On-the-wheel tubular tire repair
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Everybody knows fixing flats is the bane of tubular tire users, so when I got a flat on a nearly new tire I decided to try something different. I was too lazy to rip off the tire, open the casing, and fix the tube, and the tire wasn't that good that it justified having the repair professionally done, so after a little thought I decided I'd try some of that new-fangled tire sealant. I picked up a bottle at the LBS, got home and of course discovered that my tires don't have removable valve cores.
No matter; this stuff is supposed to seal punctures, right, so what's another hole? I gathered my materials:
1 bottle "Stan's Tire Sealant," fresh from the LBS, well agitated.
1 20cc piston syringe
1 22ga hypodermic needle
1 Pista floor pump
1 wheel with punctured tubular tire.
Step 1: put a little air in the tire, using aforementioned pump. This gives the tube some shape and allows me to introduce the needle without transfixing the tube. Fortunately the leak was small enough to retain the air for several minutes:
Step 2: remove plunger from syringe, attach needle, and introduce needle into the tube. You know you're in the right place when you hear the air return. Just like a chest tube!
Step 3: remove syringe from needle hub, leaving needle properly placed in the tube. The 22ga needle lumen is still quite small, so it will take a while for a significant amount of air to be lost. In any case, you can always add more.
Step 4: fill syringe with sealant from bottle. I used about 15cc. The LBS guy told me the bottle held enough for 2 tires (59ml), but the bottle states it was intended for MTB tires. I figured I could get away with less with narrow tubulars.
Step 5: attach syringe to needle hub and inject sealant.
Step 6: remove needle, inflate to full pressure, and give the wheel a good spin to spread the sealant around, then wait to see if it works.
Several hours later, it's still at full pressure, so I declare the procedure a success!
1 Pista floor pump
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4339 Post(s)
Liked 2,982 Times
Brilliant!
Bikes: 2007 Tarmac Pro
It's ALL base...
I see why you did this, but the idea of adding a hole to the sidewall area of a high pressure tubular tire makes me more than just a little nervous. Especially on the front wheel.
Good luck!
Good luck!
pan y agua
Quoted: 1452 Post(s)
Liked 731 Times
Vittoria Pit stop requires neither removeable valve cores, nor syringes.
You could get lost and die.
You could hit a tree and die.
Old fart
Liked 3,401 Times
Old fart
Liked 3,401 Times
Eh, why? The worst that can happen is another flat, just like the one that brought me to this point in the first place. Remember, a front flat on a tubular tire is much safer than a front flat on a clincher tire because a tubular tire doesn't rely on air pressure to keep the tire attached to the rim.
Bikes: Yeti ASRc, Focus Raven 29er, Flyxii FR316
Quoted: 17 Post(s)
Quoted: 17 Post(s)
Bontrager branded Vittoria.
But, I took my handy NoTubes sealant injector, removed the valve core, and injected 10cc of sealant. Shook the tire around a bit, put the valve back on, and inflated it. It held 100psi for longer than it had before, when puncture-free, and held ride-able pressure for several days longer than it was previously capable.
https://www.notubes.com/product_info....products_id/46
Old fart
Liked 3,401 Times
I did something similar with a tubular tire I had laying around the garage.
It's ALL base...
Certainly a clever solution, and I guess one more little hole won't matter, especially if it's effectively plugged.
Front wheel flats just freak me out, even if you're less likely to roll a tire with tubulars.
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
Would it be possible to get the syringe needle down the valve hole?
Old fart
Liked 3,401 Times
Hills hurt.. Couches kill
Bikes: 1991 Specialized Sirrus Triple, 2010 Trek Madone 6.5 Project One, 2012 Cannondale Caad10, 2013 Trek Crockett
Clever!
Bikes: Derosa SuperKing Dura ace, DA wheels, Cannondale Topstone AL, Grx, FFWD 350. Specialized Tarmac SL7 UDi2, Sworks Crux, GRX, Ridley X-night sl, GRX, Specialised Epic Comp Carbon.
Quoted: 11 Post(s)
Nicely done
BTW Did anyone see the ad, that pops up on this site about needles and syringes? Is it to do with this thread, or the other use that is so popular with Baseball players?
Old fart
Liked 3,401 Times
One day later:
Still holding full pressure; the injection site is circled.
Writin' stuff
Liked 19 Times
Take it a step further and make your own sealant. powdered latex (or latex patching and leveling additive, but that stuff stinks), and some water. Or windshield wiper fluid if your'e going to be using the tires below freezing.
I made 2 gallons for about $4, and it works just as well.
South Carolina Ed
Quoted: 344 Post(s)
Liked 291 Times
I have a tire that is a slow leaker and I opened it but couldn't find the puncture. I'm interested in giving this syringe approach a try and would like to know where to buy stuff locally.
Would Slime work as a sealant in tubulars?
Powdered latex?
Where does one buy a syringe - at a drug store? I thought one need a prescription to buy them.
Powdered latex?
gmt
Quoted: 45 Post(s)
you don't need a removable valve core. just open the valve, then put a small length of plastic tubing on it, fill the tubing with sealant, then inflate around the tubing. positive pressure will push the sealant in through the valve.
Building a better Strida
Bikes: bianchi brava 1988. fuji track 2007, 2006 Bianchi Pista, 1987 Miele and a strida knock off
wow, how much is that pit stop stuff?
i am assuming that with DEEP profile rims i'll need to dismount the valve area of the tire from the rim and then remove valve extender?
South Carolina Ed
Quoted: 344 Post(s)
Liked 291 Times
How small diameter and where can such tubing be bought?
