Yet another light thread.
Need a brighter front light then what I have....I use the cheapo light from Target...the Bell one that comes with a rear light for like 26 bucks or 29 bucks.
So I am swaying towards Amazon for my purchase and I would really like a good recommendation for a bright front light that is battery powered...really dont want anything above $30 so recommendations would be wonderful, that is sold on Amazon.
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Fred "The Real Fred"
ouate de phoque
Bikes: Bianchi, Nakamura,Opus
I have two of those,https://www.ebay.ca/itm/CREE-Q5-240-L...item231efa514e
Quite bright for the price but when you hit good bumps it tends to triger the dimming switch so it's a bit annoying.
ouate de phoque
Liked 1,245 Times
Do your two take the 18650 battery?
I put masking tape on the batterys to make a tight fit.
ouate de phoque
I know it's not the same. The way I wrote it was misleading, sorry. I just wanted to show what I got on my bike. The brightness is ok but the cheap chinese quality is annoying as you always have to fuss with the switch.
Liked 1,245 Times
I have 6 like to oneI linked. Water proof and have not had any switch problems.
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
Maybe not the time or place to ask, but when I first joined BF, your default 'suggestion' was typically a Dinotte- what's changed? Or are you still using the Dinotte as the primary to see by light, and have these cheaper ones acting as 'see me' lights on multiple bikes
Community guidelines
Liked 1,245 Times
I have B&M Ixon IQ Head light with a 20 hour run time from 4 AA batteries.
I have recently started using the 18650 Flashing Lights for Day Time Strobe use.
Have found that the adjustable focus flashlights make good night road lights for 3 hours.
I like the Three Mode ones best.
Two mounted under my bars with a rubber band.
My IQ:
On everything except my commuter, I have one of these:
https://www.dealextreme.com/p/romisen-cree-rc-n3-3-mode-led-flashlight-1xcr123a-2xaa-9070?item=52
mounted by one of these:
https://www.dealextreme.com/p/univers...diameter-31871
Less than $20 delivered for both pieces.
