Should I worry?
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times
Should I worry?
during a ride , i was taking a little break with my bike standing next to me... whitout any forewarning the wind changed direction causing my bike to drop and hit the floor.
the lever has been inclined but nothing has been damaged, the pedal is still intact but the frame has an huge chip into the clear coat.
bike is almost new , 20 days exactly since i buyed it.
the clearcoat chip was shattered almost as glass, but i can't find anything else on the frame.
looks like that only the clear coat has been damaged, i know i can even fix by myself but this doubt about the carbon fiber integrity is driving me insane,
should i really worry?
any test i can do?
image: https://i.ibb.co/sjn4H8F/1673136410117.jpg
any test i can do?
Quoted: 4409 Post(s)
Liked 1,563 Times
That area of the bike is likely solid carbon. I wouldn't worry.
The usual test is to tap the area with the edge of a nickel, listening for areas that sound dull or soft - like soft wood.
That clear coat sure isn't sticking great to the paint underneath. That would bother me on a new bike and cause me to contact the manufacturer. Clear coat should stick to the paint, not flake off like peeling a boiled egg.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
No. See linked paper, p. 1
Yes. MRI. See, generally, linked paper.
preprints201912.0295.v1.pdf
Quoted: 333 Post(s)
Liked 168 Times
Did the bike just hit the flat floor or did it hit something sharp or otherwise protruding from the floor? If not ...
Quoted: 333 Post(s)
Liked 168 Times
At this point I'm thinking that the cc saved the frame since took the hit instead ti the underneath paint or carbon layer.
Liked 1,471 Times
I agree that the clearcoat is brittle and shattered and that the CF frame is most probably fine, but I don't think the clearcoat saved the frame.
Likes For SoSmellyAir:
Liked 1,563 Times
Yeah, if the frame wasn't even painted that dropout would be fine. Carbon is reinforced hard plastic, not plaster of paris. Tubes are only fragile because they are so thin.
Likes For Kontact:
Quoted: 6196 Post(s)
Liked 4,810 Times
You might put some clear coat of some sort over that area to help keep the top coat from peeling or chipping away over time.
Likes For Iride01:
Liked 1,471 Times
Liked 4,810 Times
Not all lacquer is the same just like not all nail polish is the same. If it were me, I'd go to the auto parts store and buy a small can of touch up paint in clear coat.
But most anything will be better than leaving the raw damaged edges of the upper coats of finish exposed. Some clear 2 part epoxy adhesive might work well too if it can be spread smoothly.
Likes For Iride01:
Quoted: 333 Post(s)
Liked 168 Times
I've done some races, more than 1500kms into bad roads including some small potholes.
frame is still the same but sometimes I check the dropouts because my mind it's a bit obsessed.
