gearing
gearing
hello people: I just really just noticed that a lot of new bikes,
especially mountain types have only one front sprocket. I'm use to seeing two and three. Like what I have. What's up with that?
IBBY
IBBY
Expired Member
Quoted: 3674 Post(s)
Liked 5,432 Times
Likes For shelbyfv:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Now that rear clusters routinely have ten or more sprockets, the need for the additional front mechanism, shifter, etc. has lessened.
Likes For JohnDThompson:
Old fart
Liked 3,400 Times
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Is this guy trying to be the new Larry Sellerz?
Quoted: 1944 Post(s)
Liked 2,164 Times
It is a supply chain issue.
Years ago there were no issues with the supply chain with fewer cogs in the cassette, there was less wear on the supply chain.
As more cogs were added to the rear, this caused supply chains to wear thin, especially during the pandemic.
Unfortunately, in a global economy, supply chains were not maintained adequately and wearing resulted in the availability of parts skipping all over the place.
So now you only get one chainring.
John
John
Guest
Liked 3,270 Times
Likes For Rolla:
hello people and hello to people of the corn: I think that large rear cluster is going to ware the chain out faster due to the angle it has to be in to get that gear. I found my smoothest riding gear when the front sprocket is in line with the rear like a one-speed bike.
IBBY
IBBY
Liked 2,164 Times
It’s not really the supply chain. It is the round earth vs flat earth.
On a round earth you are always riding up or down so you need more range.
On a flat earth you can get away with one chainring.
John
John
Quoted: 18415 Post(s)
Liked 15,545 Times
Likes For indyfabz:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
Also the large rear cluster requires more paper spacers that need waterproofing to ride in the rain. You should stick with what you have if you are happy with it.
Quoted: 3238 Post(s)
Liked 2,086 Times
A very biased article by WolfTooth. Yes 1X is simpler with no front shifter and front derailer, but it's not like front derailers wear out, I've got a Suntour triple from 1991 that is still functioning mostly as it's such a simple piece of equipment there's little to go wrong. Yes, 1X saves a bit of weight, so does taking a dump before you ride. 1X is easy as it's only the rear shift, the 11 and 12 speed systems give you the overall range of a tripe, but with only 12 gears you miss on a lot of mid-range gears that can be useful to keep up your cadence. My 9 spd. triple give me 14 different gears where as my 1X 12 sp. only gives me 12. And it's not like front shifting suddenly started to suck and they needed to move to eliminate the front derailer. The Shimano Di2 electronic front shifting is pretty much perfect and defies the argument of 1X being easy to use. There are advantages in frame design to eliminating the front derailer, the entire area around the bottom bracket is different, front suspension is easier to facilitate without dealing with front derailer movement, tires can be bigger with no issues of the tire getting hit by the derailer and in many cases these are better arguments. 1X does work really well on mt. bikes, especially where you are in terrain with a lot of fast up and downs where there's no need to think about the front shift and the rear shift. Is why I [prefer 1X on a mt. bikem but not on a gravel or road bike
hello people and people of the corn: I just saw in that article word of a clutch style rear deral. Never heard of the one before. How is Larry dooowing? Sounds like you miss em?
IBBY
IBBY
Expired Member
Liked 5,432 Times
Cube begat Could begat Qwaaal begat.... Does the Obtrusive L share DNA?
Expired Member
Liked 5,432 Times
Likes For shelbyfv:
Expired Member
Liked 5,432 Times
Likes For shelbyfv:
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times
Lots of you are making a joke out of this, but I'm wondering the same thing. Case in point: I have a 2019 Specialized Diverge with a 2x drive train which is perfect for the rides I do. The current Diverge lineup is all 1x for 105 and up groupsets, so I couldn't replace what I have with the current offerings from Specialized. The big issue for me would be that I like the 48-11 high gear, but the 1x offerings have smaller chainrings. I also like the closer spacing of the gears in the casette. It's not a problem for me. I'm happy with the bike I have. But it would be a problem if I wanted to replace my current Diverge.
There may be bikes from other companies that would be better suited for me. I haven't checked because I'm not looking for another bike. But like the OP, I'm thinking I'd rather have my 2x than follow the current 1x trend.
Likes For Random11:
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
1x is just the current "in thing". Just like 29" wheels were, then 650B, and now I'm seeing people talking about 26" wheels again. It is all about change to sell us more stuff.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Liked 8,925 Times
Likes For datlas:
Likes For badger1:
Old fart
Liked 3,400 Times
Quoted: 6963 Post(s)
Liked 10,963 Times
John
John
Quoted: 4227 Post(s)
Liked 2,488 Times
