Refurbishing older bicycles project
Bikes: Vintage 80's Peugeot Urban Express & City Express
Greetings!
I need some advice. I am in the process of refurbishing an old bicycle that i have had for years. Sadly, it is not in the best of shape however it is in good enough shape that I just don't want to throw it out. I have found that it is a bit of an "orphan".....kind of like the old Ford Courier pickup.....where neither Ford, nor Mazda truly wanted to claim it as their own.
I have a vintage 80's "Peugeot Urban Express", a 15 speed, which seems to have "gone by the wayside". It is outfitted with Shimano parts including 5 speed freewheel gear cluster, and three front gears. It uses an older style 1/2" x 3/16" chain, a Shimano FD-AL11 front derailleur and a Shimano RD-AL11 long cage derailleur. I called a bike shop and of course was told that the only way it would be worth my while would be to do all of the work myself since the bike is so old. I think that after going through everything, cleaning it up, replacing cables, chain, brake pads, tubes, tires, etc., that there is a decent chance that the gears and derailleurs will still work, however I wanted to know if anyone knows if there are any other newer sets of derailleurs that might work for me, without having to replace everything else in the process. The 5 speed cluster consists of a low range of 14T, 17T, 20T, 24T, 28T. The front gears consist of 30T, 40T, 50T. If it turns out that the existing rear cluster is marginal, I do have a used replacement cluster that I ordered from eBay if necessary. Such clusters are difficult to find, to say the least. What I am looking for is to determine the best "Plan B" option, should my "Plan A" fail. There is a point where my effort may become futile however, I am not ready to give up on the project.
Depending on how my effort goes, if I am successful with refurbishing my bicycle, then I also have a "Peugeot City Express" to refurbish next which my wife used to ride Having said that, it is a bit ironic because even though the "City Express" was not as robust as my 15 speed "Urban Express" when I purchased it, I expect that since the "City Express was a 12 speed, it might be easier to find some replacement derailleurs, although I am not sure about whether the existing gearing would be compatible. In any case, I would appreciate any advice that could be offered to use these existing bikes. At 70+ years of age, I don't expect to be putting as many miles on bicycles as I used to do and since I am retired, I can also take whatever time that is necessary to refurbish what I have. It would just be nice to find some newer parts to use if I find it necessary to do so. Any advice is appreciated.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
Unless they are physically damaged, I doubt you need to replace the derailleurs. The tools to disassemble the bottom bracket are probably something you don't have, but overall this shouldn't be a tough project to undertake if you are somewhat mechanically inclined. The tires, tubes, rim tape, cables and fresh brake pads you already mentioned and maybe a chain are not too tough to DIY.
Thanks for your replay....
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
You don't have enough posts to post pictures, but you can upload them to an album anyway. If you upload a few pictures, they can be viewed and you will get better advice as to where to proceed and ways to do it.
Likes For Chuck M:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
With vintage bikes, the thing to do is to fully overhaul everything, reassemble with new consumables (chain, possibly freewheel, cables/housing, etc.) and adjust with perfection. While overhauling a component, you will usually know if something is worn out and needs replacement. Other times, you'll discover issues only during your maiden voyage after the full overhaul of the complete bike.
Likes For SurferRosa:
Quoted: 1143 Post(s)
Liked 1,743 Times
Foil and water is your friend for rust, bikes like those usually don't need much. A lot of the time bikes like yours just need new grease in the bearings and a little wd-40 here and there.
Get a few more post and a couple of days you'll be able to post pictures, with those we can give you very good advice.
Likes For Mr. 66:
SE Wis
Quoted: 2747 Post(s)
Liked 3,398 Times
SE Wis
Liked 3,398 Times
https://www.universalcycles.com/shop...gaAhPwEALw_wcB
Likes For dedhed:
This.
Likes For SlowingDown:
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
The 80s Urban Express had a pretty good spec sheet. Chrome-moly frame, Chrome manganese fork, mostly alloy accessories.
BTW, Evaporust is your friend here for tools at least. Good luck.
@SlowingDown, are you able to edit your messages after posting? You can delete duplicates this way.
After clicking Edit, click the Delete button, select Delete Message, then click the Delete This Message button. Sometimes it takes a while for the software to update the page. Be patient.
Thanks for the information. As a "Newbie", i seemed to have messed up a bit, but on your advice, did some "house keeping" to clean it up. I had to wait for a day to take care of it since I had already used up my limit of free postings for an non-paying subscriber.
Thanks for the link for the gear cluster. Being a "Newbie" with less than 10 posts, I had to edit out the URL. I went ahead and ordered a new gear cluster from the link that you sent. I am sure that it will be a better solution than installing used gears. I had not found that particular source and I was pleasantly surprised to see that they have a store in my own "back yard", here in Oregon. I should be receiving the gears in another week and I will anxiously be awaiting their arrival.
