Conti GP 5000 - 25mm vs 28mm
Quoted: 1397 Post(s)
Liked 1,877 Times
Have 25mm GP 5000 tires on an old Schwinn Peloton with Kinesis alloy fork ; Ultegra dual caliper brakes (1990's)
The tires measure around 24mm installed (Campy Omega 19 rims)
Considering 28mm for the next set - but 28's might be too large ?
Appear to have room in the rear - but fairly tight at the front (fork)
Do the 28's measure at 28mm - or possibly less or more ?
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,469 Times
Just Pedaling
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times
I have 25mm's that measure 27mm and I have 28mm Vittoro's that measure 30mm. I also have some Kendra 32mm's that only measure 30mm. All dimensions taken with calipers on tires inflated to max pressures with many miles on them. The 25 and 28's are mounted on 17mm rims and the 32's are mounted on 19mm rims. I find I have the least clearance not side to side but between the mounting bracket for the Front DR on the one, and between the front brake calipers pivot point and the tire on another. The difference in comfort between the 25 and 28 is like night and day FWIW. Also, different tires from the same mfg measure slightly different. Unless you have a few mm's of spare clearance on each potential contact point on the 25's you have mounted now, I would be leary. The only time I have a problem with my clearances is if I run through mud or pine needles, wet leaves, anything that sticks to the tire quickly jams things up. Sometimes to the point of having to stop and scrape the crap out before continuing my ride. HTH
Quoted: 426 Post(s)
Liked 274 Times
On my aero road bike systemsix it was not the width but the height the was really close. 23/25mm fit great. The gp5000 28mm just barely fit in the back by the seat post.
several of my photos around post #20 and #25
https://www.bikeforums.net/road-cycl...0mm-tyres.html
Likes For sean.hwy:
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
I tried fitting 28mm on a 2000 Peloton Pro I had for awhile, and while I can't remember if it would clear in the rear, I am sure it would not clear the fork or front caliper, which was an ultegra on a carbon Look fork with steel steerer if I remember correctly. Had to stick with 25mm tires on that one.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
For GP5000 may depend on when it was made and the specific flavor. I’ve got one about 2 to 3 years old. On a 19mm inside width Aeoles at 90psig it measured 29.0 mm. Note it gets taller but this l did not measure. I’d run 25 from and 28 rear.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
If the rear will fit then buy one and try it on the front to see, No harm in mix and matching.
They run smaller than the GP4000, but remember if it's tight and picks up a stone you can shred your tyre.
Likes For znomit:
Liked 1,877 Times
25 does appear to be the max
