Do Weinmann 4dot and 7dot brake pads fit the same holder?
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
I stumbled across a set of 7dot Koolstop pads in my parts bin, can anyone tell me if they'll fit the same holder as the 4dot model? I'd hate to tear up the old set getting them out and find the new ones don't fit.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,266 Times
Any pictures?
I'm guessing you mean these R12 Weinmann 7-dot pads and not the classic R10 Mafac 4-dot or slightly longer R14 Mafac tandem 5-dot pads? Double check the dimensions.
From what I can tell they are slightly wider and shorter than the Mafacs.
Bikes: Some Schwinns, Raleighs, Centurions, Crescent, Bianchi
Quoted: 250 Post(s)
Liked 296 Times
Koolstop gives pretty detailed dimensions of all their pads on their site. Hopefully it can help you out.
Bikes: Raleigh Super Course, Raleigh International, Raleigh Gran Sport
Quoted: 252 Post(s)
Liked 319 Times
I think the answer is no. The 4 "block" pads are longer by about 4 mm as well as thicker. It may be possible to put the shorter 7-dot pads in those holders but I personally wouldn't do it simply because of the way it looked, independent of any safety concerns.
Maybe? Kool Stop International - High Performance Bicycle Brake Pads Since 1977
The dimensions according to Koolstop look close enough that I'd guess it's within manufacturing tolerances. However, the 7 dots are the slanted surface type; made for rims with slanted sides. I guess you could sand them flat, but new pads are a better idea, IMO.
It's the X pads and the 6 dots that are shorter.
I don't really remember the swapping compatibility because BITD Weinmann pads would be typically be replaced with new pads and holders complete, off the display card.
Quoted: 252 Post(s)
Liked 319 Times
My bad - I didn't count the dots. I just compared the one with the 4 blocky features to the pad in a Weinmann side pull brake I had in my parts box.
