, I guess.
Liked 2,568 Times
I disagree about the "extra cog" being essentially unneeded. I can do most of what I want with a 2x6 setup, but 2x7 or 3x6 works out better for me, with good range and no gaps.
With old-stock or custom freewheels, one could definitely get a lot more out of that extra cog, but that's a rabbit hole I doubt I'd go down in 2022 with a 130mm bike.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Common washers are all that is really needed to add 1-2mm to the right-side axle extension.
3/8" washers can be reamed or filed to fit in just a minute or two and are available in many thicknesses.
Often I just use a thicker locknut, from my parts bins.
If you put a lot of static and/or dynamic loading on your rear wheel, a cassette hub may spare you broken or bent rear axles and driveside dropouts.
Likes For dddd:
Quoted: 359 Post(s)
Liked 582 Times
What I mostly had in mind are the new-production Shimano freewheels. One can choose between 14-16-18-21-24-28 or 14-16-18-20-22-24-28, oh joy.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,490 Times
I needed a 5-speed a few years ago for a keeper, and found a good looking one in China, like this:
https://www.ebay.com/itm/18534047304...temCondition=3
Not ramped, but works fine for my grocery getter.
Liked 2,568 Times
Not that I know of!
But if I were in the market for freewheels at all, I've considered masking off the smaller cogs and spraying or brushing some kind of copper/brass-colored paint on the biggest cog. That way, even if not an exact match, it would look way better. The cogs on SunTour freewheels didn't always match exactly either.
Interesting! Are these NOS from [checks vintage-trek.com...] 1995, or recent production?
Quoted: 1952 Post(s)
Liked 2,013 Times
Wait a minute.
You cold set to 130mm? I did that once so I could use a 7 speed cassette with a spacer on a 130mm OLD freehub. If you put the OG wheel back in your 130 drop outs, they will come back to 126 and you are back to square one.
get a longer axle or a new hub.
edit: the spacer is behind the cassette
Quoted: 3241 Post(s)
Liked 2,512 Times
If you went to 130 I think you can go 8, 9 or 10 in back.
Likes For seypat:
Quoted: 2364 Post(s)
Liked 1,751 Times
Thicker locknut as mentioned, or check the spacer stack on each side, see if you can swap them around to give you 1mm more on the drive side. Whatever you do, you'll need to have 1mm less on the NDS anyway. And yes, you'll have to re-center the rim between the locknuts.
señor miembro
Liked 6,490 Times
Likes For SurferRosa:
Count Orlok Member
Wait a minute.
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
Another vote for the Sunrace 7 speed freewheel (13-15-17-19-21-24-28) MFM30 7CS,
which is all chrome finish and I've fitted it on 127mm OLD (Campag nuovo tipo hub).
It's £21 on ebay (UK).
Quoted: 1641 Post(s)
Liked 831 Times
Some bikes with 126mm OLD at the rear triangle cannot readily accommodate 7 speed FW's.
I found that out when I tried to install a 7 speed freewheel on my 1984 Peugeot PY19FC. The smallest cog could not clear the drive side seat stay bottom end.
It turns out that the frameset was designed by Peugeot to have seatstays are a bit closer together, above the dropouts, compared to other bikes with 126mm OLD spacing. So I'm stuck with just a 6 speed FW on the bike.
Count Orlok Member
As an update, I dropped By Express Bike Shop. They sold me four spacers for a dollar, in a variety of thicknesses from .8mm to 3mm. Then I checked my 7 speed freewheel, and it also jumps from 24T to 34T. I could have sworn it had a 28T cog on it. So there's really no need to replace my 6 speed now, but if I find a suitable freewheel I can give it a try.
