Different Gears
Different Gears
I have an 18 speed mountain bike which I like. I would like to have a couple more gears for climbing though. Buying a new/different bike is not an option but changing the gears/sprockets is. I haven't used my highest gears ever while riding. I don't do speed, 20 mph is the max so far and call me a wimp but that's about fast enough on a bike for me. I want more power. I was looking at 21 and 24 speed bikes this week and I was wondering about changing my front sprocket(s). I want to put a smaller first gear on the front so my first 6 gears will have more power. Is this a good idea, feasible or a waste of time.
Well, I just went and counted the teeth on my smallest front sprocket, 28, and I noticed it's about as small as I could put on there, there wouldn't be any room for the screws that hold it on. So I guess I would have to change the rear cassette. Any suggestions?
Bikes: cannondale crit 3.0, specialized allez, old giant mtb/hybrid
you want a new cassette with wider or a higher range. telling us what kind of parts you have can get you some answers.
Quoted: 454 Post(s)
Liked 104 Times
Guessing if you have an 18 speed (6x3), it's going to be 6 speed freewheel (cassettes are 7-11 speed, with some very rare exceptions) on the back, if this is the case, to upgrade to 21 or 24 speed would probably cost the same as a complete bike, due to having to replace so much of the drive train / rear wheel,
It's an 18 speed (6x3). I don't want to change it to a 21 or 24 speed. I want to keep it an 18 speed but change the sizes (or size) of the gear (or gears) in the cassette. What I was thinking is take one or two smallest rear gears off and add one or two larger ones keeping at an 18 speed with a lot more power in the 1-6 range. I would spend more time in the 7-12 gears for speed. The tech at the bike shop where I went yesterday said I might have to change the length of my chain if I did this to compensate for the new gears.
Pedals, Paddles and Poles
Bikes: Santa Cruz Tallboy, Ridley Noah, Scott Spark 20
Quoted: 1233 Post(s)
Liked 69 Times
Chain length is a big issue. It might be easiest to just buy a different cassette as mentioned above. Trying to change out a couple of gears can have surprise problems with the rear derailleur.
Like you, I would rather be able to climb than have a big upper end speed on my MTB. What year and make is your bike? WE might be able to come up with something more specific for help.
https://www.ebay.com/itm/Shimano-Deor...item5d44460700
This 13 - 30 cassette is on Ebay for $6.00 at this time. Seems to be the tallest Cogs I could find for a 6 speed. It is an XT, so compatibility might be an issue.
I think its disgusting and terrible how people treat Lance Armstrong, especially after winning 7 Tour de France Titles while on drugs!
I can't even find my bike when I'm on drugs. -Willie N.
OK, here goes. Your probably going to roll yours but it's a Huffy Rock Creek, 26",18 speed, dual suspension bike. I know, it's a BSO but I love it. I bought it mainly because of the dual suspension. Your probably going to say it's not worth the effort or money but I have limited funds and I'm not going to get another bike for a while. While I'm riding this I am deciding what I do and don't like about it and what I want on one later when I do get a better one. Right now I just want to make this upgrade. The cassette on this bike goes from 28 teeth at gear 1 to 14 at gear 6 (I don't know how to say that in bike lingo). I've heard of gears at 32 and 35 teeth recently.
Im thinking about this and I doubt you really need different gearing, If you are in the smallest front ring and the largest back cog I cant imagine you would really need a higher ratio.
u just gota exercise more!!!
if you have your heart set on this you will need a new back freewheel. And probably a new chain. and if you dont have a chainwhip and a lockring tool you will need to pay a shop another 5-10 bucks to switch the freewheel/cassette out.
Liked 69 Times
We all dance with the girl we brought. And we all wish we have something Brian Lopes would be proud of. I'm running a 36 right now and its good. I just can't find anything else. If you go too tall, then your rear deraileur might not have room for it.
Some slug suggested to me that I needed to improve the motor when I asked a similar question. Kinda like what Escarpment suggested. There is some real wisdom there. BUT my motto is, why get good when you can buy equipment?
miles, I won't say you won't/can't find a 6-speed freewheel with lower (higher number of teeth) gears; I will say it'd be TOUGH to do. And it is because, yup, you have a big-box bike. Not a lot of selection out there for 'upgrade parts' for those, and in 6-speed? WOW. A better bet would be a different crank. Is yours a 1-piece or a 3-piece?
What I'm thinking is, get a replacement crank that will match from a 24-inch-wheeled bike, should have smaller chainrings.....
DX-MAN, now I'm curious,
This is sounding possible. I looked at my bike after watching a youtube video about replacing a bike crank and it looks feasible, as long as I can get a smaller chainrigns to fit. I had almost given up on the whole idea. This is what I wanted to do in the first place.
What I'm thinking is, get a replacement crank that will match from a 24-inch-wheeled bike, should have smaller chainrigns.....
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
6-speed freewheels with lower range aren't hard to find at all -- it's surprising that someone with access to Internet would be so confident that you'd fail in your quest.
Shimano makes a 14-34 "MegaRange" which may require a different rear derailleur. IRD makes some 6-speeds that go down to a 32: https://www.interlocracing.com/freewheelbreakdown.html
Which crank model do you have (got pics)? At least for old-school mountain bikes, the granny ring could be as small as 24T, which would help you out.
ThermionicScott, thanks for the info. Now I can look at this from both ends and see which is the better solution. I will see about getting the crank model number and pics. I bought this bike new almost 3 months ago. I check the front gears, they're 28/38/48. I just saw one on the internet that is 22/32/44. My crank is 8" and the one I just mentioned is 7", would that make much of a difference in the pedaling?
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
I found this, how does it work, special derailleur? https://www.amazon.com/Cycling-Bicycl...0064215&sr=1-9
Moar cowbell
Quoted: 29 Post(s)
Liked 6 Times
Same dreailleur, as long as the cage is long enough. Mega-Ranges shift a little clunkily into that big cog but they do shift. I had an 8-speed Mega-Range years ago that gave me my needed stump-puller gear and worked satisfactorily.
Liked 69 Times
And the fork is mounted backwards on this baby! I would hate to see the rider after he winds this up and has the front end fold under him!
Pint-Sized Gnar Shredder
Bikes: '09 Jamis Komodo, '09 Mirraco Blend One, '08 Cervelo P2C, '08 Specialized Ruby Elite, '07 Yeti AS-R SL, '07 DMR Drone
Liked 69 Times
Besides, look at that string of Dance Partners you got in the garage! I am so boring.
OK, my front gears are 48-38-28, standard set I guess. I found a set 42-32-24 and 42-32-22. Can any one here tell me if there is a chart or what ever that can tell you in power and speed what the difference is in these sizes. The reason I'm asking that on set drops my grannie gear by four teeth, the other by six. Will two teeth make that much of a difference in that size gear? The price difference is minimal from what I can see.
Bikes: 2013 GT Karakoram 3.0 29er Hardtail
It's basic maths, the difference between a 28 tooth and a 24 tooth is will give you a gear that is a big the gear that you have times 24/28. or a gear that is 86% of the size.
S'toon trail rider!
Bikes: 2011 Norco Mountaineer(XC/Trails), 2011 Jamis Commuter1(commuter)
Quoted: 12 Post(s)
I run a 2x8 with 22-32 up fron and 13-32 in the rear. I'm debating going single ring up front with a 30t ring. Yes they make them. Atleast raceface does
Edit: in addition, 2 teeth is about a 5% difference in resistance.
