Benelux Fibre Washer Replacement?
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
What can I use to replace my spent fibre washer on Benelux Mk7 (down-tube) shifter assembly?
Part #:L21A.
Part #:L21A.
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
Quoted: 3814 Post(s)
Liked 3,345 Times
fibre washers are frequently employed in plumbing fittings
if you cannot locate the exact size needed at your local hardware or building supply store the next step would be to visit a plumbing supply
Likes For juvela:
Standard Member
Liked 940 Times
Thanks, Juv. I'll pop in to the plumbing store. I'm not sure what the thickness is, but I'm thinking maybe 1mm or less. Chrisbertwhistle, over in England, has a drawer full of 1950 original ones N.O.S., and he's selling them cheap as chips, but I wanted to find a temporary fix.
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Likes For Schweinhund:
