1989 Schwinn Voyageur - upgrading brakes?
hi all,
Last year I picked up a 1989 (NOT 1985, got the title wrong) Schwinn voyageur. I finally had some time to work on it in the past couple of weeks, so I disassembled it, cleaned it, repaired some paint chips, and regreased the bearings.
I was putting it back together, and I showed it to a friend who had a horror story about the straddle cable of a cantilever brake disengaging, getting caught in the front wheel, and causing an awful accident. Which got me thinking about replacing the cantis in this bike for v-brakes, especially because I'm going to be using this bike to carry my current 10month old as soon as she turns 1, and I definitely don't want to risk it..
Scouring the forums I've been able to figure out the following:
1. The spacing between the posts for this bike is narrower than what modern brakes use.
2. The wire pull for v-brakes is different, so I would likely need mini v-brakes or different levers if I found ones that fit.
3. People have had success with modern Shimano BR-CX50/70 cantilever brakes, but these are still cantis, so I'm calling this plan b.
What are my options? has anyone been successful in getting modern v-brakes into this or a similar bike?
(I'll post some photos later once I'm home).
thanks!
thanks!
Quoted: 502 Post(s)
Liked 466 Times
There are several easy ways to prevent a straddle cable from fouling the tire such as fenders (your child will appreciate those) or reflector/light mounts.
if you switch to V-brakes, you’ve already figured out the brake lever issue. Having worked on LOTS of bikes with both types of brakes as a volunteer for the last 8 years, I’d stick with canti’s, but get good ones. Those you mentioned are excellent and widely available used. Tektro/TRP and Avid make some that use road style pads, which I’d prefer.
Good buddy @RiddleOfSteel tried mini-V’s and as I recall, he wasn’t thrilled with the feel of them. He might weigh in now that I’ve mentioned him. He also has considerable experience dealing with narrow post spacing.
Bikes: A bunch of old bikes.
Quoted: 278 Post(s)
Liked 871 Times
One option to increase safety, without changing the canti's is to change to a link wire instead of a straddle cable.
This was installed on later canti brake setups, because the failure doesn't stop the front tire suddenly.
It will probably require new inner brake cables as well.
Likes For daverup:
Quoted: 1872 Post(s)
Liked 692 Times
How many millions of miles have been done on standard cantis over the years?? MILLIONS. That's how many. I can't imagine this being an actual safety issue. Google any part ever made and you can find a horror story. Yes, even including steel.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
I mean... Yes. I totally agree with this. But rationality goes out the window when your precious cargo is involved. And if I can do something to reduce the risk, would be silly not to do it.
Quoted: 838 Post(s)
Liked 1,082 Times
Quoted: 753 Post(s)
Liked 737 Times
A fork crown mounted reflector would work until you get fenders or a rack installed.
Quoted: 800 Post(s)
Liked 753 Times
Just stay with canti brakes. If they were good enough for touring/mountain biking for many years, they'll be good for you. If there were a scourge of canti-related crashes over the decades cyclocross wouldn't still be using them. And in terms of safety, I prefer canti over v brakes. V-brakes to me are on/off kind of brakes, not always the best modulation.
Likes For Piff:
Quoted: 1083 Post(s)
Liked 687 Times
What advantages would you see in getting the CX50/70 vs getting modern pads for the current brakes?
Liked 687 Times
Try new KoolStop pads first. Assuming your cantis are set up properly, you'll have plenty of stopping power. Do you have reason to think that CX50s or CX70s would be better than what's on there now?
Not really, other than having the straddle cable instead of a link wire, which now I learned from the replies here that I can also replace.
I did use to have another 80s bike like 5 years ago with cantis and never had any issues with setting them up.
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
For an '89 Voyageur, the rear canti post spacing (width) and "height" (from the axle centerline) will most likely be amenable to a mini-V setup, but the front posts won't allow them--too narrow of spacing, and height too far from the axle. Too high a height disallows one the ability to set the brake pad low enough to contact the rim's brake track. The narrow post spacing also hurts that ability. This goes for any "slot type" (my term) V-brake or canti brake architecture.
[Cantis were often "pivot type" in that the brake pad is on a post that is grabbed by the canti arm and can pivot considerably. V-brake, center pull, and side pull calipers are all "slot type" with limited pad angle articulation (but great pad height adjustment), with a number of newer canti brake options being of the "slot type" variety. If you go to 700C wheels from the stock 27" wheels, the "pivot type" cantis will allow that to happen--it won't be possible with "slot type" brakes.]
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Tektro 539 dual pivot calipers and SLR design levers. Stops GREAT, excellent modulation, no squealing.
Just a suggestion...
I got new pads for my current cantis and fenders to avoid any issues with the straddle cable. If that doesn't feel right, I'll try these.
aka: Dr. Cannondale
Liked 3,404 Times
I’ve installed SKS black fenders on two bikes with Tektro 539 calipers. Easy fit with 32’s.
Likes For rccardr:
