It's decided: the Suntour Vx is the finest friction front derailleur.
Quoted: 236 Post(s)
Liked 171 Times
Man, I had forgotten how perfect the Suntour Vx front derailleurs are: buttery smooth, light yet precise shifting. Completely bomb proof. Absolutely destroys the Dura Ace 74XX and 7700 models I've been using. Heavy clunky and I have to say surprisingly delicate build quality (talking about the Dura Ace). Not a fan. Wow. Suntour Superbe Pro is a close second but in my blind taste testing I prefer the Vx even over the Superbe Pro. Impressive stuff.
Just had to get that off my chest.
Likes For tendency:
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,599 Times
Shhhhh!
Likes For cb400bill:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,485 Times
For me, it's the 3-hole NR.
VeloBase.com - Component: Campagnolo Nuovo Record 0104007 (1982 - 1987, 3-hole standard band)
Quoted: 236 Post(s)
Liked 171 Times
Likes For tendency:
Quoted: 786 Post(s)
Liked 520 Times
Ditto for Vx-S rear. The best kept secret in your local co-op RD drawer.
Likes For jeirvine:
señor miembro
Liked 6,485 Times
Death fork? Naaaah!!
Is that reverse action like the Compe V?
Top
Top
Quoted: 3464 Post(s)
Liked 2,829 Times
I needed to check, it is a “normal” actuation, does require a loop of housing.
might be a good candidate for a Simplex replacement.
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Likes For Bianchi84:
Idk
Between the two NRs and a Suntour XC Sport, I can’t really say which performs better. The XC Sport is even working with a weird 3 pulley rear derailleur and all is smooth.
Quoted: 1106 Post(s)
Liked 1,328 Times
Not necessarily - if the cable can be run under the BB shell it often will come up lined up well enough to go right through the slot/hole in the housing stop. It might even work with a clamp-on guide, if tweaked.
Those loops - any loop with a U - are water-traps, best avoided.
Bikes: to many to list
Quoted: 296 Post(s)
Liked 1,064 Times
I ran a shop in the 80s and its amazing how many people had those on their bicycles. Many took off the campy rear derailleur and put one VX on. Especially if they had a long cage. The VXGT was the best.
JJ
JJ
From Illinois. Collector of many fine bicycles from all over the world. Subscribe to my Youtube channel. Just search John's vintage road bike garage
Likes For jjhabbs:
All this time I was under the impression that the NR front der was the best I have used. Hmmmmm. Never cared for reverse action front or rear derailleurs. Have 10's of thousands of miles on NR front der and it has always performed perfectly without trouble. I have also had the Cyclone MkII front der on a bike I used for about 10K miles and it performed well much like the NR. In general ft der rarely underperform for me.
Quoted: 226 Post(s)
Liked 258 Times
I haven't really had problems with front derailleurs, so I usually just use a Cyclone FD to match the Cyclone RD (the greatest of vintage rear derailleurs IMO)
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Let us all now praise the least bad FD
Genesis 49:16-17
Genesis 49:16-17
Quoted: 834 Post(s)
Liked 2,126 Times
That may be the first time I have ever seen you post a photo. After all these years of dying to see your collection, I finally get a photo...of a Suntour FD?!
Likes For gaucho777:
Quoted: 834 Post(s)
Liked 2,126 Times
Quoted: 502 Post(s)
Liked 466 Times
I really like Campy Racing T FD’s, and only ride triples. I tried a Suntour XC Pro that also shifted very nicely, but the Racing T’s were less likely to need trimming across on 8-speed cassette from the middle ring.
FWIW, I’m shifting with Ergo brifters on my own bikes, but just added a Tripilizer ring to a DA 7400 crank on my daughter’s ’85 Miyata 312 (needs an increasingly rare 28.6mm clamp) with Shimano bar-end shifters, so pretty straightforward, you'd think. Tried a bunch of FD’s thanks to the plentiful choices where I volunteer. Quite a variety of subtle but irritating problems! Clamp arm hits the rear fender. Deep inner cage plate interferes with the middle ring teeth. Thick outer plate contours cause crank arm contact when on the big ring. One of my spare Racing T’s was the answer, although it required very subtle and precise adjustments for FD body rotation and the high limit screw to preclude crank arm-cage contact.
I just found a nice XC Sport in the proper clamp size and might give it a try some day, just to know. It’s outer plate has thinner contours, so it might be better with narrow Q-factor cranks like that DA 7400, but that could also affect its middle-to-granny shifts. And I’ll watch for one of those Suntour Vx fronts, too.
My rings, 46-36-24, and my daughter’s new Tripilizer setup, 48-40-28, are atypical among the fast bike crowd. YMMV.
Likes For Dfrost:
How much different are front derailleurs? I get my push rod Simplex FD's to operate quite well. 40-50 year old FD cages get wonky. A couple bends and precise alignment and they start operating better than new.
Not a fan of reverse pull fronts. I gotta have the feel of pulling the lever down and a big thwonk as the chain engages the big chainring. Thats one of the best feelings in cycling right there.
Back in the day it was common to see Huret FD's on otherwise full Campy bikes because they worked just as well as the Campy NR and cost maybe $5.00.
I like the NR front. Haven't dropped a chain in years and precise adjustment. Especially for FDs it is almost all in the setup and fine adjustment.
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,378 Times
I've been running a Suntour GPX this year. I was going to swap it since it's a bit chunky, but it works really well. Fast, positive shifts. Don't think it was designed for 8-speed setups, but I have plenty of clearance.
Likes For thinktubes:
Liked 2,829 Times
Liked 2,829 Times
