Deep Drop Caliper on Vintage Road Bike
Edo
Hi, I recently bought a Graham Weigh steel frame bike from I believe late ‘80s but I noticed that the rear brake doesn’t quite reach the rim of the wheel and is just 1/2mm too high. After a bit of research I understand I might have to install a deep drop calliper so I was looking for some advice.
I currently have Shimano 105 on alloy rims for both front and rear. I was also planning to install Koolstop Dura 2 pads, since I noticed I can’t brake on wet conditions.
If I have to replace the callipers with deep drop ones I would like to put something at least as good as the ones I currently have.
Any ideas I would really appreciate it.
Many thanks!
Many thanks!
Likes For Mr. 66:
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
https://www.amazon.com/Aican-Aluminu...0788QX964?th=1
https://bdopcycling.com/product/bdop...rs-pair-black/
Likes For dedhed:
Quoted: 837 Post(s)
Liked 1,061 Times
+1 for above advice although I have read that the BDop holders being a little chunkier, can contact the tires when applying brakes and after setting up 105 calipers for wider tires like maybe wider than 28mm tires but the info is a little vague. Can't remember where I found that info but you might be able to with some searching
EDIT: Found this old BF thread about the BDop clearance problems which can answer some questions. 650 BDop: A Cautionary Tale - Bike Forums
SE Wis
Liked 3,395 Times
Many thanks!
Many thanks!
Measure the reach you need.
https://www.sheldonbrown.com/caliper...2010%2D15%20mm).
Often if it's just a bit the slots can be filed longer
Likes For dedhed:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1947 Post(s)
Liked 1,469 Times
You need long reach caliper brakes like ...
These: Tektro R539 Road Caliper Set | Jenson USA
Or these: Tektro R559 Long Reach Road Caliper Pair | Jenson USA
Which are also available in black: Tektro R559 Long Reach Road Brake Calipers (Black) (55-73mm) (Pair) - Performance Bicycle (performancebike.com)
They may not be as good as 105 caliper brakes.
Quoted: 506 Post(s)
Liked 638 Times
Quoted: 4806 Post(s)
Liked 3,928 Times
Too bad I can't sell or donate any of the excess slot on my Pro Miyata's Cyclone calipers. (Super short brakes; probably the shortest I've ever seen and I have the pads all the way up and they just make the rim perfectly. A whole lotta slot I"m not using.
I seem to recall that there used to be made adopters that mounted like the brake bolt and had a second lower hole like the bike frame's that you mounted the brake to for solving your exact problem. I have no memory of what they were called. (I simply put Mafac Racers on those bikes but that doesn't give you a brake with the looks, feel or status of a 105. It will also require a hanger and therefore probably a different seat pin. Will stop you very well despite the low cost and excessive brake "squish".)
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
I'm glad I popped into this thread cuz I've not seen those extended pad holders before. They are clever.
Quoted: 2026 Post(s)
Liked 1,096 Times
The R539 should have the right reach range but these brakes have VERY strong return springs and require a lot of hand pressure just to make thee pads contact the rim. They are harder to apply than any Shimano brake caliper I've ever used. I bought a pair for an older Trek road frame and found them hard to get adequate braking even with Kool Stop Salmon pads due to the effort needed. Yes, the 105s are much better.
I agree with Kerry, if all the OP needs is 0.5mm, by all means file the slot.
Quoted: 1819 Post(s)
Liked 1,693 Times
They were called "drop bolts". One of the problems with long reach brake callipers is reduced mechanical advantage. Drop bolts solved this problem
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,484 Times
Likes For SurferRosa:
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,436 Times
I did the filing on a set of Sora calipers, front and back. Like the op, I only needed a millimeter of so. I tried the Dremel first, but felt like I had more control and accuracy with a round file. Took very little time, and cannot tell it has been done with shoes/pads back on. Alternately, as stated above, mid reach brake calipers would solve the issue. I have used the Tektro 539, the braking with salmon pads was very good. I have the long reach 559's on a bike now, braking is very good, but the 539's are a bit better and more than long enough for the op. The 559 would have a lot of unnecessary length, IMO. Shimano has some, but I cannot remember what models they are. Also the Kool Stop salmon pads are a bit narrower than most stock pads. I highly recommend those. I do not recall having an issue with having to use a lot of hand strength with the 539, the 559 do take a bit more.
If it was me, I would do the filing again. No cost and not much effort.
Quoted: 2338 Post(s)
Liked 2,822 Times
SE Wis
Liked 3,395 Times
Likes For dedhed:
Edo
Edo
Thanks for all the suggestions.
My apologies for the confusion, I was meant to write 1~2mm too high. To be more specific, with the Shimano brake pads I have atm, it’s about 1mm but when I tried to fit the koolstop pads, the offset increases to ~2-2.5mm.
SE Wis
Liked 3,395 Times
Likes For dedhed:
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
Even at 2mm I’d probably take a file to the pads where it might interfere with the tire. Or hold the pad stud by a pair of vice grips and take them to a bench grinder or angle grinder.
Liked 3,928 Times
SE Wis
Liked 3,395 Times
Likes For dedhed:
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,436 Times
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
Shimano makes mid reach brake calipers. They come in black and gray. I have a set I put on an old Trek 1000 frame. They work well on the carbon rims. I’d have to look the number up.
I did the filing years ago on an old set of 105 brakes I used on a Trek steel frame made for 27 inch wheels I put 700 wheels on.
Edo
Thanks for the pics. Do they take any pads like koolstop is swissstop as well?