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 251 Post(s)
Liked 167 Times
Hi,
Welcome to the forum. What area of Oregon are you in? You need to see if there is a bike co-op near you. There are several in Portland. I know of others in Hillsboro, Corvallis, Salem & Eugene. I’ve been volunteering at the NW Hub in Salem for six years. The co-ops have training classes, work stations & sell the both new and recycled parts as well as new and refurbished bikes. You can signup for volunteer work which gives you access to the services.
If you are mechanically inclined, bicycles are a great hobby. Not too expensive if you stay away from the exotic stuff and provide the opportunity for lots of exercise. 🤗
Cheers,
Van
Cheers,
Van
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
You have a pair of excellent, durable bicycles that should provide years of continued service.
Good luck with the refurbishments.
Chain ring guards
My new bike stand arrived and now I can begin some serious refurbishing. I haven't ridden my Peugeot Urban Express in years, but I always recall how annoying it was to wrap velcro leg guards around my pants to keep them from getting into the chain. To that end, while my Urban Express is all torn down, I thought that I would install a bicycle chain ring guard over my front gears. It seems as if it is a rare thing and not particularly recommended to place a chain ring over a set of three gears. My question is, as long as there is enough clearance for the pedal, does anyone every add a chain guard ring over three gears? I realize that the chain ring bolts may need to be extended out and some spacers used with the outside gear however, if all of the clearances are good, is there a problem with doing that? In looking, it is a bit of a challenge narrowing down a chain ring to a 50T gear at 110 BCD. The main deal with that is that I have found some interpretive discrepancies of the actual referenced bolt-to-bolt measurements which led me to not assume that all 110 BCD bolt patterns are the same. According to some information on the "Wolf Tooth" gear ring site, here are the listed specifications that also match my 50T gear ring:
5 Bolt Chainrings - Measuring two adjacent bolts
BCD Distance (mm) Distance (in)
110mm 64.7mm 2.55in
While the majority of 110mm chain ring guards don't reference the above bold-to-bolt standard as shown above, I have seen a couple of advertised chain ring guards that show a variation from that standard, which leads me to try and verify the bolt-to-bolt specification before purchasing anything. Of course the first issue to resolve is if it is acceptable to customize a three chain ring bike in the first place by adding on a guard ring. Any comments or advice is appreciated.
110mm 64.7mm 2.55in
Hi,
Cheers,
Van
Cheers,
Van
I actually "bounce around" between two locations. My home is between Oregon City and Molalla, but I also have a family farm that I inherited outside of Amity, where my oldest daughter and her family now live.. Your suggestion about joining a bicycle co-op sounds like a fun thing to be involved in. After retiring in 2019, my major focus has been and remains, completing a lot of major projects at the farm which is why most of my time is spent at one location or the other. There are major projects at the farm that I need to complete i.e., finish installing an 800 ft. perimeter of deer fencing, 250 ft. of cross fencing, 75 ft. of picket fencing, complete the interior of a goat barn, run water lines to and from a solar-powered well and elsewhere on the property, install raised garden beds and connect a small water tower that I built last year for a drip irrigation system to the raised beds, lay underground conduit to an additional array of 10 solar panels for auxiliary power, and also build a pump house for the well that was drilled about three years ago,. You get the picture. Lol
The rural area where the farm is located is a popular place for bicycle riding groups to have riding events and I observe such groups riding every year. It would be a natural fit for me to keep my Peugeot Urban Express and City Express bikes at the farm, once they are refurbished. It is also a much safer and enjoyable place to ride when compared to where my home is.
If I had the time to join a bike co-op, it would be worthwhile endeavor. If the current weather was better, I would be at the farm now, working on some of the outlined projects but with all of the wet, rainy, and cold Oregon weather that we are having, it is a perfect time to be working on the bike refurbishing project.....at least until the sun comes out more.
Liked 341 Times
Also, you may wish to try Boeshield T9 or CRC 3-36 or Fluid Film for preventing rust reoccuring on hand tools.
Quoted: 339 Post(s)
Liked 632 Times
Not meaning to brag but I have numerous posts relating to restoring old bikes. Check them out and you are likel;y to find some info you can use. I have been working with Bikex.org for about 10 years fixing up old bikes for donation as well as doing restorations for sale.
As stated previously, most old bikes, if they haven't been thouroughly thrashed or left out in the rain to rust, can be brought back to good serviceable condition with a good cleaning, replacement of cables, and tires, and a adjusting.
Likes For capnjonny:
Quoted: 2338 Post(s)
Liked 2,827 Times
also some good web resources
https://www.parktool.com/en-us/blog/repair-help
https://www.sheldonbrown.com/
a book i like (covers old and new) https://www.amazon.com/Zinn-Art-Road...74944533&psc=1
sounds like you have your hands full with the farm...good luck with all of that
