Good tutorial for Shimano hydraulic brake flush and replace?
My XT brakes haven't had the fluid replaced in like 5 years. I think it's time. 😵💫 Can someone link to a really good tutorial with video and/or pics? I can do most everything else on the bike, but I'm kind of intimated by this one.
Thanks...
Thanks...
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
Park Tool's website has what you need.
It is a pretty easy procedure, but you need to have some tubing and Shimano's bleed funnel or a syringe with the correct fitting. You don't need the expensive kits, just the $12 funnel and some tubing will work fine.
Liked 3,434 Times
Sometimes air bubbles are hard to dislodge, and a syringe can work better. You can also create negative pressure easily with a syringe, which is a simple way to remove gas (air) from a fluid.
The videos make it look simple, but it's very messy the first few times. Have plenty of rags and rubbing alcohol available
Quoted: 453 Post(s)
Liked 104 Times
What brakes do you have?
Shimano XT has been through multiple versions (3 major and several more minor) which require different processes.
A little more detail would be useful!
Liked 3,434 Times
Less than one atmosphere.
If you have fluid with gas dissolved in it in a syringe, you close the tip, and then start to pull out the stopper, it will create a partial vacuum above the fluid, and pull out air bubbles. It is a useful trick if the brakes feel too mushy.
But don't worry about it unless you have to.
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
Quoted: 792 Post(s)
Liked 1,494 Times
Quoted: 1397 Post(s)
Liked 1,877 Times
bbinfinite
hydraulic disc brake bleeding done right (Shimano)
