Annual Tool Kit Check 2023
Quoted: 982 Post(s)
Liked 1,647 Times
Yep... I know... Another Tool Kit thread... Ha
Well things do change. I really don't mind seeing what other carry or feel is important for thier rides. Every now and then I pick something up or change something out. My addition for this year is a small self contained tubeless tire punch with bacon. Not that I have tubeless tires but, I have run up on a few tubeless tire users that were walking the dog because they didn't. Yep, I'm that slow guy ridding up on ya that will stop and give ya a hand ta get ya ridding again. It's no biggy, I got plenty of time.
Last year I finally retired my MT-1 multi wrench and my old Park tool pouch with the chain breaker for a modern multi tool. Also added a small bottle of oil and retired my Point Setter pliers to go back to my Mini Leatherman.
So, What items have you added or retired from your tool kit for 2023?
My Set For 2023
Reluctantly Retired But Still Revered
My Set For 2023
Quoted: 2345 Post(s)
Liked 2,853 Times
no pic, but added a co2 inflator this year, will see how it works for the next flat
other thing I added was to my new tube checklist...... tighten the removal valve really wheel in the shop
both in response to pumping up a tire, on a super hot day, and then having to start over again when the core unscrewed when I unscrewed the pump head (twice)
Quoted: 7046 Post(s)
Liked 11,094 Times
I ride mostly gravel or mixed surfaces (gravel+tarmac) with tubeless tires, and my kit is:
--Topeak Hexus X
--Dynaplug Racer Pro
--Two Pedros Tire Levers
--Silca Gravelero Mini Pump
--A couple Park Tools Tire Boots
--Two spare inner tubes
--For a race, I might add a CO2 inflator + one cartridge
For context, I live in an area with no uber (or similar) service and my wife's job will not allow her to just drop everything and come rescue me. I need to be able to resolve problems on my own.
--Topeak Hexus X
Quoted: 2026 Post(s)
Liked 1,096 Times
The MT-1 is still my multi-tool of choice for cost, weight and usefulness. I also carry a Ritchey Mini chain breaker, three plastic tire levers, a used KMC quick link, a Planet Bike CO2 valve, three 16gm CO2 cartridges, two spare tubes and a mini-pump. So far that has been enough on-the-road tools for everything I've ever needed and to bail out the occasional unprepared other rider.
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
I have the same multi-tool and pump as OP. Plus Stan’s Darts and Dyna-plugs for flats. Each has its advantages so I carry both.. riding tubeless of course.
Clark W. Griswold
Quoted: 4415 Post(s)
Liked 4,059 Times
For my on the bike kit on my main commuter it hasn't changed. Snap-On 1/4 Bit Ratchet, T7, T10, T25, T30, T40, 2.5 ,3, 4, 5, 8, 10, JIS/Crosstip #2 bits mostly PB Swiss (and one Wera) in a 3d printed magnetic holder. Then I have the Wolf Tooth Magura 8 bit lever and a Crank Bros Speedier Lever and a CO2 inflator and larger canister. I also carry a pump but I want to do a different pump. I haven't actaully used the Magura lever as a tire lever so if I end up liking it I might decide to swap out that Speedier Lever though that one is my favorite tire lever. Also my T40 bit is getting swapped to a T40 IP which is what Bosch uses for their motor bolts
In terms of my actual at home tool kit I would like to get a different set of Torx wrenches probably PB Swiss and maybe some other stuff I have wanted but not really needed.
Quoted: 850 Post(s)
Liked 1,080 Times
Vinacafe, Vietnamese individual instant coffee packet. Just add water. Easily fits in a tool pack and helps to make pumping up a high-pressure tire with a mini-pump easier and faster.
Likes For Crankycrank:
Liked 11,094 Times
Quoted: 511 Post(s)
Liked 646 Times
Likes For KerryIrons:
Liked 1,096 Times
In many decades and hundreds of thousands of miles of riding, I have not had a mechanical that required a rescue.
I've had two. One was a ring-shank roofing nail that went through the tire, both sides of the tube and stuck out just inside the rim. There was no way I could pull it out by hand. The other was three flats on one ride, all within the first 5 miles. I ran out of spare tubes and patients. My rescue tool was my cell phone.
Bikes: 2013 Wilier Gran Turismo, 1983 Trek 760, 80's Colnago Super, 90's De Rosa SLX, 2009 Waterford 22 Series Singlespeed, 85 Medici Pro Strada, De Rosa Alumino frameset, Dave Molten Fuso frameset, 70's beater Peugeot PX10, Zizzo Liberte, 2022 Yoeleo R12
Quoted: 122 Post(s)
Liked 200 Times
A big change to my saddle bag tool kit is the replacement of a single butyl tube with 3 Ridenow TPU tubes that will fit up to 32mm wide tires. Park GP-2 patches apparently work on these tubes.
The 3 tubes and a patch kit weigh about the same as 1 butyl tube but take up less space.
I’ve been on various rides with friends where someone has double flatted, or have gotten 2-3 flats on a single ride.
Likes For momoman:
Quoted: 303 Post(s)
Liked 137 Times
Once, ~15 yrs ago I double flatted (front/rear) from a curb hit avoiding a car and found both my spare tubes in the underseat
bag had holes rubbed in them by loose tools. Fortunately a passerby offered me a ride home, but I now double bag the loose
tools (MT1 wrench/Park chaintool/ tire levers) in Ziplock bags which are replaced every few years and bag the tubes also.
Those ultralite innertubes from Ridenow are not cheap, even by current standards, have to be riding with really good friends
before I would offer one. ($18 or so ea). Also not sure I would want one in the tire long term as they seem very thin but would
get you home.
get you home.
Quoted: 982 Post(s)
Liked 1,647 Times
I am sure you could easily make one from an old spoke. If interested I'll send you the specs...
Quoted: 982 Post(s)
Liked 1,647 Times
I get ya... and it's great that you even stopped to help people as many don't. I'll take note of your carry. I too carry a few Scab Patches but I personally have not had good luck with them even though they did get me home. Each year I take more away from my tool kit then I put in. And yes I do need to seriously consider a spare tube for sure...
Quoted: 982 Post(s)
Liked 1,647 Times
I have been looking into these TPU tubes and just waiting for the price to come down on them. My big question is flexibility. Can the same tube be used on 700c 32 and 27" 1¼ wheels? If the price goes down I'll certainly consider it for my 2024 Tool Kit...
elcraft
For 24 cents, I might just have to throw caution to the winds and buy it! I had noticed the bent spoke and extra quick link in your kit, but this device squeezes the quick link as a nutcracker might crush a nut?
Likes For elcraft:
Quoted: 122 Post(s)
Liked 200 Times
The Ridenow 700c TPU tubes are about $7-9 shipped from China. I just bought another 20 for about $7 ea using Aliexpress coupons and my order included 2 patch kits. My friends want to try them and carry them as spares. It took 8 days to arrive.
Quoted: 511 Post(s)
Liked 646 Times
Liked 1,096 Times
Neither can I and, in fact, I carry two spare tubes. I know some riders carry a patch kit (so do I) and claim they will just patch a punctured tube. However, finding a very small hole such as from a thorn or small wire can be nearly impossible at the side of the road. I've had flats that require a pail of water and floor pump to find. It's much easier and faster to install a new tube and repair the flattened tube at home later.
Quoted: 569 Post(s)
Liked 595 Times
Exactly, I seldom flat as I ride our retirement community roads with 5-8' bike lanes that are swept regularly but steel belted tire broken pieces of very fine belting wire are usually the cause of my flats and they often take a water tank to find.
