Bob Jackson seatpost binder bolt
self propelled lifer
Bikes: 1962 Dawes Galaxy; 72 Gitane Interclub;73 Peugeot PR10;78 Torpado Luxe;73 Grandis; 81 Raleigh/Carlton Comp; 85 Bianchi Stelvio; 87 Bianchi Brava; 73 Bottechia Special; 1969 or70 Bob Jackson
Quoted: 10 Post(s)
Liked 12 Times
Is anyone familiar with the kind of seatpost binder bolts used on 1970's Bob Jacksons with the fastback Messina lugs? The right side of the lug is deeply recessed and the left side is threaded....it must be some kind of alan bolt arrangement but i can't find any photos of the actual bolt online.
Thanks for any info.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
Sorry about the lousy pictures, but if this looks right, I can take it out and get some decent pictures and measurements of the bolt in the morning.
Quoted: 5 Post(s)
Liked 37 Times
I have a 70's Condor with fastback stays and what came with it was a large headed Allen bolt which I hardly think was original I would like to get one that will recess into the binding lug the head of the current one binds on the outside
Quoted: 150 Post(s)
Liked 34 Times
That looks like just a big allen head bolt to pinch together the split back of the lug. not really unusual.
I think you should be able to find a metric socket bolt from a good hardware store to fit and work
Before you posted your pics, I was thinking that it could also be one of those three piece wedge type pinch bolts that some bikes also have, which will be harder to find parts for.
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times
I would think 6mm x 1.0
Quoted: 10 Post(s)
Liked 12 Times
Thanks Dyander
IME, that's pretty UNlikely for a 70's vintage brit (or US) bike. Back then metric hardware was rare outside Europe (which does NOT include the UK - just ask any brit) or the far east. And on a bike from the UK, it could even be Whitworth (shudder...). So look in the SAE hardware section of your local Ace or big-box hardware store. And remember you'll need an inch-size allen wrench to go with.
SP
OC, OR
...been wrenching on 70's bike since the 70's.
SP
OC, OR
Quoted: 3464 Post(s)
Liked 2,831 Times
SP
OC, OR
SP
OC, OR
As Bob Jackson still exists, (even though the employees of the day are probably long retired) I would inquire with them. They have an active refinishing department still, so I bet they know from that work. If they have the correct fastener, buy it and pay the postage.
Quoted: 10 Post(s)
Liked 12 Times
I too think there is a good chance it is not Metric, and of course not SAE. Whitworth threading may not be that difficult as a bolt, (Think British car restoration) but an allen head cap screw in Whitworth may be more of a trick.
Thanks for the input guys.
Quoted: 150 Post(s)
Liked 34 Times
I had checked out their website, the only seatpost binder bolt shown costs $45.00. . Next trip to the City i'll check out the hardware stores. As a last resort i could drill out the threading on the left seatpost lug, then a regular alan bolt style will work.
The lug and frame designers went to such effort to provide a very clean design for the seat cluster. A bolt and nut affair will surely uglify that area if you go that direction. Give the hardware store a shot to see if you can find an equivalent to the original bolt. If you find it there, it will mostt likely just cost a couple of bucks at most. Try to find one that is either stainless steel or cadmium plated. Do not get a blued/parkerized one as it will rust almost as soon as you install it.
Quoted: 10 Post(s)
Liked 12 Times
Oh please don't resort to irreversable mods to the poor frame like drilling out the threads on the lug.
Liked 2,831 Times
Or, call them and follow up with an email directly to the person you talk to.
Take the bolt out and head to your local Ace Hardware, you may be surprised. I would guess metric, even on a Brit bike. At least by taking a trip to the hardware store, you will be able to tell for sure what the threading is.
Quoted: 39 Post(s)
Liked 32 Times
My Jackson tandem has the same bolts both front and rear. It is NOT metric. Whether it is SAE or whitworth I am not sure. I checked my triplet too and it too uses teh same bolts for all three seatposts. I remember back in the 70's I had to find an SAE allen key specifically for the tandem.
Quoted: 150 Post(s)
Liked 34 Times
If it is indeed SAE threaded, the OP will be in good shape as it's easier to find SAE Allen headed bolts in hardware stores here in the US....
Quoted: 10 Post(s)
Liked 12 Times
I've tried a few SAE seatpost bolts and all are too tight. It may be Whitworth but I thought Whitworth threads were quite coarse. According to one online source Bob Jackson built their 531 SL frames out of metric sized tubing so maybe they used metric fasteners also. This frame is very light so it may be SL. I'll pick up a few metric sized bolts this week and see if any fit.
Thanks again.
Should mention the frame has been back to the factory at some point for extra braze ons and a repaint so no frame stickers.
Thanks again.
Liked 1,064 Times
it could be an example of a BSC (British Standard CYCLE) bolt which is considered a sub-set of Whitworth standards but reserved for bicycle and motorcycles. It differs from the Whitworth threaded fasteners used in auto and shipbuilding specifically by the 60° thread angle used (compared to 55° standard Whitworth) and a finer thread pitch (usually 24 or 26 TPI).
If I was betting this is what I'd put my money on.
Since British motorcycles also used this threading, and employed many more Allen-head bolts in use than bicycles, I'd search your LMS (Local Motorcycle Shop) for a bolt. Or look on-line.
Still learning
Metrics have fine thread and course, so the pitch can be different.
Quoted: 10 Post(s)
Liked 12 Times
Quoted: 10 Post(s)
Liked 12 Times
https://www.retrobike.co.uk/forum/dow...e.php?id=74479
Not what i was expecting on such a slick looking lug, basically a knurled nut and bolt.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
