3x2 drivetrain for touring
Really Old Senior Member
Not lost wanderer.
Quoted: 885 Post(s)
Liked 992 Times
Better setup would be a Sturmey Archer 3 speed with 2 cogs.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Looks like the closest alternative would be 50/26T front with a 16/19 dual freewheel cog and a 27T cog on the other side of the hub with a tensioner
This would be 83 gear inches top gear and 43 low gear on 16T with the ability to switch manually to 19T for 36 to 70 gear inches. 27T cog would be cumbersome to set up but results in a 25 to 50 inches two-speed range
A colleague had a folding Brompton with a similar set up. On a long ride, the chain tensioner fell off and we could not find the pieces. It was ride-able but very frustrating. I don't believe your set up would be any more reliable or have less drag than a regular derailleur.
Likes For MarcusT:
Not lost wanderer.
Quoted: 885 Post(s)
Liked 992 Times
Here is my simple alternative to this. A dingle speed.
It has both a 17-21 fixed cog and freewheel on the flip flop hub. The chainrings are 46x42.
This gives me 2 very usable gears with the same length chain. the 21-42 is 55gi and the 17-46 is 75gi. Not the ratios you are looking for but much simpler setup.
Likes For bwilli88:
Yeah I looked for the 17/21 Surly cogs but they are out of production. White Industries are the only ones making something similar
Too aggressive to attempt to tour on this but will test drive it locally. Thanks
Quoted: 514 Post(s)
Liked 448 Times
Quoted: 1944 Post(s)
Liked 2,164 Times
You started out with a triple crank and 2 cogs, but having to stop to move the chain was a problem.
Everyone ran around with suggestions and now you’re contemplating a double crank with 2 cogs that you have to stop to move the chain thus making a full 360 but with one less chainring on your Biopace crank. Why would you even do that?
I get the impression this light touring bike may only exist in your head.
But if I’m wrong, just run your original 3x2 as I doubt there is any other solution to meet your wants.
John
Likes For 70sSanO:
Liked 2,164 Times
I believe the OP has mistakenly put too much emphasis on drivetrain friction and optimum working chainline. Modern bushingless chains are much more flexible.
There is some merit of running fewer cogs and friction shifting. Those who are not interested in optimum performance and can live with larger gaps can ride along however they want.
He is also under the impression that a no dish wheel will be much more durable. While technically true, a poorly made no dish wheel will not hold up as well as a properly made dished wheel. But running fewer cogs and keeping to 126mm OLD or less should be more than durable. Even more so for light touring and modern rims.
I could see a vintage gearing setup of a 3x5 with the 26-38-50 and a 13-16-20-26-34, or there abouts. This more than covers his gear inches and lets him ride in the 38t the majority of the time.
John
John
I think at this point you have kind of pushed this a bit too far.
I appreciate the suggestions but apparently I'm okay with moving the chain manually.
If a symmetric wheel is stronger I can run it with fewer spokes and reduce drag. What's with the grump sauce
Liked 2,164 Times
Of course it's in my head. I'm designing and sourcing parts for it right now. What kind of comment is that?
No one would look at fewer spokes on a touring bike to reduce drag a nearly immeasurable amount while there is enormous aerodynamic drag from the panniers. It makes no sense in the real world.
John
Exactly, that's why this one has triathlon aero bars instead of panniers. Great minds think alike
Quoted: 2338 Post(s)
Liked 2,822 Times
drag for the wheel for touring is not a factor even without panniers or what ever you are carrying.
peopled have toured all over the world with standard asymmetrical spoke set ups
more spokes is better in a lot of ways, like if you break on a low spoke count wheel you have wheel that will be unrideable fast, but you can get away with a broken spoke on a 32 or 36 spoke count wheel
Over all very little of your design ideas seem based in practicality or reality of touring, especially in an sort of hils
good luck but don't be surprised with a little grumpus on focus on non issues vs real world
Likes For squirtdad:
Sure, and if you're riding on a dished wheel you need more spokes cause they break quicker, so who's right?
Liked 2,822 Times
Show where properly built wheel ( even tensions, double buttted stainless spokes, 3 cross, on good quality rims) breaks spokes frequently. I am a big guy and have thousands of mile on builds like that with out a broken spoke
your theory is not supported by any evidence
Liked 2,164 Times
as a lawyer would say: facts not in evidence
Quoted: 1034 Post(s)
Liked 1,290 Times
The rims have been bullet proof.
